零重力实验室的这个广告打得好
虎哥2018/02/22正能量研究 IP:四川
图片来自bg6lqv。
相关链接:XXXXXXXXXXXXXXXXXXXXXXXX/t/82635
风马牛一号卫星是由翎客航天公司(@焓熵` )领导的一个业余卫星项目,使用0.7m波段作为下行。
频率及调制资料如下:
Headline Details: A 3U CubeSat with deployable solar panels. The main mission of the satellite is that new component experiment. FMN-1 will also serve as a repeater for amateurs worldwide via the onboard transponder system. Proposing a 9k6 BPSK AX25 UHF downlink with an FM uplink on VHF. Planning a launch into a 490km SSO from Jiuquan on 16th August 2017 **The following frequencies have been coordinated - FM repeater downlink and telemetry 435.350 MHz and for FM repeater uplink 145.945 MHz**
如果不懂GUNRADIO,可以用普通的SDR软件,使用USB方式解调,然后使用UZ7HO的SoundModem 软件解码。
来自:电子信息 / 无线电
专家 进士 学者 机友 笔友
2005/08/24注册,4秒前活动
刘 虎
创新工程局主席
认证方式:身份证号
