俄罗斯新款SDR电台即将发布,先睹为快
虎哥2014/06/19无线电 IP:辽宁
这是一个开放参与的项目(但没有完全开源)。这种项目组织方式+牛逼的技术背景,产生了优秀的产品。该机构架为前级+SDR收发机+PC机构架(据说是I7的电脑),售价约3K欧元,低于目前同类产品。传统厂商有些招架不住啊。
本文转自该项目的论坛:XXXXXXXXXXXXXXXXXXXXX
Besides transceiver features:
In the one box we have: Full PC(Mini ITX, Intel Core i7 CPU, full blown Windows 7 or Linux), 7" display, touch panel, with all the attendant features.
1. Installing digital communications software.
2. Contest loggers, magazines.
3. Internet browsing, internet clusters and other opportunities (e-mail,Skype, ICQ, TV... ) associated with internet.
4. Viewing and listening audio files.
5. Watching TV via USB-TV receivers.
6. And a lot of others, everything just limited by your fantasy.
In the first model of SunSDR-MB1 will be the next features:
Software: ExpertSDR2 (own software)
Supported OS: Windows All versions, Linux, in future MAC OS.
Direct conversion in RX/TX mode, in HF/VHF bands
Frequency range 0-75MHz, 95-155MHz
Wide band spectrum panadapter up to 80MHz
Two independent receivers
Full duplex mode (depends on software, will available in a new versions of software)
High dynamic range of receiver: up to 120dB in the HF, and up to 116dB in the VHF.
Sensitivity, uV: 0.07(Preamp on)/0.13(Preamp off)
Output power: 125W(HF), 60W(VHF)
IMD3 DR of transmitter, -35dB...-30dB (can be improved by software up to -60dB)
Predistortion of TX signal: will available later(depends on software)
ATU: Available as option.
Reference 10 MHz input
Very small CW delay: 10ms
ADC sample rate: 160MHz
ADC resolution: 16 bit
IMD3 DR, in-band: 100 dB
DUC sample rate: 640MHz
DUC resolution: 14 bit
High perfomance 24 bit Codec on board
Power supply: AC 110...220V 50...60Hz, 1A(RX)/2A(TX)
Weight: 9 Kg
Inputs/outputs:
VHF antenna connector(SO239)
Two HF antenna connectors(SO239)
Wide RF input port direct connect to high speed ADC(SMA)(for XVTRX, measurement etc.)
Wide RF output port direct connect to DUC(SMA)(for XVTRX, measurement etc.)
Reference 10MHz input connector(SMA)
ALC input port(RCA)
PTT input port(JACK 6.3mm)
CW Key input port(JACK 6.3mm)
External Control port with 8 power switch and RS-485 interface(D-SUB-15)
External control 2 port for Stealth Antenna 9310.
PTT output ports for external PA control(RCA x4).
Electret Microphone input(line in)(JACK 6.3mm)
Dynamic Microphone input with PTT switch for MH-31(RJ-45)
Headphones output(line)(JACK 6.3mm)
Ethernet connector(RJ-45) for LAN.
USB 3.0 connectors (x4 + x2 on front panel).
Speaker/headphones connector from embedded PC's sound card(3.5 mm Jack).
Microphone connector from embedded PC's sound card(3.5 mm Jack).
Display port connector.
HDMI connector.
Power supply connector.
Ground connector.
Special for SunSDR-MB1 will be developed an ExpertSDR2 software version with adapted GUI.
Features of the software is very big. You can find it in user manual which will be released in end of this month.
Approximately price on first model SunSDR-MB1 in base variant: 150 000 RUB ~ 4300 USD, + option ATU 6000 RUB ~ 200 USD
Exact price will be known after finishing all works with the first preserial model, which you seen in video(a small part - front panel).
Also may be will be started a special offer with prepayment with discount ~20% for first buyers... will seen after HAM Radio 2014 at Friederichshafen in Germany.
Approximately date of starting sales - end of autumn.
The picture with back panel has some difference with the first serial model of SunSDR-MB1 transceiver.
At the present time we are working on new GUI for SunSDR-MB1. Usual an ExpertSDR2 GUI was changed to special GUI for monoblock. Half way already passed. Next step it is increasing a fonts on the frequency scale between spectrum and waterfall, and increasing fonts on PWR-meter, SWR-meter and MIC-meter. Touch panel installed on high resolution IPS 7" display, and gives to user possibility to choose any function or to set any frequency in one touch.
On next week I'll publish a new photo with a fully assembled SunSDR-MB1 and finished GUI. SunSDR_MB1_GUI.jpg
Today was the first start of GUI for SunSDR-MB1.
老版本的框图
原型机
来自:电子信息 / 无线电
29
minlianw
10年7个月前 IP:未同步
696426
看不懂,翻译一下
ls.ls
10年7个月前 IP:未同步
696427
英语考10分的求野生字幕君
张静茹
10年7个月前 IP:未同步
696440
XXXXX 发表于 2014-6-20 00:33
英语考10分的求野生字幕君
不是哔哩哔哩 木有野生的.........
千斤拨四两
10年7个月前 IP:未同步
696441
这。。。。从小e文没学好,誰翻译下?
小龙鱼
10年7个月前 IP:未同步
696446
除了收发器的特点:
在一个盒子,我们有:全电脑(迷你ITX主板,英特尔酷睿i7处理器,完全成熟的Windows 7或Linux),7“显示屏,触摸屏,所有的服务员功能。
1,安装数字通信软件。
2,大赛记录仪,杂志。
3,上网浏览,网络集群和其他机会(电子邮件,Skype和ICQ,电视...)与互联网有关。
4,观看和收听音频文件。
5,通过USB电视接收器看电视。
6,和很多其他的,一切都只是限于你的幻想。
在SunSDR-MB1的首款车型将是未来的特点:
软件:ExpertSDR2(自己的软件)
支持的操作系统:Windows所有版本的Linux,在将来的MAC OS。
直接转换的RX / TX模式,在HF / VHF频段
频率范围0-75MHz的,95-155MHz的
宽带频谱panadapter最高可达80MHz
两个独立的接收器
全双工模式(依赖于软件,将提供软件的新版本)
接收器的高动态范围:高达120dB的在HF,和高达116分贝在VHF。
灵敏度,抗紫外线:0.07(前置放大器接通)/ 0.13(前置放大器关闭)
输出功率:125W(HF),60W(VHF)
发射器的IMD3 DR,-35分贝...-30dB的(可以通过软件可达 - 60dB的改善)
预失真TX信号:将稍后推出(取决于软件)
ATU:可作为选项。
参考10 MHz输入
非常小的CW延迟:10毫秒
ADC采样率:160MHz的
ADC分辨率:16位
IMD3 DR,带:100分贝
DUC采样率:640MHz
DUC分辨率:14位
性能比较高的24位编解码器在船上
电源:AC 110 ... 220V 50 ... 60赫兹,1A(RX)/ 2A(TX)
尺寸:320x240x140mm
重量:9千克
输入/输出:
甚高频天线连接器(SO239)
两个高频天线连接器(SO239)
宽RF输入端口直接连接至高速ADC(SMA)(用于XVTR​​X,测量等)
宽RF输出端口直接连接到DUC(SMA)(用于XVTR​​X,测量等)
参考10MHz输入接口(SMA)
ALC输入端口(RCA)
PTT输入端口(JACK6.3毫米)
CW键输入端口(JACK6.3毫米)
有8个电源开关和RS-485接口外部控制端口(D-SUB-15)
外部控制2端口,用于隐形天线9310。
PTT输出端口,用于外部PA控制(RCA×4)。
驻极体麦克风输入(线路输入)(JACK6.3毫米)
用PTT开关的MH-31(RJ-45)动圈式麦克风输入
耳机输出(线)(JACK6.3毫米)
以太网接口(RJ-45)用于局域网。
USB 3.0接口(前面板X4 + X2)。
从嵌入式PC的声卡(3.5毫米插孔)音箱/耳机接口。
从嵌入式PC的声卡(3.5毫米插孔)麦克风接口。
显示端口连接器。
HDMI连接器。
电源连接器。
接地连接器。
特供SunSDR-MB1将开发一个ExpertSDR2软件版本改编的GUI。
该软件的特点是非常大的。你可以找到它在用户手册将被发布在本月底。
价格约在第一个模型SunSDR-MB1在基地变种:150 000 RUB~4300美元,+选项ATU 6000 RUB~200美元
具体价格将在完成所有作品的第一preserial模型,你在视频看到的( - 前面板上的一小部分)后才能知道。
也可能是将要启动的特别优惠与提前还款与折扣~首次购房者的20%......将业余无线电爱好者在2014年后在德国看到在Friederichshafen。
起点销售金额约日 - 秋天的结束。
与后面板的画面与SunSDR-MB1收发器的第一序列模型的一些差异。
谷歌一下会怀孕啊
ufo007sss
10年7个月前 IP:未同步
696450
口水留了一地!但是短波等波段的降噪滤波效果,也就是说音频的清晰抗噪很重要,数字信号解密神马的也很重要不然的话没特点[s:12]
leeqingyang
10年7个月前 IP:未同步
696451
最重要的聊天频段竟然没有,差评
BG8KIH
10年7个月前 IP:未同步
696457
神器啊,好想立即拥有[s:13]
光谱
10年7个月前 IP:未同步
696506
@liu000888 买不起的都不是好东西
go炮君
10年7个月前 IP:未同步
696510
神器啊买不起
Cleyton
10年7个月前 IP:未同步
696520
不明觉厉
虎哥作者
10年7个月前 IP:未同步
696532
160M,16bit采样,这个硬件选择有些变态,按这个条件应该可以做到全直采,灵活度非常高。
edges00
10年7个月前 IP:未同步
696535
看起来好给力的样子
kar98
10年7个月前 IP:未同步
696565
看来很多B站的啊......
LF1364855
10年5个月前 IP:未同步
716101
3K欧元 是个问题
ufo007sss
10年5个月前 IP:未同步
718027
每次看到这个都无比的羡慕啊!!!真漂亮!!!什么时候才能有财力买个回来啊[s:10]
10年5个月前 IP:未同步
718697
DDDDDDDDDDDDDDDD[s:12]
大名
10年5个月前 IP:未同步
718966
能与IC7800抗衡吗[s:9]
表慌张
10年4个月前 IP:重庆
722788
这个可以用来打地主吗?
zw1235
10年4个月前 IP:浙江
722804
16bit,160M采样率??????????
这指标.严重怀疑
成飞秋山澪
10年4个月前 IP:山东
723445
求个野生字幕菌。。。。。。。。。。
ufo007sss
10年4个月前 IP:河南
725290
引用 大名:
能与IC7800抗衡吗
我看功能花样上能抗衡,指标、性能上绝对不能抗衡[s::lol]
xiongfeixiang
10年4个月前 IP:河南
725313
只能流口水咯
xuliya282
9年11个月前 IP:安徽
751990
这东西的用途不会太有前途的
黑暗死宅男
9年11个月前 IP:广西
752006
没钱只能看看路过
x6x
9年11个月前 IP:北京
752008
随着智能仪器的普及,更加先进的电脑和传感器将使得各种仪器的功能产生质的飞越。
smith
9年11个月前 IP:广东
755166
这个项目现在的进入如何了,有开发套件了吗。
看这个套件全部搞下来,起码要5000刀以上了吧
diodes_1
9年11个月前 IP:山东
755669
看上去很牛B的样子~~~~~
hambaby
9年8个月前 IP:北京
769222
SUN SDR2
规格:
General coverage receiver in HF, MHz0.09...65
General coverage receiver in VHF, MHz95...148
Frequency coverage in HF in TX mode, MHzAll amateur frequencies
Frequency coverage in VHF in TX mode, MHz144...148
Sensitivity, uV0,07
Maximum transmitter's output power in HF, W20
Maximum transmitter's output power in VHF, W8
Blocking dynamic range in HF mode (BDR), dB120
Blocking dynamic range in VHF mode (BDR), dB>114
RF ADC clock frequency, MHz160
RF ADC resolution, bit16
RF DAC clock frequency, MHz640
RF DAC resolution, bit14
Recommended power supply, V15
Supply voltage range, V12...16
Local oscillator's stability, ppm+/- 0.5
Maximum consumption current, А5
Built-in audio codec resolution, bit24
ALC input voltage range, V0..4
Dimensions, mm165х165х35
Operating temperature, Celsius degree0...+70
Weight, kg1
国内已经有代理了,已经卖出去一台了。
专家 进士 学者 机友 笔友
2005/08/24注册,13分31秒前活动
刘 虎
创新工程局主席
认证方式:身份证号
