在日常生活中,我们可能会遇到像导航路线选择的问题.这时我们就需要从诸多路径中选择最短的一条.
为了解决此类问题我们需要引入一个概念——图.
(图-1)
如图-1,这就是一个图.图中的每一个节点叫作顶点,连接两个顶点的线段叫作边.当然,有一些图中由顶点指向顶点的边是有向的(比如该图)叫作有向图,也有的图由顶点指向顶点的边是无向的叫作无向图.图中的每一条边都可以有一个权值$f$,比如图中BD边的权值就可记作$f_{BD} = 5$.
若将图描述为一个集合$G$,那么则有
$$V,E\subset\\G$$(1)
其中$V,E$分别为点集和边集,他们都是$G$的子集.
尽然了解了图的概念,我们将讲解一下Dijkstra算法.
参照百度百科对Dijkstra算法的介绍:迪杰斯特拉算法(Dijkstra)是由荷兰计算机科学家狄克斯特拉于1959年提出的,因此又叫狄克斯特拉算法。是从一个顶点到其余各顶点的最短路径算法,解决的是有权图中最短路径问题.迪杰斯特拉算法主要特点是从起始点开始,采用贪心算法的策略,每次遍历到始点距离最近且未访问过的顶点的邻接节点,直到扩展到终点为止.
设带权图$G = (V,E)$,求v到其它点的最短路径.开一个二维列表Weight作为边的权值,d[i]为点的值(初始为无穷大).sign[i]为标记列表,数值类型为bool,初始为False.
大致步骤如下:
d[v] = 0,sign[v] = True
对当前已确定的点i,寻找所有未确定的点j,若边<i,j>存在则进行松弛操作d[j] < d[i] + Weight[i][j]
确定i和d[i].即对所有为未打上标记的点j,枚举找出最小的点d[j],令sign[j] = True.
重复2、3步骤直到所有的点都被确定为止.
显然,理想情况下上述算法的时间复杂度为$O(n^2)$
以下是我用python编写的测试代码:
import openpyxl import heapq def read_graph_from_excel(filepath): workbook = openpyxl.load_workbook(filepath) sheet = workbook.active graph = {} for row in sheet.iter_rows(min_row=3, values_only=True): # Start from row 3 now, since we skip the first two rows node1, node2, weight = row[0], row[1], row[2] if node1 not in graph: graph[node1] = [] if node2 not in graph: graph[node2] = [] graph[node1].append((node2, weight)) graph[node2].append((node1, weight)) # Assuming an undirected graph return graph def dijkstra(graph, start): distances = {vertex: float('infinity') for vertex in graph} distances[start] = 0 pq = [] # Priority queue for neighbor, weight in graph[start]: heapq.heappush(pq, (0, neighbor)) # Set initial distance to 0 for neighbors of start node while pq: current_distance, current_vertex = heapq.heappop(pq) if current_distance > distances[current_vertex]: continue for neighbor, weight in graph[current_vertex]: distance = current_distance + weight if distance < distances[neighbor]: distances[neighbor] = distance heapq.heappush(pq, (distance, neighbor)) return distances # Read the graph from Excel file_path = r"C:\Users\Administrator\Desktop\new1\s.xlsx" graph = read_graph_from_excel(file_path) # Run Dijkstra algorithm start_node = 1 # Change this to match the first node in your Excel file distances = dijkstra(graph, start_node) # Print the results for node, distance in distances.items(): if node != start_node: print(f"Shortest path to node {node}: {distance}")
程序保存在C:\Users\Administrator\Desktop\new2目录下的s1.xlsx文件作为输入(不知道为啥我一用相对路径就报错,所以我选择了绝对路径),xlsx文件的A列用来保存原顶点,B列用来保存与其连接的顶点,C列用来保存权值.测试的图如下:
(图-2)
结果为
Shortest path to node 2: 3 Shortest path to node 3: 6 Shortest path to node 4: 5 Shortest path to node 5: 7 Shortest path to node 1: 2
