有兴趣做大学有机试卷的同学做一下吧 不是我们学校的
thallium20122010/04/17化学 IP:天津
来吧 让大家迅速变成大学生
华东理工大学2006–2007学年第一学期
《 有机化学 》课程期末考试试卷  A  2006.1.24
开课学院:理优05级  专业:           考试形式:一页开卷,所需时间:120分钟
考生姓名:              学号:                    班级:               任课教师:荣国斌
题序    一    二     三    四    五    六    七    八    总 分
得分
评卷人
可用中文或英文回答一~七各题(共八页,八大题):
一.(1) Indicate all isomeric C4H9+ carbocations, which one is the most stable? (2 points)
(2) Write the appropriate resonance structures of anion 1 and show which form is more stable? (2 points)
(3) March the boiling points(9℃, 28℃, 36℃) with the appropriate alkane: pentane, 2-methylbutane, 2,2-dimethylpropane. (2 point)
(4) Draw the most stable conformation of
1-tert-butyl-1-methylcyclohexane. (2 point)
(5) Classify each of the following molecules as aromatic or not according to Huckel's rule. (4 point) :
(6) Assign absolute configurations as R or S for the compound 1 and E or Z for 2. (5 points)
(7) Give two structures of the product 4 and 5 from the hydration of 3. Indicate which one is optically active and another isomer is not. (5 points)
二. The Compound A, C6H12, reacts with 1 molar equivalent of H2 over a palladium catalyst. A react with OsO4 to give a diol, B. When react with KMnO4 in acidic solution, A give two fragments, one is CH3CH2CO2H and the other is a ketone, C. What are the structures of A,B, and C? (6 point)
三. Propose a mechanism to account the following reaction. (10 points)
四 The synthetic sequences shown below are unlikely to occur as written. Tell what is wrong with each, and predict the true product. (6 points)
五. How would you carry out the following transformation? Indicate the products or reagent (1~7 )you would use in each case. (24 points)
六. (1)The 1H NMR spectra of compound A, C8H9Br are shown. Propose a structure for A, and assign peaks in the spectra to your structure. (4 points)
(2)How would you use MS, or IR, or UV to distinguish between the following pairs of compounds, explain your choice. (6 points)
七. How would you synthesize the following two target molecules starting from the given compound? (12 points)
八. Translate the following message to Chinese: (10 points)
Although useful, the Friedel-Crafts alkylation reaction has several limitations. For one thing, only alkyl halides can be used; aryl halides such as chlorobenzene don’t react. In addition, Friedel-Crafts reactions don’t succeed on aromatic rings that are already substituted by the groups –NO2, –CN, –SO3H, or –COR. Such aromatic rings are much less reactive than benzene for reasons we’ll discuss in Section 5.7 and 5.8. Closely related to the Friedel-Crafts alkylation reaction is the Friedel-Crafts acylation reaction. When an aromatic compound is treated with a carboxylic acid chloride, RCOCl, in the presence of AlCl3, an acyl group, –COR, is introduced onto the ring.
来自:数理化 / 化学
thallium2012 作者
14年9个月前 IP:未同步
209858
《 有机化学 》课程期末考试试卷  B  2007.2.26
开课学院:理优05 专业:                    考试形式:一页开卷,所需时间:120分钟
得分
评卷人
可用中文或英文回答一~七各题(共六页,八大题):
一.
(1) Write the structure of all the alkenes that can be hydrogenated to form 2-methylpentane.(6 points)
(2) Assign E/Z configurations to each of the following alkenes: (4 points)
(3) Assign R and S designation to the following compounds: (4 points)
(4) Place the following radicals in decreasing order of stability: (4 points)
CH3CH2•C(CH3)2       •CH2CH2CH(CH3)2    CH3•CHCH(CH3)2
1                      2                   3
(5) For each of the following compounds,give the number of H’s with distinct NMR signals,and their relative δ values in decreasing order. (6 points)
CaH3OC(CbH3)3            CaH3CbH2CO2cH
1                         2
二.
(1) Give the product from the hydroboration-oxidation of 1-methylcyclopentene and classify the mode of addition.(6 points)
(2) Give the structures of the products of the following reactions[s:2]4 points)
(3)  Write the structure for the products from reductive ozonolysis of 1,2-dimethylcyclohexene. (2points)
(4) Prepare (a) PhCHDCH3 (b) p-DC6H4CH2CH3 from PhCH2CH3. (8 points)
三. Account for the formation of both 2-bromo-3,3-dimethylbutane and 2-bromo-2,3-dimethylbutane from the reaction of HBr with 3,3-dimethyl-1-butene.(10 points)
四. The synthetic sequences shown below are unlikely to occur as written. Tell what is wrong with each, and predict the true product: (6 points)
(1)
(2)
五. Indicate the products in each following transformation case. (10 points)
(1)
(2)
(3)
(4)
(5)
六. Using acetylene and any alkyl halides as starting materials, synthesize the following compounds 1 and 2 respectively. More than one step may be required.  Show all reagents and all intermediate compounds in your synthetic scheme.(10 points)
七.  In an abandoned laboratory has been found a flammable liquid, 1, in a bottle bearing only the label “Compound 1: C7H12”. Compound 1 reacts with 1 mol equiv of hydrogen and, after treatment with acidic KMnO4, gives the dicarboxylic acid 3. Another bottle from the same laboratory is labeled “Compound 2 (isomer of 1).” Compound 2 also reacts with 1 mol equiv of hydrogen, but yields cyclohexanone 4 after treatment with acidic KMnO4. Give the structures for 1 and 2 (10 points)
Hydroxylation of an alkene—the addition of an –OH group to each of the alkene carbons—can be carried out by reaction of the alkene with potassium permanganate, KMnO4, in basic solution. Since oxygen is added to the alkene during the reaction, we call this an oxidation. The reaction occurs with synstereochemistry and yields a 1,2-dialcohol, or diol, product(also called a glycol). For example, cyclohexene gives cis-1,2-cyclohexanediol in 37% yields.
When oxidation of the alkene is carried out with KMnO4 in either neutral or acidic solution, cleavage of the double bond occurs and carbonyl-containing products are obtained. If the double bond is tetrasubstituted, the two carbonyl-containing products are ketones; if a hydrogen is present on the double bond, one of the carbonyl-containing products is a carboxylic acid; and if two hydrogens are present on one carbon, CO2 is formed.
thallium2012作者
14年9个月前 IP:未同步
209860
只有b卷答案哦
理优05级06-07年度第一学期
《有机化学》(B)卷试题参考答案.
共八大题;除第八题外,用中、英文回答均有效。
一.(共24分)
(1)(6分,每个1.5分)
(2)(4分,每个2分)    1 Z,  2 E.
(3)(4分,每个2分)    1 R;2 S构型
(4)(4分,每个次序2分) 1 > 3 > 2
(5)(6分,每个次序2分):1 b < a;  2 a < b < c
二. (共20分)
(1) (6分,结构式4分,回答同面加成2分)
(2) (4分,每个2分)
(3)(2分,准确给分)
(4):(8分,每题4分)
三. (10分,正确写出第一步4分,重排4分,加溴各1分)
四. (共6分,回答正确,每小题各3分)(1)不符马氏规则,产物应为
(2)由于羧基上活泼氢的影响,这格氏试剂不存在
五. (共10分,回答正确,每小题各2分)
六.( 共10分,回答正确,每小题各5分)
七.( 共10分, 回答正确,每小题各5分)
八: (共10分,翻译正确,意思完整给分,文句不通扣1~2分。)
烯烃的羟基化作用——羟基对烯烃每个碳原子的加成反应——可以在碱性溶液中通过烯烃和高锰酸钾KMnO4反应来实现。由于在反应过程中氧加成到了烯烃上,所以我们称之为氧化反应。这类反应伴有顺式立体化学现象发生,并生成了1,2-二醇或称二醇(也可称为乙二醇)。例如:环己烯生成了顺式-1,2-环己二醇,收率37%。
当在中性或酸性溶液中进行烯烃与高锰酸钾的氧化反应时,双键发生断裂,生成含有羰基的产物。如果双键是四取代的,则两个含有羰基的产物都是酮;如果双键上有一个氢原子存在,则含羰基的产物中有一个是羧酸;而且若一个碳原子上有两个氢原子,则会形成二氧化碳。
其实 这是化学双语
latexles
14年9个月前 IP:未同步
209862
马的,有机太难,只看过一些无机的
齐国
14年9个月前 IP:未同步
209866
洋文看不懂啊。
startwood
14年9个月前 IP:未同步
209868
我有ZJU的物理化学试卷
但是发上来会被宰掉…这几乎是这学期的期末考卷了
thallium2012作者
14年9个月前 IP:未同步
209875
引用第5楼startwood于2010-04-17 16:24发表的  :
我有ZJU的物理化学试卷
什么意思
h_17
14年9个月前 IP:未同步
209901
全是英文·······
假猩猩
14年9个月前 IP:未同步
209970
...  我英文不好..看得我心里毛毛的...
thallium2012
2010/02/10注册,17天9时前活动
