为解决惰性催化剂加入到固体推进剂中引起能量降低的问题,以咪唑为原料经两步硝化、热重排和复分解反应合成了一种新型含能燃烧催化剂2,4-DNI铅盐(PDNI)。测试了其机械感度、相容性等性能,并与PNTO进行了比较。结果表明,PNTO和PDNI与NC/NG体系均具有较好的化学相容性,比PNTO具有更低的机械感度和更好的热稳定性。将其作为含能燃烧催化剂应用于固体推进剂中,考察其对燃烧性能的影响,结果表明,PDNI在螺压改性双基推进剂配方中的燃烧催化作用与2,4-二羟基苯甲酸铅相当。
For solving the problem of energy decrease of solid propellant caused by adding inert catalyst into propellant, a novel energetic combustion catalyst, 2,4-dinitroimidazole lead salt (PDNI)was synthesized by two stepsof nitration, thermal rearrangement and ion exchange reactions using imidazole as starting material. The mechani-cal sensitivity and compatibility of PDNI were determined and compared with those of PNTO. The result shows that PDNI has fair compatibility with NC/NG system. In comparison with PNTO,PDNI has the lower mechanical sensitivity and better thermal stability. The effects of PDNI as an energetic combustion catalyst on the combustion performance of the modified double base propellant were investigated. The results show that PDNIhas catalytic effect level approaching that of Pb(Ⅱ )-β-resorcylic acid complex.
引 言
在固体推进剂配方中添加燃烧催化剂是调节推进剂燃烧性能最有效的方法之一。由于金属氧化物或金属有机化合物作为燃烧催化剂添加到推进剂配方中引起推进剂能量的下降,因此,含能燃烧催化剂的研究在国内外得到普遍重视[1-4]。国内也开展了相关研究,其中关于NTO的铅、铜盐性能及其应用的报道较多[5-6]。
2,4-二硝基咪唑(2,4-DNI)是目前国外研究较为广泛的一种高能低感度炸药,因原材料易得,制造工艺简单,造成的环境问题比TNT少,能量比TATB高15%~ 20% ,而感度远低于HMX和RDX,因此,具有良好的应用前景,可以替代TATB,甚至可以替代TNT。由于咪唑环N位的氢显一定的酸性,是否影响该化合物作为单质炸药的使用是一个值得研究的问题。本研究以咪唑为原料经两步硝化、热重排和复分解反应合成了2,4-DNI铅盐(PDNI),并将其作为含能燃烧催化剂应用于固体推进剂,初步研究了其对推进剂燃烧性能的影响。
全文见附件:
2_4_DNI铅盐的合成及性能.caj
99.33KB
CAJ
236次下载
(本帖仅用于测试网站的格式化发表功能)
