Open Source |
accountsservice query and manipulate user account information <br>acl Access control list utilities acpidAdvanced Configuration and Power Interface event daemon adduseradd and remove users and groups adwaita-icon-themedefault icon theme of GNOME (small subset) amd64-microcodeProcessor microcode firmware for AMD CPUs apparmoruser-space parser utility for AppArmor apportautomatically generate crash reports for debugging apport-symptomssymptom scripts for apport aptcommandline package manager apt-transport-httpshttps download transport for APT apt-utilspackage management related utility programs aspell-enEnglish dictionary for GNU Aspell atDelayed job execution and batch processing at-spi2-coreAssistive Technology Service Provider Interface (dbus core) attrUtilities for manipulating filesystem extended attributes authbindAllows non-root programs to bind() to low ports avahi-autoipdAvahi IPv4LL network address configuration daemon avahi-daemonAvahi mDNS/DNS-SD daemon base-filesDebian base system miscellaneous files base-passwdDebian base system master password and group files bashGNU Bourne Again SHell bash-completionprogrammable completion for the bash shell bcGNU bc arbitrary precision calculator language bcache-toolsbcache userspace tools bind9-hostVersion of 'host' bundled with BIND 9.X binutilsGNU assembler, linker and binary utilities bsdmainutilscollection of more utilities from FreeBSD bsdutilsbasic utilities from 4.4BSD-Lite btrfs-toolsChecksumming Copy on Write Filesystem utilities build-essentialInformational list of build-essential packages busybox-initramfsStandalone shell setup for initramfs busybox-staticStandalone rescue shell with tons of builtin utilities byobutext window manager, shell multiplexer, integrated DevOps environment bzip2high-quality block-sorting file compressor - utilities ca-certificatesCommon CA certificates ca-certificates-javaCommon CA certificates (JKS keystore) cifs-utilsCommon Internet File System utilities cloud-guest-utilscloud guest utilities cloud-initramfs-copymodscopy initramfs modules into root filesystem for later use cloud-initramfs-dyn-netconfwrite a network interface file in /run for BOOTIF colordsystem service to manage device colour profiles -- system daemon colord-datasystem service to manage device colour profiles -- data files command-not-foundSuggest installation of packages in interactive bash sessions command-not-found-dataSet of data files for command-not-found. console-setupconsole font and keymap setup program console-setup-linuxLinux specific part of console-setup coreutilsGNU core utilities cpioGNU cpio -- a program to manage archives of files cppGNU C preprocessor (cpp) cpp-5GNU C preprocessor crdawireless Central Regulatory Domain Agent cronprocess scheduling daemon cryptsetupdisk encryption support - startup scripts cryptsetup-bindisk encryption support - command line tools curlcommand line tool for transferring data with URL syntax dashPOSIX-compliant shell dbussimple interprocess messaging system (daemon and utilities) dbus-x11simple interprocess messaging system (X11 deps) dconf-gsettings-backendsimple configuration storage system - GSettings back-end dconf-servicesimple configuration storage system - D-Bus service debconfDebian configuration management system debconf-i18nfull internationalization support for debconf debianutilsMiscellaneous utilities specific to Debian default-jre-headlessStandard Java or Java compatible Runtime (headless) dh-pythonDebian helper tools for packaging Python libraries and applications dictionaries-commonspelling dictionaries - common utilities diffutilsFile comparison utilities distro-info-datainformation about the distributions' releases (data files) dkmsDynamic Kernel Module Support Framework dmeventdLinux Kernel Device Mapper event daemon dmidecodeSMBIOS/DMI table decoder dmsetupLinux Kernel Device Mapper userspace library dns-root-dataDNS root data including root zone and DNSSEC key dnsmasq-baseSmall caching DNS proxy and DHCP/TFTP server dnsutilsClients provided with BIND dosfstoolsutilities for making and checking MS-DOS FAT filesystems dpkgDebian package management system dpkg-devDebian package development tools e2fslibsext2/ext3/ext4 file system libraries e2fsprogsext2/ext3/ext4 file system utilities edclassic UNIX line editor efibootmgrInteract with the EFI Boot Manager ejectejects CDs and operates CD-Changers under Linux emacsen-commonCommon facilities for all emacsen ethtooldisplay or change Ethernet device settings exfat-fuseread and write exFAT driver for FUSE exfat-utilsutilities to create, check, label and dump exFAT filesystem expectAutomates interactive applications fakeroottool for simulating superuser privileges fbiLinux frame buffer image viewer fehimlib2 based image viewer fileDetermines file type using "magic" numbers findutilsutilities for finding files--find, xargs flexfast lexical analyzer generator fontconfiggeneric font configuration library - support binaries fontconfig-configgeneric font configuration library - configuration fonts-dejavu-coreVera font family derivate with additional characters fonts-ubuntu-font-family-consoUbuntu Font Family Linux console fonts, sans-serif monospace friendly-recoveryMake recovery more user-friendly ftpclassical file transfer client fuseFilesystem in Userspace g++GNU C++ compiler g++-5GNU C++ compiler gawkGNU awk, a pattern scanning and processing language gccGNU C compiler gcc-5GNU C compiler gcc-5-baseGCC, the GNU Compiler Collection (base package) gcc-6-baseGCC, the GNU Compiler Collection (base package) gcc-7-baseGCC, the GNU Compiler Collection (base package) gcc-8-baseGCC, the GNU Compiler Collection (base package) gcc-9-baseGCC, the GNU Compiler Collection (base package) gcrGNOME crypto services (daemon and tools) gdbGNU Debugger gdbserverGNU Debugger (remote server) gdiskGPT fdisk text-mode partitioning tool geoip-databaseIP lookup command line tools that use the GeoIP library (country database) gettextGNU Internationalization utilities gettext-baseGNU Internationalization utilities for the base system ghostscriptinterpreter for the PostScript language and for PDF gir1.2-glib-2.0Introspection data for GLib, GObject, Gio and GModule gitfast, scalable, distributed revision control system git-manfast, scalable, distributed revision control system (manual pages) glib-networkingnetwork-related giomodules for GLib glib-networking-commonnetwork-related giomodules for GLib - data files glib-networking-servicesnetwork-related giomodules for GLib - D-Bus services gnome-keyringGNOME keyring services (daemon and tools) gnupgGNU privacy guard - a free PGP replacement gpgvGNU privacy guard - signature verification tool grepGNU grep, egrep and fgrep groff-baseGNU troff text-formatting system (base system components) grub-commonGRand Unified Bootloader (common files) grub-efi-amd64GRand Unified Bootloader, version 2 (EFI-AMD64 version) grub-efi-amd64-binGRand Unified Bootloader, version 2 (EFI-AMD64 binaries) grub-efi-amd64-signedGRand Unified Bootloader, version 2 (EFI-AMD64 version, signed) grub-legacy-ec2Handles update-grub for ec2 instances grub2-commonGRand Unified Bootloader (common files for version 2) gsettings-desktop-schemasGSettings desktop-wide schemas gsfontsFonts for the Ghostscript interpreter(s) gstreamer1.0-plugins-baseGStreamer plugins from the "base" set gstreamer1.0-plugins-goodGStreamer plugins from the "good" set gstreamer1.0-xGStreamer plugins for X11 and Pango guacamoleHTML5 web application for accessing remote desktops guacdGuacamole proxy daemon gzipGNU compression utilities hdparmtune hard disk parameters for high performance hicolor-icon-themedefault fallback theme for XXXXXXXXXXXXXXX icon themes hostnameutility to set/show the host name or domain name humanity-icon-themeHumanity Icon theme icu-devtoolsDevelopment utilities for International Components for Unicode ifenslaveconfigure network interfaces for parallel routing (bonding) ifupdownhigh level tools to configure network interfaces indicator-applicationApplication Indicators infoStandalone GNU Info documentation browser initSystem-V-like init utilities - metapackage init-system-helpershelper tools for all init systems initramfs-toolsgeneric modular initramfs generator (automation) initramfs-tools-binbinaries used by initramfs-tools initramfs-tools-coregeneric modular initramfs generator (core tools) initscriptsscripts for initializing and shutting down the system insservboot sequence organizer using LSB init.d script dependency information install-infoManage installed documentation in info format installation-reportsystem installation report intel-microcodeProcessor microcode firmware for Intel CPUs iproute2networking and traffic control tools iptablesadministration tools for packet filtering and NAT iputils-arpingTool to send ICMP echo requests to an ARP address iputils-pingTools to test the reachability of network hosts iputils-tracepathTools to trace the network path to a remote host irqbalanceDaemon to balance interrupts for SMP systems isc-dhcp-clientDHCP client for automatically obtaining an IP address isc-dhcp-commoncommon files used by all of the isc-dhcp packages iso-codesISO language, territory, currency, script codes and their translations iucode-toolIntel processor microcode tool iwtool for configuring Linux wireless devices java-commonBase package for Java runtimes jemallocTek jemalloc 5.2 kbdLinux console font and keytable utilities keyboard-configurationsystem-wide keyboard preferences keyutilsLinux Key Management Utilities klibc-utilssmall utilities built with klibc for early boot kmodtools for managing Linux kernel modules krb5-localesInternationalization support for MIT Kerberos language-pack-entranslation updates for language English language-pack-en-basetranslations for language English language-selector-commonLanguage selector for Ubuntu laptop-detectattempt to detect a laptop lesspager program similar to more libaa1ASCII art library libaccountsservice0query and manipulate user account information - shared libraries libacl1Access control list shared library libaio1Linux kernel AIO access library - shared library libalgorithm-diff-perlmodule to find differences between files libalgorithm-diff-xs-perlmodule to find differences between files (XS accelerated) libalgorithm-merge-perlPerl module for three-way merge of textual data libapparmor-perlAppArmor library Perl bindings libapparmor1changehat AppArmor library libappindicator3-1Application Indicators libapt-inst2.0deb package format runtime library libapt-pkg5.0package management runtime library libasan2AddressSanitizer -- a fast memory error detector libasan4AddressSanitizer -- a fast memory error detector libasn1-8-heimdalHeimdal Kerberos - ASN.1 library libasound2shared library for ALSA applications libasound2-dataConfiguration files and profiles for ALSA drivers libaspell15GNU Aspell spell-checker runtime library libasprintf-devGNU Internationalization library development files libasprintf0v5GNU library to use fprintf and friends in C++ libassuan0IPC library for the GnuPG components libasyncns0Asynchronous name service query library libatk-bridge2.0-0AT-SPI 2 toolkit bridge - shared library libatk1.0-0ATK accessibility toolkit libatk1.0-dataCommon files for the ATK accessibility toolkit libatm1shared library for ATM (Asynchronous Transfer Mode) libatomic1support library providing __atomic built-in functions libatspi2.0-0Assistive Technology Service Provider Interface - shared library libattr1Extended attribute shared library libaudit-commonDynamic library for security auditing - common files libaudit1Dynamic library for security auditing libavahi-client3Avahi client library libavahi-common-dataAvahi common data files libavahi-common3Avahi common library libavahi-core7Avahi's embeddable mDNS/DNS-SD library libavc1394-0control IEEE 1394 audio/video devices libbabeltrace-ctf1Common Trace Format (CTF) library libbabeltrace1Babeltrace conversion libraries libbind9-140BIND9 Shared Library used by BIND libblkid1block device ID library libbluetooth3Library to use the BlueZ Linux Bluetooth stack libboost-filesystem1.58.0filesystem operations (portable paths, iteration over directories, etc) in C++ libboost-system1.58.0Operating system (e.g. diagnostics support) library libbsd0utility functions from BSD systems - shared library libbz2-1.0high-quality block-sorting file compressor library - runtime libc-binGNU C Library: Binaries libc-dev-binGNU C Library: Development binaries libc6GNU C Library: Shared libraries libc6-dbgGNU C Library: detached debugging symbols libc6-devGNU C Library: Development Libraries and Header Files libcaca0colour ASCII art library libcairo-gobject2Cairo 2D vector graphics library (GObject library) libcairo-script-interpreter2Cairo 2D vector graphics library (script interpreter) libcairo2Cairo 2D vector graphics library libcap-ng0An alternate POSIX capabilities library libcap2POSIX 1003.1e capabilities (library) libcap2-binPOSIX 1003.1e capabilities (utilities) libcapnp-0.5.3Cap'n Proto C++ library libcc1-0GCC cc1 plugin for GDB libcdparanoia0audio extraction tool for sampling CDs (library) libcilkrts5Intel Cilk Plus language extensions (runtime) libcolord2system service to manage device colour profiles -- runtime libcolorhug2library to access the ColorHug colourimeter -- runtime libcomerr2common error description library libcommons-collections3-javaApache Commons Collections - Extended Collections API for Java libcommons-dbcp-javaDatabase Connection Pooling Services libcommons-pool-javapooling implementation for Java objects libcroco3Cascading Style Sheet (CSS) parsing and manipulation toolkit libcrypto++-devGeneral purpose cryptographic library - C++ development libcrypto++9v5General purpose cryptographic library - shared library libcryptsetup4disk encryption support - shared library libcups2Common UNIX Printing System(tm) - Core library libcupsfilters1OpenPrinting CUPS Filters - Shared library libcupsimage2Common UNIX Printing System(tm) - Raster image library libcurl3easy-to-use client-side URL transfer library (OpenSSL flavour) libcurl3-gnutlseasy-to-use client-side URL transfer library (GnuTLS flavour) libdaemon0lightweight C library for daemons - runtime library libdatrie1Double-array trie library libdb5.3Berkeley v5.3 Database Libraries [runtime] libdbus-1-3simple interprocess messaging system (library) libdbus-glib-1-2simple interprocess messaging system (GLib-based shared library) libdbusmenu-glib4library for passing menus over DBus libdbusmenu-gtk3-4library for passing menus over DBus - GTK+ version libdconf1simple configuration storage system - runtime library libdebconfclient0Debian Configuration Management System (C-implementation library) libdevmapper-event1.02.1Linux Kernel Device Mapper event support library libdevmapper1.02.1Linux Kernel Device Mapper userspace library libdns-export162Exported DNS Shared Library libdns162DNS Shared Library used by BIND libdouble-conversion1v5routines to convert IEEE floats to and from strings libdpkg-perlDpkg perl modules libdrm-amdgpu1Userspace interface to amdgpu-specific kernel DRM services -- runtime libdrm-commonUserspace interface to kernel DRM services -- common files libdrm-devUserspace interface to kernel DRM services -- development files libdrm-intel1Userspace interface to intel-specific kernel DRM services -- runtime libdrm-nouveau2Userspace interface to nouveau-specific kernel DRM services -- runtime libdrm-radeon1Userspace interface to radeon-specific kernel DRM services -- runtime libdrm2Userspace interface to kernel DRM services -- runtime libdumbnet1dumb, portable networking library -- shared library libdv4software library for DV format digital video (runtime lib) libecj-javaEclipse Java compiler (library) libedit2BSD editline and history libraries libefivar0Library to manage UEFI variables libegl1-mesafree implementation of the EGL API -- runtime libelf1library to read and write ELF files libepoxy0OpenGL function pointer management library liberror-perlPerl module for error/exception handling in an OO-ish way libestr0Helper functions for handling strings (lib) libevdev2wrapper library for evdev devices libevent-2.0-5Asynchronous event notification library libexif12library to parse EXIF files libexpat1XML parsing C library - runtime library libexpat1-devXML parsing C library - development kit libfakeroottool for simulating superuser privileges - shared libraries libfdisk1fdisk partitioning library libffi6Foreign Function Interface library runtime libfftw3-binLibrary for computing Fast Fourier Transforms - Tools libfftw3-devLibrary for computing Fast Fourier Transforms - development libfftw3-double3Library for computing Fast Fourier Transforms - Double precision libfftw3-long3Library for computing Fast Fourier Transforms - Long precision libfftw3-quad3Library for computing Fast Fourier Transforms - Quad precision libfftw3-single3Library for computing Fast Fourier Transforms - Single precision libfile-copy-recursive-perlPerl extension for recursively copying files and directories libfile-fcntllock-perlPerl module for file locking with fcntl(2) libfl-devstatic library for flex (a fast lexical analyzer generator) libflac8Free Lossless Audio Codec - runtime C library libfontconfig1generic font configuration library - runtime libfontenc1X11 font encoding library libfreetype6FreeType 2 font engine, shared library files libfribidi0Free Implementation of the Unicode BiDi algorithm libfuse2Filesystem in Userspace (library) libgbm1generic buffer management API -- runtime libgcc-5-devGCC support library (development files) libgcc-7-devGCC support library (development files) libgcc1GCC support library libgck-1-0Glib wrapper library for PKCS#11 - runtime libgcr-3-commonLibrary for Crypto UI related tasks - common files libgcr-base-3-1Library for Crypto related tasks libgcr-ui-3-1Library for Crypto UI related tasks libgcrypt20LGPL Crypto library - runtime library libgd3GD Graphics Library libgdbm3GNU dbm database routines (runtime version) libgdk-pixbuf2.0-0GDK Pixbuf library libgdk-pixbuf2.0-commonGDK Pixbuf library - data files libgeoip1non-DNS IP-to-country resolver library libgettextpo-devGNU Internationalization library development files libgettextpo0GNU Internationalization library libgif7library for GIF images (library) libgirepository-1.0-1Library for handling GObject introspection data (runtime library) libgl1-mesa-drifree implementation of the OpenGL API -- DRI modules libgl1-mesa-glxfree implementation of the OpenGL API -- GLX runtime libglapi-mesafree implementation of the GL API -- shared library libglib2.0-0GLib library of C routines libglib2.0-binPrograms for the GLib library libglib2.0-dataCommon files for GLib library libglib2.0-devDevelopment files for the GLib library libgmp-devMultiprecision arithmetic library developers tools libgmp10Multiprecision arithmetic library libgmpxx4ldblMultiprecision arithmetic library (C++ bindings) libgnutls-devGNU TLS library - development files libgnutls-openssl27GNU TLS library - OpenSSL wrapper libgnutls28-devdummy transitional package for GNU TLS library - development files libgnutls30GNU TLS library - main runtime library libgnutlsxx28GNU TLS library - C++ runtime library libgomp1GCC OpenMP (GOMP) support library libgpg-error0library for common error values and messages in GnuPG components libgphoto2-6gphoto2 digital camera library libgphoto2-l10ngphoto2 digital camera library - localized messages libgphoto2-port12gphoto2 digital camera port library libgpm2General Purpose Mouse - shared library libgraphite2-3Font rendering engine for Complex Scripts -- library libgs9interpreter for the PostScript language and for PDF - Library libgs9-commoninterpreter for the PostScript language and for PDF - common files libgssapi-krb5-2MIT Kerberos runtime libraries - krb5 GSS-API Mechanism libgssapi3-heimdalHeimdal Kerberos - GSSAPI support library libgstreamer-plugins-base1.0-0GStreamer libraries from the "base" set libgstreamer-plugins-good1.0-0GStreamer development files for libraries from the "good" set libgstreamer1.0-0Core GStreamer libraries and elements libgtk-3-0GTK+ graphical user interface library libgtk-3-binprograms for the GTK+ graphical user interface library libgtk-3-commoncommon files for the GTK+ graphical user interface library libgtk2.0-0GTK+ graphical user interface library libgtk2.0-binprograms for the GTK+ graphical user interface library libgtk2.0-commoncommon files for the GTK+ graphical user interface library libguac-client-vnc0VNC support plugin for Guacamole libguac5Core Guacamole library used by guacd and client plugins libgudev-1.0-0GObject-based wrapper library for libudev libgusb2GLib wrapper around libusb1 libharfbuzz-icu0OpenType text shaping engine ICU backend libharfbuzz0bOpenType text shaping engine (shared library) libhcrypto4-heimdalHeimdal Kerberos - crypto library libheimbase1-heimdalHeimdal Kerberos - Base library libheimntlm0-heimdalHeimdal Kerberos - NTLM support library libhogweed4low level cryptographic library (public-key cryptos) libhunspell-1.3-0spell checker and morphological analyzer (shared library) libhx509-5-heimdalHeimdal Kerberos - X509 support library libhyphen0ALTLinux hyphenation library - shared library libice-devX11 Inter-Client Exchange library (development headers) libice6X11 Inter-Client Exchange library libicu55International Components for Unicode libid3tag0ID3 tag reading library from the MAD project libidn11GNU Libidn library, implementation of IETF IDN specifications libidn11-devDevelopment files for GNU Libidn, an IDN library libiec61883-0an partial implementation of IEC 61883 libieee1284-3cross-platform library for parallel port access libijs-0.35IJS raster image transport protocol: shared library libimlib2image loading, rendering, saving library libindicator3-7panel indicator applet - shared library libinput-bininput device management and event handling library - udev quirks libinput10input device management and event handling library - shared library libisc-export160Exported ISC Shared Library libisc160ISC Shared Library used by BIND libisccc140Command Channel Library used by BIND libisccfg140Config File Handling Library used by BIND libisl15manipulating sets and relations of integer points bounded by linear constraints libitm1GNU Transactional Memory Library libjack-jackd2-0JACK Audio Connection Kit (libraries) libjavascriptcoregtk-4.0-18JavaScript engine library from WebKitGTK+ libjbig0JBIGkit libraries libjbig2dec0JBIG2 decoder library - shared libraries libjpeg-devIndependent JPEG Group's JPEG runtime library (dependency package) libjpeg-progsPrograms for manipulating JPEG files libjpeg-turbo8IJG JPEG compliant runtime library. libjpeg-turbo8-devDevelopment files for the IJG JPEG library libjpeg8Independent JPEG Group's JPEG runtime library (dependency package) libjpeg8-devIndependent JPEG Group's JPEG runtime library (dependency package) libjpeg9Independent JPEG Group's JPEG runtime library libjson-c2JSON manipulation library - shared library libjson-glib-1.0-0GLib JSON manipulation library libjson-glib-1.0-commonGLib JSON manipulation library (common files) libk5crypto3MIT Kerberos runtime libraries - Crypto Library libkeyutils1Linux Key Management Utilities (library) libklibcminimal libc subset for use with initramfs libkmod2libkmod shared library libkrb5-26-heimdalHeimdal Kerberos - libraries libkrb5-3MIT Kerberos runtime libraries libkrb5support0MIT Kerberos runtime libraries - Support library liblcms2-2Little CMS 2 color management library libldap-2.4-2OpenLDAP libraries libldb1LDAP-like embedded database - shared library libllvm6.0Modular compiler and toolchain technologies, runtime library liblocale-gettext-perlmodule using libc functions for internationalization in Perl liblsan0LeakSanitizer -- a memory leak detector (runtime) libltdl7System independent dlopen wrapper for GNU libtool liblvm2app2.2LVM2 application library liblvm2cmd2.02LVM2 command library liblwres141Lightweight Resolver Library used by BIND liblxc1Linux Containers userspace tools (library) liblz4-1Fast LZ compression algorithm library - runtime liblzma5XZ-format compression library liblzo2-2data compression library libmagic1File type determination library using "magic" numbers libmbim-glib4Support library to use the MBIM protocol libmbim-proxyProxy to communicate with MBIM ports libmirclient9Display server for Ubuntu - client library libmircommon7Display server for Ubuntu - shared library libmircore1Display server for Ubuntu - shared library libmirprotobuf3Display server for Ubuntu - RPC definitions libmm-glib0D-Bus service for managing modems - shared libraries libmnl0minimalistic Netlink communication library libmount1device mounting library libmpc3multiple precision complex floating-point library libmpdec2library for decimal floating point arithmetic (runtime library) libmpfr4multiple precision floating-point computation libmpx0Intel memory protection extensions (runtime) libmpx2Intel memory protection extensions (runtime) libmspack0library for Microsoft compression formats (shared library) libmtdev1Multitouch Protocol Translation Library - shared library libncurses5shared libraries for terminal handling libncursesw5shared libraries for terminal handling (wide character support) libndp0Library for Neighbor Discovery Protocol libnetfilter-conntrack3Netfilter netlink-conntrack library libnettle6low level cryptographic library (symmetric and one-way cryptos) libnewt0.52Not Erik's Windowing Toolkit - text mode windowing with slang libnfnetlink0Netfilter netlink library libnfsidmap2NFS idmapping library libnih1NIH Utility Library libnl-3-200library for dealing with netlink sockets libnl-genl-3-200library for dealing with netlink sockets - generic netlink libnm0GObject-based client library for NetworkManager libnma-commonlibrary for wireless and mobile dialogs - common files libnma0library for wireless and mobile dialogs (libnm version) libnotify4sends desktop notifications to a notification daemon libnspr4NetScape Portable Runtime Library libnss-mdnsNSS module for Multicast DNS name resolution libnss3Network Security Service libraries libnss3-nssdbNetwork Security Security libraries - shared databases libnuma1Libraries for controlling NUMA policy libogg0Ogg bitstream library libopts25automated option processing library based on autogen libopus0Opus codec runtime library liborc-0.4-0Library of Optimized Inner Loops Runtime Compiler libossp-uuid-devOSSP uuid ISO-C and C++ - headers and static libraries libossp-uuid16OSSP uuid ISO-C and C++ - shared library libp11-kit-devlibrary for loading and coordinating access to PKCS#11 modules - development libp11-kit-gnome-keyringGNOME keyring module for the PKCS#11 module loading library libp11-kit0library for loading and coordinating access to PKCS#11 modules - runtime libpam-gnome-keyringPAM module to unlock the GNOME keyring upon login libpam-modulesPluggable Authentication Modules for PAM libpam-modules-binPluggable Authentication Modules for PAM - helper binaries libpam-runtimeRuntime support for the PAM library libpam-systemdsystem and service manager - PAM module libpam0gPluggable Authentication Modules library libpango-1.0-0Layout and rendering of internationalized text libpangocairo-1.0-0Layout and rendering of internationalized text libpangoft2-1.0-0Layout and rendering of internationalized text libpaper1library for handling paper characteristics libparted2disk partition manipulator - shared library libpcap0.8system interface for user-level packet capture libpci3Linux PCI Utilities (shared library) libpciaccess0Generic PCI access library for X libpcre16-3Perl 5 Compatible Regular Expression Library - 16 bit runtime files libpcre3Perl 5 Compatible Regular Expression Library - runtime files libpcre3-devPerl 5 Compatible Regular Expression Library - development files libpcre32-3Perl 5 Compatible Regular Expression Library - 32 bit runtime files libpcrecpp0v5Perl 5 Compatible Regular Expression Library - C++ runtime files libpcsclite1Middleware to access a smart card using PC/SC (library) libperl5.22shared Perl library libpipeline1pipeline manipulation library libpixman-1-0pixel-manipulation library for X and cairo libpixman-1-devpixel-manipulation library for X and cairo (development files) libplymouth4graphical boot animation and logger - shared libraries libpng12-0PNG library - runtime libpolkit-agent-1-0PolicyKit Authentication Agent API libpolkit-backend-1-0PolicyKit backend API libpolkit-gobject-1-0PolicyKit Authorization API libpopt0lib for parsing cmdline parameters libprocps4library for accessing process information from /proc libprotobuf-lite9v5protocol buffers C++ library (lite version) libproxy1v5automatic proxy configuration management library (shared) libpthread-stubs0-devpthread stubs not provided by native libc, development files libpulse0PulseAudio client libraries libpython-stdlibinteractive high-level object-oriented language (default python version) libpython2.7Shared Python runtime library (version 2.7) libpython2.7-devHeader files and a static library for Python (v2.7) libpython2.7-minimalMinimal subset of the Python language (version 2.7) libpython2.7-stdlibInteractive high-level object-oriented language (standard library, version 2.7) libpython3-stdlibinteractive high-level object-oriented language (default python3 version) libpython3.5Shared Python runtime library (version 3.5) libpython3.5-minimalMinimal subset of the Python language (version 3.5) libpython3.5-stdlibInteractive high-level object-oriented language (standard library, version 3.5) libqmi-glib5Support library to use the Qualcomm MSM Interface (QMI) protocol libqmi-proxyProxy to communicate with QMI ports libqt5core5aQt 5 core module libqt5dbus5Qt 5 D-Bus module libqt5gui5Qt 5 GUI module libqt5network5Qt 5 network module libqt5opengl5Qt 5 OpenGL module libqt5printsupport5Qt 5 print support module libqt5qml5Qt 5 QML module libqt5quick5Qt 5 Quick library libqt5sql5Qt 5 SQL module libqt5sql5-sqliteQt 5 SQLite 3 database driver libqt5svg5Qt 5 SVG module libqt5webkit5Web content engine library for Qt libqt5widgets5Qt 5 widgets module libquadmath0GCC Quad-Precision Math Library libquazip-headersC++ wrapper for ZIP/UNZIP (development header files) libquazip5-1C++ wrapper wrapper for ZIP/UNZIP (Qt5 build) libquazip5-devC++ wrapper wrapper for ZIP/UNZIP (development files, Qt5 build) libraw1394-11library for direct access to IEEE 1394 bus (aka FireWire) libreadline5GNU readline and history libraries, run-time libraries libreadline6GNU readline and history libraries, run-time libraries librest-0.7-0REST service access library libroken18-heimdalHeimdal Kerberos - roken support library librsvg2-2SAX-based renderer library for SVG files (runtime) librsvg2-commonSAX-based renderer library for SVG files (extra runtime) librtmp1toolkit for RTMP streams (shared library) libsamplerate0Audio sample rate conversion library libsaneAPI library for scanners libsane-commonAPI library for scanners -- documentation and support files libsasl2-2Cyrus SASL - authentication abstraction library libsasl2-modulesCyrus SASL - pluggable authentication modules libsasl2-modules-dbCyrus SASL - pluggable authentication modules (DB) libseccomp2high level interface to Linux seccomp filter libsecret-1-0Secret store libsecret-commonSecret store (common files) libselinux1SELinux runtime shared libraries libsemanage-commonCommon files for SELinux policy management libraries libsemanage1SELinux policy management library libsensors4library to read temperature/voltage/fan sensors libsepol1SELinux library for manipulating binary security policies libservlet3.0-javaServlet 3.0 and JSP 2.2 Java API classes libshout3MP3/Ogg Vorbis broadcast streaming library libsigsegv2Library for handling page faults in a portable way libslang2S-Lang programming library - runtime version libsm-devX11 Session Management library (development headers) libsm6X11 Session Management library libsmartcols1smart column output alignment library libsndfile1Library for reading/writing audio files libsoup-gnome2.4-1HTTP library implementation in C -- GNOME support library libsoup2.4-1HTTP library implementation in C -- Shared library libspeex1The Speex codec runtime library libsqlite3-0SQLite 3 shared library libss2command-line interface parsing library libssl1.0.0Secure Sockets Layer toolkit - shared libraries libstartup-notification0library for program launch feedback (shared library) libstdc++-5-devGNU Standard C++ Library v3 (development files) libstdc++-7-devGNU Standard C++ Library v3 (development files) libstdc++6GNU Standard C++ Library v3 libsystemd0systemd utility library libtag1v5audio meta-data library libtag1v5-vanillaaudio meta-data library - vanilla flavour libtalloc2hierarchical pool based memory allocator libtasn1-6Manage ASN.1 structures (runtime) libtasn1-6-devManage ASN.1 structures (development) libtasn1-docManage ASN.1 structures (documentation) libtcl8.6Tcl (the Tool Command Language) v8.6 - run-time library files libtdb1Trivial Database - shared library libtevent0talloc-based event loop library - shared library libtext-charwidth-perlget display widths of characters on the terminal libtext-iconv-perlconverts between character sets in Perl libtext-wrapi18n-perlinternationalized substitute of Text::Wrap libthai-dataData files for Thai language support library libthai0Thai language support library libtheora0Theora Video Compression Codec libtiff5Tag Image File Format (TIFF) library libtinfo5shared low-level terminfo library for terminal handling libtirpc1transport-independent RPC library libtk8.6Tk toolkit for Tcl and X11 v8.6 - run-time files libtomcat7-javaServlet and JSP engine -- core libraries libtsan0ThreadSanitizer -- a Valgrind-based detector of data races (runtime) libtxc-dxtn-s2tc0Texture compression library for Mesa libubsan0UBSan -- undefined behaviour sanitizer (runtime) libudev1libudev shared library libunistring0Unicode string library for C libusb-0.1-4userspace USB programming library libusb-1.0-0userspace USB programming library libusb-1.0-0-devuserspace USB programming library development files libusb-1.0-docdocumentation for userspace USB programming libustr-1.0-1Micro string library: shared library libutempter0privileged helper for utmp/wtmp updates (runtime) libuuid1Universally Unique ID library libv4l-0Collection of video4linux support libraries libv4lconvert0Video4linux frame format conversion library libvisual-0.4-0audio visualization framework libvncclient1API to write one's own VNC server - client library libvncserver-configAPI to write one's own VNC server - library utility libvncserver-devAPI to write one's own VNC server - development files libvncserver1API to write one's own VNC server libvorbis0adecoder library for Vorbis General Audio Compression Codec libvorbisenc2encoder library for Vorbis General Audio Compression Codec libvpx3VP8 and VP9 video codec (shared library) libwacom-binWacom model feature query library -- binaries libwacom-commonWacom model feature query library (common files) libwacom2Wacom model feature query library libwavpack1audio codec (lossy and lossless) - library libwayland-client0wayland compositor infrastructure - client library libwayland-cursor0wayland compositor infrastructure - cursor library libwayland-egl1-mesaimplementation of the Wayland EGL platform -- runtime libwayland-server0wayland compositor infrastructure - server library libwbclient0Samba winbind client library libwebp5Lossy compression of digital photographic images. libwebpdemux1Lossy compression of digital photographic images. libwind0-heimdalHeimdal Kerberos - stringprep implementation libwnck-commonWindow Navigator Construction Kit - common files libwnck22Window Navigator Construction Kit - runtime files libwrap0Wietse Venema's TCP wrappers library libx11-6X11 client-side library libx11-dataX11 client-side library libx11-devX11 client-side library (development headers) libx11-docX11 client-side library (development documentation) libx11-xcb1Xlib/XCB interface library libxatracker2X acceleration library -- runtime libxau-devX11 authorisation library (development headers) libxau6X11 authorisation library libxaw7X11 Athena Widget library libxcb-dri2-0X C Binding, dri2 extension libxcb-dri3-0X C Binding, dri3 extension libxcb-glx0X C Binding, glx extension libxcb-icccm4utility libraries for X C Binding -- icccm libxcb-image0utility libraries for X C Binding -- image libxcb-keysyms1utility libraries for X C Binding -- keysyms libxcb-present0X C Binding, present extension libxcb-randr0X C Binding, randr extension libxcb-render-util0utility libraries for X C Binding -- render-util libxcb-render0X C Binding, render extension libxcb-render0-devX C Binding, render extension, development files libxcb-shape0X C Binding, shape extension libxcb-shm0X C Binding, shm extension libxcb-shm0-devX C Binding, shm extension, development files libxcb-sync1X C Binding, sync extension libxcb-util1utility libraries for X C Binding -- atom, aux and event libxcb-xfixes0X C Binding, xfixes extension libxcb-xinerama0X C Binding, xinerama extension libxcb-xkb1X C Binding, XKEYBOARD extension libxcb1X C Binding libxcb1-devX C Binding, development files libxcomposite1X11 Composite extension library libxcursor1X cursor management library libxdamage1X11 damaged region extension library libxdmcp-devX11 authorisation library (development headers) libxdmcp6X11 Display Manager Control Protocol library libxext-devX11 miscellaneous extensions library (development headers) libxext6X11 miscellaneous extension library libxfce4ui-1-0widget library for Xfce - Gtk+2 variant libxfce4ui-commoncommon files for libxfce4ui libxfce4util-bintools for libxfce4util libxfce4util-commoncommon files for libxfce4util libxfce4util7Utility functions library for Xfce4 libxfconf-0-2Client library for Xfce4 configure interface libxfixes-devX11 miscellaneous 'fixes' extension library (development headers) libxfixes3X11 miscellaneous 'fixes' extension library libxfont1X11 font rasterisation library libxfont2X11 font rasterisation library libxft2FreeType-based font drawing library for X libxi-devX11 Input extension library (development headers) libxi6X11 Input extension library libxinerama1X11 Xinerama extension library libxkbcommon-x11-0library to create keymaps with the XKB X11 protocol libxkbcommon0library interface to the XKB compiler - shared library libxkbfile1X11 keyboard file manipulation library libxml2GNOME XML library libxmlsec1XML security library libxmlsec1-opensslOpenssl engine for the XML security library libxmu6X11 miscellaneous utility library libxmuu1X11 miscellaneous micro-utility library libxpm4X11 pixmap library libxrandr-devX11 RandR extension library (development headers) libxrandr2X11 RandR extension library libxrender-devX Rendering Extension client library (development files) libxrender1X Rendering Extension client library libxres1X11 Resource extension library libxshmfence1X shared memory fences - shared library libxslt1.1XSLT 1.0 processing library - runtime library libxss1X11 Screen Saver extension library libxt6X11 toolkit intrinsics library libxtables11netfilter xtables library libxtst6X11 Testing -- Record extension library libxv1X11 Video extension library libxvmc1X11 Video extension library libxxf86dga1X11 Direct Graphics Access extension library libxxf86vm1X11 XFree86 video mode extension library libzstd1fast lossless compression algorithm linux-baseLinux image base package linux-firmwareFirmware for Linux kernel drivers linux-headers-4.15.0-58Header files related to Linux kernel version 4.15.0 linux-headers-4.15.0-58-generiLinux kernel headers for version 4.15.0 on 64 bit x86 SMP linux-image-4.15.0-58-genericSigned kernel image generic linux-image-4.15.0-64-genericSigned kernel image generic linux-libc-devLinux Kernel Headers for development linux-modules-4.15.0-58-generiLinux kernel extra modules for version 4.15.0 on 64 bit x86 SMP linux-modules-4.15.0-64-generiLinux kernel extra modules for version 4.15.0 on 64 bit x86 SMP linux-modules-extra-4.15.0-58-Linux kernel extra modules for version 4.15.0 on 64 bit x86 SMP linux-modules-extra-4.15.0-64-Linux kernel extra modules for version 4.15.0 on 64 bit x86 SMP localesGNU C Library: National Language (locale) data [support] loginsystem login tools logrotateLog rotation utility lsb-baseLinux Standard Base init script functionality lsb-releaseLinux Standard Base version reporting utility lshwinformation about hardware configuration lsofUtility to list open files ltraceTracks runtime library calls in dynamically linked programs lvm2Linux Logical Volume Manager lxc-commonLinux Containers userspace tools (common tools) lxcfsFUSE based filesystem for LXC lxdContainer hypervisor based on LXC - daemon lxd-clientContainer hypervisor based on LXC - client m4macro processing language makeutility for directing compilation makedevcreates device files in /dev man-dbon-line manual pager manpagesManual pages about using a GNU/Linux system manpages-devManual pages about using GNU/Linux for development mawka pattern scanning and text processing language mdadmtool to administer Linux MD arrays (software RAID) mesa-common-devDeveloper documentation for Mesa mesa-utilsMiscellaneous Mesa GL utilities mime-supportMIME files 'mime.types' & 'mailcap', and support programs mlocatequickly find files on the filesystem based on their name mobile-broadband-provider-infodatabase of mobile broadband service providers modemmanagerD-Bus service for managing modems mokutiltools for manipulating machine owner keys mounttools for mounting and manipulating filesystems mtoolsTools for manipulating MSDOS files mtr-tinyFull screen ncurses traceroute tool multiarch-supportTransitional package to ensure multiarch compatibility nanosmall, friendly text editor inspired by Pico ncurses-basebasic terminal type definitions ncurses-binterminal-related programs and man pages ncurses-termadditional terminal type definitions net-toolsNET-3 networking toolkit netbaseBasic TCP/IP networking system netcat-openbsdTCP/IP swiss army knife nettle-devlow level cryptographic library (development files) network-managernetwork management framework (daemon and userspace tools) network-manager-gnomenetwork management framework (GNOME frontend) network-manager-pptpnetwork management framework (PPTP plugin core) nfs-commonNFS support files common to client and server notification-daemondaemon for displaying passive pop-up notifications ntfs-3gread/write NTFS driver for FUSE ntpNetwork Time Protocol daemon and utility programs open-iscsiiSCSI initiator tools open-vm-toolsOpen VMware Tools for virtual machines hosted on VMware (CLI) openjdk-8-jre-headlessOpenJDK Java runtime, using Hotspot JIT (headless) openssh-clientsecure shell (SSH) client, for secure access to remote machines openssh-serversecure shell (SSH) server, for secure access from remote machines openssh-sftp-serversecure shell (SSH) sftp server module, for SFTP access from remote machines opensslSecure Sockets Layer toolkit - cryptographic utility os-proberutility to detect other OSes on a set of drives overlayrootuse an overlayfs on top of a read-only root filesystem p11-kitp11-glue utilities p11-kit-modulesp11-glue proxy and trust modules parteddisk partition manipulator passwdchange and administer password and group data pastebinitcommand-line pastebin client patchApply a diff file to an original pciutilsLinux PCI Utilities perlLarry Wall's Practical Extraction and Report Language perl-baseminimal Perl system perl-modules-5.22Core Perl modules pinentry-gnome3GNOME 3 PIN or pass-phrase entry dialog for GnuPG pkg-configmanage compile and link flags for libraries plymouthboot animation, logger and I/O multiplexer plymouth-theme-ubuntu-textboot animation, logger and I/O multiplexer - ubuntu text theme policykit-1framework for managing administrative policies and privileges policykit-1-gnomeGNOME authentication agent for PolicyKit-1 poppler-dataencoding data for the poppler PDF rendering library popularity-contestVote for your favourite packages automatically powermgmt-baseCommon utils and configs for power management pppPoint-to-Point Protocol (PPP) - daemon pptp-linuxPoint-to-Point Tunneling Protocol (PPTP) Client procps/proc file system utilities psmiscutilities that use the proc file system pythoninteractive high-level object-oriented language (default version) python-apt-commonPython interface to libapt-pkg (locales) python-cryptocryptographic algorithms and protocols for Python python-dnspythonDNS toolkit for Python python-ldbPython bindings for LDB python-minimalminimal subset of the Python language (default version) python-sambaPython bindings for Samba python-tallochierarchical pool based memory allocator - Python bindings python-tdbPython bindings for TDB python2.7Interactive high-level object-oriented language (version 2.7) python2.7-devHeader files and a static library for Python (v2.7) python2.7-minimalMinimal subset of the Python language (version 2.7) python3interactive high-level object-oriented language (default python3 version) python3-apportPython 3 library for Apport crash report handling python3-aptPython 3 interface to libapt-pkg python3-chardetuniversal character encoding detector for Python3 python3-commandnotfoundPython 3 bindings for command-not-found. python3-dbussimple interprocess messaging system (Python 3 interface) python3-debianPython 3 modules to work with Debian-related data formats python3-distupgrademanage release upgrades python3-gdbmGNU dbm database support for Python 3.x python3-giPython 3 bindings for gobject-introspection libraries python3-minimalminimal subset of the Python language (default python3 version) python3-newtNEWT module for Python3 python3-pkg-resourcesPackage Discovery and Resource Access using pkg_resources python3-problem-reportPython 3 library to handle problem reports python3-pycurlPython bindings to libcurl (Python 3) python3-requestselegant and simple HTTP library for Python3, built for human beings python3-sixPython 2 and 3 compatibility library (Python 3 interface) python3-software-propertiesmanage the repositories that you install software from python3-systemdPython 3 bindings for systemd python3-update-managerpython 3.x module for update-manager python3-urllib3HTTP library with thread-safe connection pooling for Python3 python3.5Interactive high-level object-oriented language (version 3.5) python3.5-minimalMinimal subset of the Python language (version 3.5) qtQt 5.6.3 lib filesxport PATH=/opt/Qt5.6.3/5.6.3/gcc_64/bin:$PATH qt512Qt 5.12.9 lib filesxport PATH=/opt/TekSDK/Qt/5.12.9/bin:$PATH qttranslations5-l10ntranslations for Qt 5 readline-commonGNU readline and history libraries, common files renamePerl extension for renaming multiple files resolvconfname server information handler rpcbindconverts RPC program numbers into universal addresses rsyncfast, versatile, remote (and local) file-copying tool rsyslogreliable system and kernel logging daemon run-onerun just one instance of a command and its args at a time sambaSMB/CIFS file, print, and login server for Unix samba-commoncommon files used by both the Samba server and client samba-common-binSamba common files used by both the server and the client samba-dsdb-modulesSamba Directory Services Database samba-libsSamba core libraries samba-vfs-modulesSamba Virtual FileSystem plugins sbsigntoolutility for signing and verifying files for UEFI Secure Boot screenterminal multiplexer with VT100/ANSI terminal emulation secureboot-dbSecure Boot updates for DB and DBX sedThe GNU sed stream editor sensible-utilsUtilities for sensible alternative selection sgml-baseSGML infrastructure and SGML catalog file support shared-mime-infoXXXXXXXXXXXXXXX shared MIME database and spec shimboot loader to chain-load signed boot loaders under Secure Boot shim-signedSecure Boot chain-loading bootloader (Microsoft-signed binary) snapdDaemon and tooling that enable snap packages software-properties-commonmanage the repositories that you install software from (common) sosreportSet of tools to gather troubleshooting data from a system squashfs-toolsTool to create and append to squashfs filesystems ssh-import-idsecurely retrieve an SSH public key and install it locally straceSystem call tracer sudoProvide limited super user privileges to specific users systemdsystem and service manager systemd-sysvsystem and service manager - SysV links sysv-rcSystem-V-like runlevel change mechanism sysvinit-utilsSystem-V-like utilities tarGNU version of the tar archiving utility taskseltool for selecting tasks for installation on Debian systems tasksel-dataofficial tasks used for installation of Debian systems tclTool Command Language (default version) - shell tcl-expectAutomates interactive applications (Tcl package) tcl8.6Tcl (the Tool Command Language) v8.6 - shell tcpdWietse Venema's TCP wrapper utilities tcpdumpcommand-line network traffic analyzer tdb-toolsTrivial Database - bundled binaries tekscopefilesysTektronix scope filesystem telnetbasic telnet client thermaldThermal monitoring and controlling daemon timeGNU time program for measuring CPU resource usage tkToolkit for Tcl and X11 (default version) - windowing shell tk8.6Tk toolkit for Tcl and X11 v8.6 - windowing shell tmuxterminal multiplexer tomcat7Servlet and JSP engine tomcat7-adminServlet and JSP engine -- admin web applications tomcat7-commonServlet and JSP engine -- common files tomcat7-userServlet and JSP engine -- tools to create user instances tzdatatime zone and daylight-saving time data ubuntu-advantage-toolsmanagement tools for Ubuntu Advantage ubuntu-cloudimage-keyringGnuPG keys of the Ubuntu Cloud Image builder ubuntu-keyringGnuPG keys of the Ubuntu archive ubuntu-minimalMinimal core of Ubuntu ubuntu-monoUbuntu Mono Icon theme ubuntu-release-upgrader-coremanage release upgrades ubuntu-standardThe Ubuntu standard system ucfUpdate Configuration File(s): preserve user changes to config files udev/dev/ and hotplug management daemon ufwprogram for managing a Netfilter firewall uidmapprograms to help use subuids unattended-upgradesautomatic installation of security upgrades unzipDe-archiver for .zip files update-inetdinetd configuration file updater update-manager-coremanage release upgrades update-notifier-commonFiles shared between update-notifier and other packages ureadaheadRead required files in advance usb-modeswitchmode switching tool for controlling "flip flop" USB devices usb-modeswitch-datamode switching data for usb-modeswitch usbutilsLinux USB utilities util-linuxmiscellaneous system utilities uuid-runtimeruntime components for the Universally Unique ID library vimVi IMproved - enhanced vi editor vim-commonVi IMproved - Common files vim-runtimeVi IMproved - Runtime files vim-tinyVi IMproved - enhanced vi editor - compact version vlanuser mode programs to enable VLANs on your ethernet devices vnc4serverVirtual network computing server software wgetretrieves files from the web whiptailDisplays user-friendly dialog boxes from shell scripts wireless-regdbwireless regulatory database wkhtmltopdfCommand line utilities to convert html to pdf or image using WebKit wpasupplicantclient support for WPA and WPA2 (IEEE 802.11i) x11-appsX applications x11-commonX Window System (XXXXX) infrastructure x11-session-utilsX session utilities x11-utilsX11 utilities x11-xkb-utilsX11 XKB utilities x11-xserver-utilsX server utilities x11proto-core-devX11 core wire protocol and auxiliary headers x11proto-fixes-devX11 Fixes extension wire protocol x11proto-input-devX11 Input extension wire protocol x11proto-kb-devX11 XKB extension wire protocol x11proto-randr-devX11 RandR extension wire protocol x11proto-render-devX11 Render extension wire protocol x11proto-xext-devX11 various extension wire protocol x11vncVNC server to allow remote access to an existing X session x11vnc-datadata files for x11vnc xauthX authentication utility xbase-clientsmiscellaneous X clients - metapackage xbitmapsBase X bitmaps xdg-user-dirstool to manage well known user directories xfconfutilities for managing settings in Xfce xfonts-basestandard fonts for X xfonts-encodingsEncodings for XXXXX fonts xfonts-utilsX Window System font utility programs xfsprogsUtilities for managing the XFS filesystem xfwm4window manager of the Xfce project xinitX server initialisation tool xinputRuntime configuration and test of XInput devices xinput-calibratorGeneric touchscreen calibration program for XXXXX xkb-dataX Keyboard Extension (XKB) configuration data xml-coreXML infrastructure and XML catalog file support xorg-sgml-doctoolsCommon tools for building XXXXX SGML documentation xrdpRemote Desktop Protocol (RDP) server xserver-commoncommon files used by various X servers xserver-xorg-core-hwe-16.04Xorg X server - core server xserver-xorg-hwe-16.04XXXXX X server xserver-xorg-input-all-hwe-16.XXXXX X server -- input driver metapackage xserver-xorg-input-evdev-hwe-1XXXXX X server -- evdev input driver xserver-xorg-input-synaptics-hSynaptics TouchPad driver for XXXXX server xserver-xorg-input-wacom-hwe-1XXXXX X server -- Wacom input driver xserver-xorg-legacy-hwe-16.04setuid root Xorg server wrapper xserver-xorg-video-all-hwe-16.XXXXX X server -- output driver metapackage xserver-xorg-video-amdgpu-hwe-XXXXX X server -- AMDGPU display driver xserver-xorg-video-ati-hwe-16.XXXXX X server -- AMD/ATI display driver wrapper xserver-xorg-video-fbdev-hwe-1XXXXX X server -- fbdev display driver xserver-xorg-video-intel-hwe-1XXXXX X server -- Intel i8xx, i9xx display driver xserver-xorg-video-nouveau-hweXXXXX X server -- Nouveau display driver xserver-xorg-video-qxl-hwe-16.XXXXX X server -- QXL display driver xserver-xorg-video-radeon-hwe-XXXXX X server -- AMD/ATI Radeon display driver xserver-xorg-video-vesa-hwe-16XXXXX X server -- VESA display driver xserver-xorg-video-vmware-hwe-XXXXX X server -- VMware display driver xtermX terminal emulator xtrans-devX transport library (development files) xz-utilsXZ-format compression utilities yadtool for creating graphical dialogs from shell scripts zenity-commonDisplay graphical dialog boxes from shell scripts (common files) zerofreezero free blocks from ext2, ext3 and ext4 file-systems zlib1gcompression library - runtime zlib1g-devcompression library - development zstdfast lossless compression algorithm -- CLI tool |
