Lua脚本32位数模拟64位乘除运算, 有符号的
m24h2020/01/29原创 软件综合 IP:上海
中文摘要
一个32位有符号数乘另一个32位有符号数减去一个32位有符号数
结果再除于一个32位有符号数
最终输出一个有符号的64位数和32位有符号的模
关键词
32位模拟64位
网上没有有效的代码可以抄
只好自己废脑细胞
这算法没啥难点, 就是复杂而已, 符号实现很麻烦
算法是在lua上的, 但是其他需要的地方也可以借鉴
算法是为了:
结果再除于一个32位有符号数
没有溢出或者精度丢失问题
--- for (a*b+c)/d, input signed 32bit, return signed 64bit quotient and signed 32bit remainder as [low32, high32, remainder]
--- following lua remainder rule
function muldiv (a, b, c, d)
    assert(d~=0, "muldiv() divided by 0")
    --- a*b
    local t0, t1, t2, t3 = bit.rshift(a,16), XXXXXXnd(0xffff, a), bit.rshift(b,16), XXXXXXnd(0xffff, b)
    t0, t1, t2, t3 = t1*t3, t1*t2, t0*t3, t0*t2
    t0, t1 = XXXXXXnd(0xffff, t0), bit.rshift(t0,16)+t1+XXXXXXnd(0xffff, t2)
    t0, t3 = t0 + XXXXXXhift(t1, 16), t3+bit.rshift(t1,16)+bit.rshift(t2,16)
    if (a<0) then t3 = t3-b end
    if (b<0) then t3 = t3-a end
    --- +c
    if (c>0) then
        if (t0<0) then
            t0 = t0+c
            if (t0>=0) then t3=t3+1 end
        else
            t0 = t0+c
        end
    else
        if (t0>=0) then
            t0 = t0+c
            if (t0<0) then t3=t3-1 end
        else
            t0 = t0+c
        end
    end
    --- /d
    local s1, s2 = false, false
    if (d<0) then
        d = -d
        s1 = true
    end
    if (t3<0) then
        t0 = -t0
        t3 = -t3 - 1
        s2 = true
    end
    t2=0
    for t1=1,32 do
        t2 = XXXXXXhift(t2, 1) + bit.rshift(t3, 31)
        t3 = XXXXXXhift(t3, 1)
        if (t2>=d or t2<0) then
            t2 = t2 - d
            t3 = t3 + 1
        end
    end
    for t1=1,32 do
        t2 = XXXXXXhift(t2, 1) + bit.rshift(t0, 31)
        t0 = XXXXXXhift(t0, 1)
            t2 = t2 - d
            t0 = t0 + 1
        end
    end
    if (s1) then
        if (s2) then
            t2 = -t2
        else
            t0 = -t0
            t3 = -t3 - 1
            if (t2~=0) then
                t2 = t2 - d
                if (t0==0) then
                    t3 = t3 -1
                end
                t0 = t0 - 1
            end
        end
    elseif (s2) then
        t0 = -t0
        t3 = -t3 - 1
        if (t2~=0) then
            t2 = d - t2
            if (t0==0) then
                t3 = t3 -1
            end
            t0 = t0 - 1
         end
    end
    return t0, t3, t2
end
来自:计算机科学 / 软件综合
m24h
进士 学者 机友
2020/01/22注册,1时44分前活动
个人开源项目: XXXXXXXXXXXXXX
IP归属地:上海
