俄罗斯新款SDR电台即将发布,先睹为快
虎哥2014/06/19无线电 IP:辽宁
这是一个开放参与的项目(但没有完全开源)。这种项目组织方式+牛逼的技术背景,产生了优秀的产品。该机构架为前级+SDR收发机+PC机构架(据说是I7的电脑),售价约3K欧元,低于目前同类产品。传统厂商有些招架不住啊。
本文转自该项目的论坛:XXXXXXXXXXXXXXXXXXXXX
Besides transceiver features:
In the one box we have: Full PC(Mini ITX, Intel Core i7 CPU, full blown Windows 7 or Linux), 7" display, touch panel, with all the attendant features.
1. Installing digital communications software.
2. Contest loggers, magazines.
3. Internet browsing, internet clusters and other opportunities (e-mail,Skype, ICQ, TV... ) associated with internet.
4. Viewing and listening audio files.
5. Watching TV via USB-TV receivers.
6. And a lot of others, everything just limited by your fantasy.
In the first model of SunSDR-MB1 will be the next features:
Software: ExpertSDR2 (own software)
Supported OS: Windows All versions, Linux, in future MAC OS.
Direct conversion in RX/TX mode, in HF/VHF bands
Frequency range 0-75MHz, 95-155MHz
Wide band spectrum panadapter up to 80MHz
Two independent receivers
Full duplex mode (depends on software, will available in a new versions of software)
High dynamic range of receiver: up to 120dB in the HF, and up to 116dB in the VHF.
Sensitivity, uV: 0.07(Preamp on)/0.13(Preamp off)
Output power: 125W(HF), 60W(VHF)
IMD3 DR of transmitter, -35dB...-30dB (can be improved by software up to -60dB)
Predistortion of TX signal: will available later(depends on software)
ATU: Available as option.
Reference 10 MHz input
Very small CW delay: 10ms
ADC sample rate: 160MHz
ADC resolution: 16 bit
IMD3 DR, in-band: 100 dB
DUC sample rate: 640MHz
DUC resolution: 14 bit
High perfomance 24 bit Codec on board
Power supply: AC 110...220V 50...60Hz, 1A(RX)/2A(TX)
Weight: 9 Kg
Inputs/outputs:
VHF antenna connector(SO239)
Two HF antenna connectors(SO239)
Wide RF input port direct connect to high speed ADC(SMA)(for XVTRX, measurement etc.)
Wide RF output port direct connect to DUC(SMA)(for XVTRX, measurement etc.)
Reference 10MHz input connector(SMA)
ALC input port(RCA)
PTT input port(JACK 6.3mm)
CW Key input port(JACK 6.3mm)
External Control port with 8 power switch and RS-485 interface(D-SUB-15)
External control 2 port for Stealth Antenna 9310.
PTT output ports for external PA control(RCA x4).
Electret Microphone input(line in)(JACK 6.3mm)
Dynamic Microphone input with PTT switch for MH-31(RJ-45)
Headphones output(line)(JACK 6.3mm)
Ethernet connector(RJ-45) for LAN.
USB 3.0 connectors (x4 + x2 on front panel).
Speaker/headphones connector from embedded PC's sound card(3.5 mm Jack).
Microphone connector from embedded PC's sound card(3.5 mm Jack).
Display port connector.
HDMI connector.
Power supply connector.
Ground connector.
Special for SunSDR-MB1 will be developed an ExpertSDR2 software version with adapted GUI.
Features of the software is very big. You can find it in user manual which will be released in end of this month.
Approximately price on first model SunSDR-MB1 in base variant: 150 000 RUB ~ 4300 USD, + option ATU 6000 RUB ~ 200 USD
Exact price will be known after finishing all works with the first preserial model, which you seen in video(a small part - front panel).
Also may be will be started a special offer with prepayment with discount ~20% for first buyers... will seen after HAM Radio 2014 at Friederichshafen in Germany.
Approximately date of starting sales - end of autumn.
The picture with back panel has some difference with the first serial model of SunSDR-MB1 transceiver.
At the present time we are working on new GUI for SunSDR-MB1. Usual an ExpertSDR2 GUI was changed to special GUI for monoblock. Half way already passed. Next step it is increasing a fonts on the frequency scale between spectrum and waterfall, and increasing fonts on PWR-meter, SWR-meter and MIC-meter. Touch panel installed on high resolution IPS 7" display, and gives to user possibility to choose any function or to set any frequency in one touch.
On next week I'll publish a new photo with a fully assembled SunSDR-MB1 and finished GUI. SunSDR_MB1_GUI.jpg
Today was the first start of GUI for SunSDR-MB1.
老版本的框图
原型机
来自:电子信息 / 无线电
29
虎哥 作者
10年6个月前 IP:未同步
696532
160M,16bit采样,这个硬件选择有些变态,按这个条件应该可以做到全直采,灵活度非常高。
专家 进士 学者 机友 笔友
2005/08/24注册,16秒前活动
刘 虎
创新工程局主席
认证方式:身份证号
