把二进制翻译成中文/英文
【四方】2013/08/27软件综合 IP:吉林
linux 把二进制翻译成中文/英文
01
#!/usr/bin/perl -w
02
#use diagnostics;
03
sub bin2cn{
04
    die "Error:1001:bin2cn\n" if chop($_[0]) eq "";
05
    @hexi = &bin2hex($_[0]);
06
    while(@hexi){
07
        $q=shift @hexi if @hexi;#noting
08
        $temp=&hex2int($q);
09
        $temp=$temp*16+&hex2int($q);
        push @cni, chr($temp);
    join '', @cni
16
sub bin2hex{
17
    my @binarr=('0000','0001','0010','0011','0100','0101','0110','0111','1000','1001','1010','1011','1100','1101','1110','1111');
18
    my @hexarr=("0","1","2","3","4","5","6","7","8","9","A","B","C","D","E","F");
19
20
    if(length($_[0]) % 4 ){
21
        my @in = &split4($_[0]);
22
        while(my $ta=shift @in){
23
            for (0..15){
24
                push @re, $hexarr[$_] if ($binarr[$_] eq $ta) ;
25
26
27
        @re
28
    }else{
29
        print "Error:1001:bin2hex\n";
30
        exit
31
32
33
sub hex2bin{
34
35
    my @hexarr=('0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F');
36
    my @in = split //, $_[0];
37
    while(@in){
38
        my $tai=shift @in;#noting
39
        for (0..15){
40
            push @reo, $binarr[$_] if ($hexarr[$_] eq $tai);
41
42
43
    join '', @reo
44
45
sub split4{
46
    my $ini = $_[0];
47
    push @res, substr($ini,$_,4) for (grep {$_ % 4 == 0 } 0..length($ini));
48
    @res
49
50
51
sub hex2int{
52
    if ($_[0] =~ /^[ABCDEF]$/){
53
        ord($_[0])-65+10;
54
    }elsif($_[0] =~ /^[0123456789]$/){
55
        ord($_[0])-48;
56
    }else{
57
        print "\nError: 1001:hex2int\n";
58
        exit
59
60
61
#open IN, "<./binaryfile";
62
#my $tee= <IN>;
63
#my @sd=&split4($tee);
64
#print "SS: @sd\n";
65
#print "OO: ".(length($tee) % 8)."\n"; 0
66
67
#print ord(1)." FF: ".&hex2int(1)."\n";
68
69
#my $Stee=&bin2cn($tee);
70
#print "TT: $Stee\n";
71
72
my $ods= "E4B896E7958CEFBC8CE4BDA0E5A5BDE38082";
73
my $des=&hex2bin($ods);
74
my $Stea=&bin2cn($des);
75
print "TT: $Stea\n";
转自 开源中国 Jahdo_Lee 发布于 2013年08月12日 22时
来自:计算机科学 / 软件综合
【四方】
2013/03/23注册,5年4个月前活动
