国外商品过氧化氢液机SS67B-3的各种介绍资料
拔刀斋2011/12/23喷气推进 IP:北京
SS67B-1 technical specifications:
Design thrust: 170 Newtons
Burn time: 18 seconds
Total Impulse: 3060 Ns
Design chamber temperature: 400 C
Design chamber pressure: 70 psig
Exit gas velocity: Mach 1.82
Maximum speed : Mach 0.8
Nozzle area ratio (exit/throat): 1.5:1
Maximum altitude: 5000 ft.
Parachute ejection: Induced drag
Fuel: gasoline
Oxidizer: 50% Hydrogen Peroxide
Ignition system: chemical
Dry weight: 7 kg
昨天群聊中的各种问题汇总
1.制造商主页?
XXXXXXXXXXXXXXXXXXXXt/~launch/
2.网站上的链接点出来是ISP主页,网站欠钱倒闭了?
地址略有不同的这个链接还能用,赶快下载吧。XXXXXXXXXXXXXXXXXXXXXt/~launch/XXXXXXXXXm
3.氧化剂(50%H2O2)和燃烧剂(汽油)混合加注?
不是的,混合后分层的图片仅用来说明二者混合不会自燃。
实际氧化剂和燃烧剂有各自的储箱(不过结构做在一起)
Parts description:
Nose cone
High pressure reservoir (500 psi)
Combustion chamber
Fiber-resin casing (c/w fins)
Oxidizer and fuel tanks (500 psi)
4.使用50%H2O2浓度不够点不了火、燃烧温度只有400多摄氏度不可能?
SS67B-3 Engine Specifications:
Thrust: 260 Newtons (57.2 lbs)
Burn : 8.5 seconds
Total Impulse: 2210Ns
Chamber temperature: 450 C (842 F)
Chamber pressure: 200 psi
Nozzle area ratio(exit/throat):2.62:1
Exit gas velocity: Mach 2.4
Fuel: Super unleaded gasoline
Estimated altitude: >5000 ft.
Dry weight: 4.60 kg (10.12 lbs) (including nose cone, parachute, fins)
Loaded weight: 7.1 kg (15.62 lbs)
还有前面发射的图片里面火箭有鸭翼无尾翼,怀疑是骗人的。
5.真的是骗人的?
用户表示发动机本身确有其事,能点火、有推力,实际卖的火箭套件也有尾翼。
但是价格昂贵、性能很差、推力不足,需要很长的发射架,而且开伞装置极其简陋。
XXXXXXXXXXXXXXXXXXXX/XXXXXXXXp?title=ISSS_Rocket_Projects
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX/XXXXXXXXXXXXXp?t=34046
XXXXXXXXXXXXXXXXXXXXXXXXX/XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXml
详细的用户评价:
XXXXXXXXXXXXXXXXXXXXXXXXXX/rocketry/XXXXXXXXXXtml
注意储箱设计很特殊,氧化剂和燃烧剂储箱同轴嵌套,在底面直接安装喷注器。
催化剂使用糊状高锰酸钾“饼”,放在燃烧室内的火焰稳定器上面。
6.其他相关资源
某大学买了一台之后研究改进写出的H2O2推进剂性能计算论文
XXXXXXXXXXXXXXXXXXXXXXXXXXXX/ojs/XXXXXXXXp/juer/article/viewFile/71/42
一个较大的业余火箭网站,里面有个醒目的塞式喷管图片(与这个无关)
XXXXXXXXXXXXXXXXXXXXXXXXX/Rocketry/XXXXXXXXXXXXml
ehco
13年1个月前 IP:未同步
346883
对该介绍表示各种质疑,各种蛋疼。。
还有,刀版
“注意储箱设计很特殊,氧化剂和燃烧剂储箱同轴嵌套,在底面直接安装喷注器。”
这个结构已经被广泛使用了,没啥特殊额,中间还有个柱状悬浮活塞和环形活塞,放置倾倒后失压。
thallium2012
2011-12-24
看我给你的帖子 然后好好给我回复一下
soap-coke
13年1个月前 IP:未同步
346926
其实自己做的比他还好,起码有自己的技术,联系到实际更适合自己生产。
买不是出路,自产才是王道!
何况我也怀疑这发动机的真实性
乖雪狼
13年1个月前 IP:未同步
347829
他的燃料箱直接加喷注器,这样不怕悲剧啊?万一回火,或是温度过高使过氧化氢在燃料箱内分解就不怕爆炸?
拔刀斋作者
13年1个月前 IP:未同步
348279
回 3楼(roboter) 的帖子
他用的是弹簧芯的喷注器,只有内外压差足够高才能顶开弹簧,相当于自带单向阀。
这样主要的优点是无需电磁阀控制推进剂,只需电磁阀控制增压气体,气路部分可以用铜元件。
而且50%过氧化氢相对不易自行维持连锁反应分解爆炸。
拔刀斋
2006/08/19注册,2年1个月前活动
