我来发两篇英文的冷核聚变论文
orichalcum2010/08/14电气电工 IP:辽宁
拍砖前请先阅读论文。
作者:
Yoshiaki Arata and Yue Chang Zhang
Cooperation Research Center for Science and Technology, Osaka University
2-1, Yamadaoka, Suita, Osaka, 565-0871, Japan
第一篇:Development of Compact Nuclear Fusion Reactor Using Solid Pycnodeuterium as Nuclear Fuel(使用固态聚合氘作为核反应燃料的小型核聚变反应器的发展)
简介:
基于钯黑在DS电极产生无可辩驳的固态核聚变的证据的功能,开发新材料来吸收充足的D/H原子,最高到300%的钯原子数目。这些吸收的原子固态化紧凑地处于每个宿主晶格里成为“聚合氕”或者“聚合氢”。给聚合氘激发能量就会很容易地引发固态核聚变,而聚合氕没有发生反应。结论是,很显然聚合氘与其他核燃料相比是最好的核燃料。
Based on the functioning of Pd black inside a DS-Cathode, which has produced irrefutable evidence for the existence of solid nuclear fusion, new materials were developed to absorb abundant D/H atoms, up to levels as high as 300% of Pd number. These absorbed atoms were solidified densely inside each unit cell of the host lattice as solid-state “Pycnodeuterium” or “Pycnohydrogen.” Stimulation energy with Pycnodeuterium easily caused intense solid-state nuclear fusion, whereas with Pycnohydrogen no reaction occurred. As the result, it was clarified that Pycnodeuterium is by far the best nuclear fuel compared to all other nuclear fuels.
下载地址:
attachment icon ArataYdevelopmena.pdf 1.62MB PDF 84次下载 预览
第二篇:A New Energy caused by “Spillover-Deuterium”
简介:
已经确认一种新的、由“溢出氘”在双结构(DS)电极中与钯黑作用产生的能力。使用这种电极作者确认了一种明显而持续几个月的能量,是不能被认为化学反应能量的。使用0.1mol钯黑的化学反应能量只有4kJ,但是超过200MJ的释放能量以大约50-100kJ每小时在超过3000小时内持续释放。使用这种装置在两年来间歇实验证明了这些结果完全具有可重复性。
It was verified that a new kind of energy is caused by “Spillover-Deuterium” generated in a double structure (DS)-cathode with “Pd-black”. Using this cathode, the authors confirmed the sustained production of a significantly abnormal amount of energy over a period of several months that could not be ascribed to chemical reaction energy. The chemical reaction energy of 0.1 [mol] Pd-black used is only 4[kJ], but more than 200[MJ] of excess energy was continuously produced for over 3000 [hr] at an average rate of 50-100 [kJ/hr] using a DS-cathode with a same quantity of Pd-black. Intermittent operation over a period of two years using this structure proved the complete reproducibility of these results.
下载地址:
attachment icon ArataYanewenergya.pdf 640.70KB PDF 85次下载 预览
来自:电气工程 / 电气电工
a452520569
14年11个月前 IP:未同步
248558
虽然看不懂,绝对顶起
托尼史塔克
14年10个月前 IP:未同步
251652
很不错哈哈哈!!!
托尼史塔克
14年10个月前 IP:未同步
251653
有没有人关注这个的?貌似大家都觉得它不可行
托尼史塔克
14年10个月前 IP:未同步
251654
恩……第一篇我以前看过了……
maya2012
14年8个月前 IP:未同步
263780
这个东西不提高电压,不改进电极结构根本没得玩
orichalcum
2009/06/15注册,7年4个月前活动
认证方式:未同步
