学习了,十分感谢!期待更新。pixhawk和APM用一样的源代码吗?
<code class="lang-"> void loop() { // We want this to execute at 50Hz if possible // ------------------------------------------- if (millis()-fast_loopTimer > 19) 1 { delta_ms_fast_loop = millis() - fast_loopTimer; 2 load= (float)(fast_loopTimeStamp - fast_loopTimer)/delta_ms_fast_loop; //cpu使用率 3 G_Dt=(float)delta_ms_fast_loop/1000.f; //陀螺仪积分时间(DCM算法) 4 fast_loopTimer = millis(); 5 mainLoop_count++; 6 // Execute the fast loop // --------------------- fast_loop(); 7 // Execute the medium loop // ----------------------- medium_loop(); 8 counter_one_herz++; 9 if(counter_one_herz == 50) 10 { one_second_loop(); 11 counter_one_herz = 0; 12 } if(millis()-perf_mon_timer>20000) 13 { //性能监控时间到,执行性能监控 if (mainLoop_count != 0) 14 { gcs.send_message(MSG_PERF_REPORT); 15 if (g.log_bitmask & MASK_LOG_PM) 16 Log_Write_Performance(); 17 resetPerfData(); 18 } } fast_loopTimeStamp = millis(); 19 } } </code>
<code class="lang-"> void fast_loop() { // This is the fast loop - we want it to execute at 50Hz if possible // ----------------------------------------------------------------- if (delta_ms_fast_loop > G_Dt_max) G_Dt_max = delta_ms_fast_loop; // Read radio ////读取遥控信号 // ---------- read_radio(); //APM_RC.InputCh(CH_ROLL)-> ch1_temp-> g.channel_roll.set_pwm(ch1_temp)(即转为control_in) //油门还有control_failsafe(g.channel_throttle.radio_in); //g.channel_throttle.servo_out = g.channel_throttle.control_in; //airspeed_nudge,throttle_nudge, // check for loss of control signal failsafe condition ////检查丢失控制信号故障安 // ------------------------------------ check_short_failsafe(); //关于failsafe和ch3_failsafe的处理 // Read Airspeed ///读取空速 // ------------- if (g.airspeed_enabled == true && HIL_MODE != HIL_MODE_ATTITUDE) { //使能空速计真实飞行时为1 read_airspeed(); //读取空速,并calc_airspeed_errors(); } else if (g.airspeed_enabled == true && HIL_MODE == HIL_MODE_ATTITUDE) { //真实飞行时为0 calc_airspeed_errors(); } #if HIL_MODE == HIL_MODE_SENSORS //飞行模式时为0 // update hil before dcm update hil.update(); #endif dcm.update_DCM(G_Dt); ////更新DCM // uses the yaw from the DCM to give more accurate turns ///使用从DCM获得的偏航数据,进行更精确的转弯 calc_bearing_error(); //计算得出bearing_error # if HIL_MODE == HIL_MODE_DISABLED //飞行模式时为1 if (g.log_bitmask & MASK_LOG_ATTITUDE_FAST) Log_Write_Attitude((int)dcm.roll_sensor, (int)dcm.pitch_sensor, (uint16_t)dcm.yaw_sensor); if (g.log_bitmask & MASK_LOG_RAW) Log_Write_Raw(); #endif // inertial navigation ////惯性导航 // ------------------ #if INERTIAL_NAVIGATION == ENABLED //这个不执行。本程序的捷联惯性导航算法只能计算飞机飞行姿态,无法结算三维位置,,所以,不能实施完全的惯性导航。或者程序作者正在进行相关试验,或者程序作者的惯性导航不是这个意思,仅是调试时调用这个。 // TODO: implement inertial nav function //实施惯性导航功能 inertialNavigation(); #endif // custom code/exceptions for flight modes ///飞行模式的自定义代码/异常 // --------------------------------------- update_current_flight_mode(); // 导航级PID // apply desired roll, pitch and yaw to the plane ////控制飞机的副翼,升降,方向 if (control_mode > MANUAL) stabilize(); // 控制级PID //write out the servo PWM values // set_servos_4(); // XXX is it appropriate to be doing the comms below on the fast loop? ////现在适合做快速环路上的COMMS吗? #if HIL_MODE != HIL_MODE_DISABLED && HIL_PORT != GCS_PORT //飞行模式时为0 // kick the HIL to process incoming sensor packets //使用HIL处理传入的传感器数据包 hil.update(); #if HIL_PROTOCOL == HIL_PROTOCOL_MAVLINK hil.data_stream_send(45,1000); #else hil.send_message(MSG_SERVO_OUT); #endif #elif HIL_PROTOCOL == HIL_PROTOCOL_MAVLINK && HIL_MODE == HIL_MODE_DISABLED && HIL_PORT == 0 //飞行模式时为1 // Case for hil object on port 0 just for mission planning //HIL端口的对象,只是用来进行任务规划 hil.update(); hil.data_stream_send(45,1000); #endif // kick the GCS to process uplink data ////让GCS处理上行数据 gcs.update(); #if GCS_PROTOCOL == GCS_PROTOCOL_MAVLINK //飞行模式时为 gcs.data_stream_send(45,1000); #endif // XXX this should be absorbed into the above, // or be a "GCS fast loop" interface } </code>
[修改于 7年10个月前 - 2016/08/26 22:03:00]
