Private Declare Function EbExecuteLine Lib "vba6.dll" (ByVal pStringToExec As Long, ByVal Unknownn1 As Long, ByVal Unknownn2 As Long, ByVal fCheckOnly As Long) As Long Public Function ExecuteLine(sCode As String, Optional fCheckOnly As Boolean) As Boolean ExecuteLine = EbExecuteLine(StrPtr(sCode), 0&, 0&, Abs(fCheckOnly)) = 0 End Function Private Sub Command1_Click() If Text1.Text <> "" Then Dim Result As Boolean Result= ExecuteLine(Text1.Text) End If End Sub 在文本框中输入Msgbox "Hello",看看有什么结果。
