I'd love to.
ba la la la la~
ba la la la la~
.386
.model flat, stdcall 32 bit memory model
option casemap :none case sensitive
include XXXXXXXXXXc
include XXXXXXXXXXXc
include XXXXXXXXXc
includelib XXXXXXXXXXXb
includelib XXXXXXXXXb
DlgProc PROTO :HWND,:UINT,:WPARAM,[s:10]PARAM
.data?
hInstance dd ?
hTimer dd ?
.code
DllEntry proc _hInstance,_dwReason,_dwReserved
.if _dwReason==DLL_PROCESS_ATTACH
invoke GetModuleHandle,NULL
push _hInstance
pop hInstance
invoke DialogBoxParam,hInstance,101,NULL,addr DlgProc,NULL
.endif
mov eax,TRUE
ret
DllEntry endp
DlgProc proc hWin:HWND,uMsg:UINT,wParam:WPARAM,lParam[s:10]PARAM
mov eax,uMsg
.if eax==WM_INITDIALOG ;初始化,设定1秒的计时器
invoke SetTimer,hWin,1,1000,NULL
mov hTimer,eax
.elseif eax==WM_CLOSE
invoke EndDialog,hWin,NULL
.elseif eax==WM_TIMER ;时间到,取消计时器,关闭对话框,返回 DllEntry
invoke KillTimer,hTimer,1
.else
mov eax,FALSE
ret
.endif
mov eax,TRUE
ret
DlgProc endp
End DllEntry
0100739D PUSH 70
0100739F PUSH 01001898
0100739D JMP 01008750
010073A2 NOP
010073A3 NOP
010073A4 . CALL NOTEPAD.01007568
01008750 PUSH 70
01008752 PUSH NOTEPAD.01001898
01008750 PUSH 70
01008757 JMP SHORT NOTEPAD.01008764 ;留一个字节,做字符串结束用
01008759 DEC ESI
0100875A JA SHORT NOTEPAD.010087A1 多余的前缀
0100875D INS BYTE PTR ES:[EDI],DX ; I/O 命令
0100875E INS BYTE PTR ES:[EDI],DX ; I/O 命令
0100875F PREFIX CS: ; 多余的前缀
01008760 INS BYTE PTR ES:[EDI],DX ; I/O 命令
01008762 INS BYTE PTR ES:[EDI],DX ; I/O 命令
01008764 PUSH NOTEPAD.01008759 ASCII "NewDll.dll"
01008769 MOV EAX,DWORD PTR [10010C8]
0100876E CALL EAX
01008770 JMP NOTEPAD.010073A2
