【class】C#指针二值化代码
93°2009/07/29软件综合 IP:广东
用指针那是相当的快。。相当的爽。。。普通验证码基本1ms之内解决掉
这里暂时是RGB2L法,要RGB2H的改一下就好
编译好的类
attachment icon Binary.rar 2.53KB RAR 31次下载
using System;
using XXXXXXXXXXXXXXXXXXXXXneric;
using XXXXXXXXXXponentModel;
using System.Data;
using System.Drawing;
using System.Text;
namespace Binary
    public class CSunsafe
        private XXXXXXXXXXXXXXXXXtmap curBitmap;
        private int[,] pic;
        public void File_Init(string sFilename)
            if (sFilename != null)
                curBitmap = (Bitmap)XXXXXXXXomFile(sFilename);
        public void BMP_Init(Bitmap BMP)
            if (BMP != null)
                curBitmap = BMP;
        private double Max(double a, double b)
            if (a > b)
                return a;
            return b;
        private double Min(double a, double b)
            if (a < b)
                return a;
            return b;
        private double RGB2H(double r, double g, double b)
            double h;
            r /= 255.0;
            g /= 255.0;
            b /= 255.0;
            double mi = this.Min(r, this.Min(g, b));
            double ma = XXXXXXXx(r, XXXXXXXx(g, b));
            h = 0;
            double del_max = ma - mi;
            if (del_max == 0.0)
                return 0.0;
            double del_r = ((ma - (r / 6.0)) + (del_max / 2.0)) / del_max;
            double del_g = ((ma - (g / 6.0)) + (del_max / 2.0)) / del_max;
            double del_b = ((ma - (b / 6.0)) + (del_max / 2.0)) / del_max;
            if (r == ma)
                h = del_b - del_g;
            else if (g == ma)
                h = (1.0/3.0 + del_r) - del_b;
            else if (b == ma)
                h = (2.0/3.0 + del_g) - del_r;
            if (h < 0.0)
                h++;
            if (h > 1.0)
                h--;
            return h;
        private double RGB2L(double r, double g, double b)
            r /= 255.0;
            g /= 255.0;
            b /= 255.0;
            return ((XXXXXXXx(r, XXXXXXXx(g, b)) + mi) / 2.0);
        public int[,] Binary(double value)
            if (curBitmap != null)
                Rectangle rect = new Rectangle(0, 0, curBitmap.Width, curBitmap.Height);
                XXXXXXXXXXXXXXXXXXXXXXXXXtmapData bmpData = curBitmap.LockBits(rect, XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXadWrite, curBitmap.PixelFormat);
                pic = new int [bmpData.Width,bmpData.Height];
                unsafe
                    byte* ptr = (byte*)(XXXXXXXXXXan0);
                    for (int i = 0; i < bmpData.Height; i++)
                        for (int j = 0; j < bmpData.Width; j++)
                            if (RGB2L(ptr[2], ptr[1], ptr[0]) < value)
                                pic[j, i] = 1;
                            else
                                pic[j, i] = 0;
                            ptr += 3;
                        ptr += XXXXXXXXXXride - bmpData.Width * 3;
                curBitmap.UnlockBits(bmpData);
                return pic;
            else
                return null;
要编译本代码请允许不安全代码 如下图所示
+1000  科创币    delete    2009/07/29 试试评个分
来自:计算机科学 / 软件综合
19
93° 作者
15年6个月前 IP:未同步
133241
最近爱上C#了 。。爱上C#了……C#…… 。。。。
93°作者
15年6个月前 IP:未同步
133252
引用第2楼chiataimakra于2009-07-29 16:50发表的  :
算法很恶心(或者说我没看懂。。。有可能的)
提出二值化算法:
RGB,阈值为y
去试一试就知道了,这个算法在我以前的帖子里就已经发过,对于某种验证码 比如我这次做的,基本无效
93°作者
15年6个月前 IP:未同步
133253
引用第4楼chiataimakra于2009-07-29 16:54发表的  :
然后就是这一段
                                pic[j, i] = 1;
请参见MSDN
93°作者
15年6个月前 IP:未同步
133255
(如果不是,自然就是0了,不用加一句else return 0
= = 在很大程度上表现出您对C#的不了解
还有,null不是0 。。。。如果在这个function里返回0会报错的,人家要的是二维数组。。您返回个0
null=nothing=nil=什么都没有
如果去掉return null
93°作者
15年6个月前 IP:未同步
133258
提出二值化算法:
RGB,阈值为y
参见这里XXXXXXXXXXXXXXXXXXXXXXXX/t/12553
93°作者
15年6个月前 IP:未同步
133263
引自《C++ primer》
定义变量时,应该给变量赋初始值,除非确定变量用于其它意图之前会覆盖这个初值。
虽然是关于cpp的,但是所有编程语言都应该这样做,“如果不是自然就是0了”很明显是不符合编程规范的
使用C的时候就囧死你了,int i,直接出i的值的话保证囧飞你
93°作者
15年6个月前 IP:未同步
133265
虽然说我命名极其不规范,UI极其不规范,但是我这个编程思想还是要规范的 。。。 = =
93°作者
15年6个月前 IP:未同步
133267
送上测试代码
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles XXXXXXXXXXick
        Dim binary_frame As New Binary.CSunsafe
        binary_XXXXXXXXP_Init(XXXXXXXXXXXXXXage)
        pic = binary_XXXXXXXXnary_L(0.6)
        debug(pic, 50, 85)
    End Sub
    Public Function debug(ByVal pic(,) As Integer, ByVal width As Integer, ByVal height As Integer)
        Dim bmp As New Bitmap(width + 1, height + 1)
        Dim i, j As Integer
        For i = 0 To width
            For j = 0 To height
                If pic(i, j) = 1 Then
                    XXXXXXtPixel(i, j, Color.Black)
                End If
            Next
        Next
        Dim frm As New Form
        XXXXXXckgroundImage = bmp
        XXXXXXckgroundImageLayout = ImageLayout.Center
        XXXXXXow()
        Return Nothing
    End Function
93°
2007/04/10注册,6年11个月前活动
