这是一个rfid设备的虚拟器(emulator),可以将自己虚拟成任意一个设定的rfid卡或者读卡器,和卡或者读卡器通信,并且记录通信过程(数据)。 本来原来在这个网站上有卖的,现在没有了,但是设计图是开源的,如果有高手能做出来的话,我可以现金收购。
The OpenPICC project for Proximity Integrated Circuit Cards (PICC) is the counterpart to OpenPCD. It is a device that emulates 13.56MHz based RFID transponders / smartcards. OpenPICC can be used to e.g. simulate ISO 14443 or ISO 15693 transponders, such as those being used in biometric passports and FIFA worldcup tickets.
Schematics (pdf)
XXXXXXXXXXXXXXXXXXXXXX/dl/openpicc/OpenPICC_Bm117_3_SCH.pdfPCB layout (pdf)
XXXXXXXXXXXXXXXXXXXXXX/dl/openpicc/OPENPICC_Bm117_3_PCB.pdfBill of materials (pdf)
XXXXXXXXXXXXXXXXXXXXXX/dl/openpicc/OpenPICC_Bm117_3_BOM.pdfGerber files (zip)
XXXXXXXXXXXXXXXXXXXXXX/dl/openpicc/BM117_3.ZIP
