谁能做出来这个东西?
AnthraX2009/01/22电子技术 IP:澳大利亚
这是一个rfid设备的虚拟器(emulator),可以将自己虚拟成任意一个设定的rfid卡或者读卡器,和卡或者读卡器通信,并且记录通信过程(数据)。 本来原来在这个网站上有卖的,现在没有了,但是设计图是开源的,如果有高手能做出来的话,我可以现金收购。
The OpenPICC project for Proximity Integrated Circuit Cards (PICC) is the counterpart to OpenPCD. It is a device that emulates 13.56MHz based RFID transponders / smartcards. OpenPICC can be used to e.g. simulate ISO 14443 or ISO 15693 transponders, such as those being used in biometric passports and FIFA worldcup tickets.
Schematics (pdf)
XXXXXXXXXXXXXXXXXXXXXX/dl/openpicc/OpenPICC_Bm117_3_SCH.pdf
PCB layout (pdf)
XXXXXXXXXXXXXXXXXXXXXX/dl/openpicc/OPENPICC_Bm117_3_PCB.pdf
Bill of materials (pdf)
XXXXXXXXXXXXXXXXXXXXXX/dl/openpicc/OpenPICC_Bm117_3_BOM.pdf
Gerber files (zip)
XXXXXXXXXXXXXXXXXXXXXX/dl/openpicc/BM117_3.ZIP
AnthraX 作者
16年0个月前 IP:未同步
64537
这个很有用,由于mifare通信加密的脆弱性(1-65535随机数字),只要12秒就能破解出key a 和key b
AnthraX
2008/03/06注册,1个月22天前活动
