变态货
拔刀斋2009/09/25喷气推进 IP:安徽
2MPa燃烧压力 无涡轮泵
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX/partners/mwade/lvs/XXXXXXXXXXXm
Sea Dragon was a two-stage design of 1962 capable of putting 1.2 million pounds (550 tonnes) into low Earth orbit. The concept was to achieve minimum launch costs through lower development and production costs. This meant accepting a larger booster with a lower performance propulsion system and higher stage dead weight then traditional NASA and USAF designs. The first stage had a single pressure fed, thrust chamber of 36 million kgf thrust, burning LOX/Kerosene. The second stage was ‘considerably smaller’ (thrust only 6.35 million kgf!) and burned LOX/LH2. The complete vehicle was 23 m in diameter and 150 m long. The all-up weight was 18,000 tonnes. The launch vehicle would be fuelled with RP-1 kerosene in port, then towed horizontally to a launch point in the open ocean. It would then be filled with cryogenic liquid oxygen and hydrogen from tankers or produced by electrolysis of sea water by a nuclear aircraft carrier (such as the CVN Enterprise in the painting). After fuelling, the tanks at the launcher base would be flooded, and the vehicle would reach a vertical position in the open ocean. Launch would follow. The concept was proven with tests of the earlier Sea Bee and Sea Horse vehicles. Aside from the baseline two stage expendable version, a single-stage-to-orbit reusable vehicle with a plug nozzle was designed. Costs to low earth orbit were estimated to be between $60/kg and $600/kg - eg one fourth that of the Saturn V or less.
Stage one used liquid nitrogen to force the propellants into the engine. At ignition, combustion chamber pressure was 20 atmospheres, and kerosene was forced into the chamber at a pressure of 32 atmospheres and liquid oxygen at 17 atmospheres. By burnout 81 seconds later combustion chamber pressure had declined to 14 atmospheres, kerosene feed pressure to 20 atmospheres, and liquid oxygen pressure to 8.5 atmospheres. At burnout the stage had reached a velocity of 1.8 km/second at an altitude of 40 km and a range of 33 km. After separation the stage would impact the ocean 290 km downrange (one alternate was recovery and reuse of the stage). Losses due to gravity and drag were minimised by the high 2:1 thrust-to-weight ratio and low drag losses (deceleration at max q was about 0.2 G’s ) resulting from the large size of the booster.
+200  科创币    power_rdx    2009/09/25 转帖有功
trample
15年4个月前 IP:未同步
153490
此物无爱...液氮有爱
novakon
15年4个月前 IP:未同步
153508
能把550吨送上低地球轨道
150m长
全重18000吨(靠。。)
将物体送上低地球轨道的代价为600美元公斤,可能比土星五号的四分之一更低。
普通用户
15年4个月前 IP:未同步
153540
帅哥,你先找个能出这么多钱的人来
jrcsh
15年4个月前 IP:未同步
153558
2MPa   换成力 也就 20KG左右吧
破兜漏糖
15年4个月前 IP:未同步
153567
引用第4楼jrcsh于2009-09-25 21:01发表的  :
2MPa   换成力 也就 20KG左右吧
只有几平方公分的面积么???
拔刀斋
2006/08/19注册,2年1个月前活动
