来个邪恶的资料~~
trample2009/12/18化学 IP:陕西
关于邪恶的钍
attachment icon 钍的放射化学.pdf 1.10MB PDF 122次下载 预览
来自:数理化 / 化学
18
trample 作者
15年1个月前 IP:未同步
171564
嘿嘿  在来张XE截图
trample作者
15年1个月前 IP:未同步
171573
引用第4楼lily于2009-12-18 18:45发表的  :
SM货真多哦。。。改天我跟你俩一起去SM夸夸 猪毛共绯 的河蟹政策。
全是鸟语....还有牛人制出了HHTDD呐!!......
trample作者
15年1个月前 IP:未同步
171579
呵呵  正在翻译中....顺便提升鸟语水平...一举多得岂不是很好吗  嘿
trample作者
15年1个月前 IP:未同步
171591
今天DIY卧病在床.....脚踝受轻伤 擦破一块皮结果由于走路摩擦  小伤变大伤  今天第3天伤口还在流着淋巴与血的混合物.......
trample作者
15年1个月前 IP:未同步
171614
额 这份资料我也有  要详细的  呵呵
先小小的来上一段:
1、l,4-Diformyl-2,3,5,6-tetrahydroxypiperazine. Formamide (135 g, 119 ml, 3.0 mol) was added to stirred aqueous glyoxal (40% w/w, 435 g, 3.0 mol), and the pH was adjusted to 8.5 by using aqueous sodium hydroxide solution (10 M). The temperature rose slowly to 30°C over the first 30 min, and the solution developed a yellow tinge. The exotherm subsided, and after 4 h of stirring, the mixture was left to stand for 3 days. A first crop of the product (93 g) was collected by filtration, and a second crop was obtained by adjusting the pH of the filtrate to 9, the temperature of the mixture being controlled at 25°C with ice/water and the additional product being collected after 5 h. Both crops were washed well with water, dried, and purified by digesting the solid twice in a hot mixture of dimethylformamide/water (80:20). This involved using 70 ml of this mixture for each 30 g of solid, maintaining the stirred slurry at 75°C for 30 min, then cooling it to 30°C, collecting the solid, and washing it well with water. The product was dried over a desiccant to give a white solid (204 g, 66%), which darkened substantially above 190 °C and decomposed above 210°C (lit. mp ca. 225°C dec).
trample作者
15年1个月前 IP:未同步
171628
折寿算什么...活着就是用来绽放光彩的 苟且偷生、碌碌无为的活着还不如死了好
活着的价值不在于活了多长时间,而在于为世界做出了多少贡献
没有条件,我们可以创造条件..
遇到困难,我们克服困难
决不退缩,因为我们要意识到我们所肩负的重任
任重而道远,死而后已
天下兴亡匹夫有责...难道我们连匹夫都不如吗?
一些人就甘愿自己连匹夫都不如,我可不愿!
trample
2009/02/02注册,1年2个月前活动
