一款可以实时更新晨昏和全球卫星云图的桌面软件 Desktop Earth 2.0
原野风暴2011/02/01物理 IP:英国
可能有人已经用过了 但是我还是再发一次
这是一款可以实时更新地球晨昏和全球卫星云图作为桌面的软件
卫星云图有部分貌似是来自UK的邓迪大学  具体介绍和下载地址如下
INTRODUCTION
Desktop Earth is a wallpaper generator. It will generate a high-resolution, accurate representation of the Earth. The imagery is based on NASA's Blue Marble Next and Earth's City Lights.
Day and night is accurately represented depending on the Sun's overhead position (which depends on both the time of day and the day of the year) and both the snow cover and the foliage changes with the seasons.
THE GOODS
Desktop Earth comes in two versions:
Downloadable: This is for Windows only. Desktop Earth will sit in your systray, run whenever you are logged on, and continuously update your wallpaper with an accurate representation of the Earth. There is no limit on the resolution, and the imagery is calculated from high-resolution 2560x1280 textures, so you can go wild with it even on 30" flat panel displays. Multi-monitor configurations are also supported.
Click here for Desktop Earth.
Online: You select the date and time, specify the resolution up to 1920x1200 (WUXGA), and click Generate. A high-resolution lossless PNG file will be displayed in your browser.
Click here for Desktop Earth Online.
来自:数理化 / 物理
原野风暴 作者
14年1个月前 IP:未同步
278115
额  补充一下 还有一年四季的雪线变化什么的  大家可以下了自己慢慢玩
14年1个月前 IP:未同步
278121
有中文的么
原野风暴作者
14年1个月前 IP:未同步
278195
额  下了就能用    貌似没汉化  = = 不过也用不着 其实就是个定时换桌面的软件
tRNA
14年1个月前 IP:未同步
278594
俺以前用过这个,有点占资源。。。不过说的是当时的电脑,现在的电脑应该可以很好应对了吧....
现在用电脑干活了,基本不看桌面就没再安装(安装程序倒是一直留着),很久没用了。
以及,标题标签应该写天文而非物理。
unless
14年0个月前 IP:未同步
283007
有汉化的没
buck
13年11个月前 IP:未同步
286972
不错,标记一下
原野风暴
2008/03/04注册,7年0个月前活动
