Preparation of Diphenylketone Oxime (二苯甲酮肟的制备)
carneades2009/07/29化学 IP:江苏
Submitted by P. Carneades C from YuanHe Institute
Procedure
A mixture of 5.0g of diphenylketone, 3.0g of hydroxylamine hydrochloride, 5.0g of sodium hydroxide is placed in a 150mL single-necked flask. Then cover the mixture with ethanol immediately (Note 1) and a few drops of water is added. Heat the flask on a steam bath for 10 minutes. 20 mL of concentrated hydrochloric acid is dissolved in 100 mL of water. Afterwards, pour the reactant into this solution, a considerable amount of powder-like crystal (crude product) is separated out and float on the surface of the liquid. Filtrate the mixture and recrystallize the cake in 40mL of ethanol (Note 2) . 4.0g of colourless acicular crystal (pure product) is obtained. The final yield is 81.4%
Notes
1. Ethanol must be added with stirring as quickly as possible. Or the hydroxylamine released will decompose spontaneously.
2. Recrystallizations with ethanol must be carried out on a hot-water bath. Organic solvents like ethanol, aether or something can be ignited easily by flames or sparks.
Discussion
The order of mixing the reactants requires some further adaption. The decomposition of hydroxylamine must be prevented.
Photographs of the Experimental Operations
元和中心XXXXXXXXXXXXXXXXXXX/tangxianzong/album/item/XXXXXXXXXXXXXXXXXXXXXXXXXXXml DSC03530.jpg
+300  科创币    焓熵`    2009/07/29 我爱那药饼!
+200  科创币    delete    2009/07/29 我不是这个板块的版主, ..
+1000  科创币    mithril    2009/07/29 嗯 产率多少?
来自:数理化 / 化学
13
carneades 作者
15年6个月前 IP:未同步
133014
这次做的二苯甲酮肟只是我的合成路线的中间体。
实验本来还有后续操作的,可惜温度没有控制好,东西没做出来。
明天重做这个合成的时候,还会再做二苯甲酮肟。下次发中文,这次就不翻译了。
carneades作者
15年6个月前 IP:未同步
133791
通报一下:昨天我重做了该合成实验,第二步在我的严格监控下终于做出东西来了。由于没有真空泵,过滤花了我一个多小时。
现在那坨湿漉漉的滤饼在干燥器里头,过几天再去重结晶。
carneades
2008/08/18注册,7年5个月前活动
