Python脚本计算内弹道(似乎有问题)
ZiRui2024/06/06喷气推进 IP:广东
Python
from tkinter import Tk, Label, Entry, Button, StringVar from tkinter.messagebox import showerror from tkinter.filedialog import askdirectory from math import sqrt root = Tk() root.title("推力室内弹道") def calculate():     try:         gamma = float(gamma_entry.get())         mass_flow = float(mass_flow_entry.get())         pressure = float(pressure_entry.get())         temperature = float(temperature_entry.get())         gas_constant = float(gas_constant_entry.get())         pressure_export = float(pressure_export_entry.get())         characteristic_length = float(characteristic_length_entry.get())         diameter_convergence_ratio_length = float(diameter_convergence_ratio_length_entry.get())         convergence_half_angle = float(convergence_half_angle_entry.get())         G = sqrt(gamma) * (2 / (gamma + 1)) ** ((gamma + 1) / (2 * (gamma - 1)))         throat_area = mass_flow / (G * (pressure / sqrt(gas_constant * temperature)))         compute_throat_diameter = sqrt(throat_area / 3.14159) * 2         expansion_area_ratio = ((2 / (gamma + 1)) ** (1 / (gamma - 1)) * (                 (pressure / pressure_export) ** (1 / gamma))) / sqrt(             ((gamma + 1) / (gamma - 1)) * (1 - ((pressure_export / pressure) ** ((gamma - 1) / gamma))))         compute_export_diameter = sqrt(throat_area * expansion_area_ratio / 3.14159) * 2         chamber_volume = throat_area * characteristic_length         compute_chamber_radius = round(compute_throat_diameter * diameter_convergence_ratio_length + 0.40) / 2         compute_convergence_length = (90 / convergence_half_angle - 1) * \                                      (compute_chamber_radius - (compute_throat_diameter / 2))         chamber_volume -= float(compute_convergence_length) * 3.14159 * float(compute_chamber_radius ** 2 +        (compute_throat_diameter / 2) ** 2 +        compute_throat_diameter / 2 * compute_chamber_radius) / 3000         compute_cylinder_length = chamber_volume * 1000 / (compute_chamber_radius ** 2 * 3.14159)         chamber_diameter.set(f"{compute_chamber_radius * 2}")         cylinder_length.set(f"{round(compute_cylinder_length + 0.40)}")         convergence_length.set(f"{round(compute_convergence_length + 0.40)}")         throat_diameter.set(f"{round(compute_throat_diameter, 3)}")         expansion_diameter.set(f"{round(compute_export_diameter, 3)}")         expansion_ratio.set(f"{round(expansion_area_ratio, 3)}")     except Exception as e:         showerror("错误"f"计算过程中发生错误:\n{str(e)}")         print(e) mass_flow_label = Label(root, text="质量流量(Kg/s):") mass_flow_label.grid(row=0, column=0, padx=5, pady=5) mass_flow_entry = Entry(root) mass_flow_entry.grid(row=0, column=1, padx=5, pady=5) gamma_label = Label(root, text="比热比(γ):") gamma_label.grid(row=1, column=0, padx=5, pady=5) gamma_entry = Entry(root) gamma_entry.grid(row=1, column=1, padx=5, pady=5) pressure_label = Label(root, text="压力(MPa):") pressure_label.grid(row=2, column=0, padx=5, pady=5) pressure_entry = Entry(root) pressure_entry.grid(row=2, column=1, padx=5, pady=5) temperature_label = Label(root, text="温度(K):") temperature_label.grid(row=3, column=0, padx=5, pady=5) temperature_entry = Entry(root) temperature_entry.grid(row=3, column=1, padx=5, pady=5) gas_constant_label = Label(root, text="气体常数(J/(Kg·K)):") gas_constant_label.grid(row=4, column=0, padx=5, pady=5) gas_constant_entry = Entry(root) gas_constant_entry.grid(row=4, column=1, padx=5, pady=5) pressure_export_label = Label(root, text="出口压力(MPa):") pressure_export_label.grid(row=5, column=0, padx=5, pady=5) pressure_export_entry = Entry(root) pressure_export_entry.grid(row=5, column=1, padx=5, pady=5) characteristic_length_label = Label(root, text="特征长度(m):") characteristic_length_label.grid(row=6, column=0, padx=5, pady=5) characteristic_length_entry = Entry(root) characteristic_length_entry.grid(row=6, column=1, padx=5, pady=5) diameter_convergence_ratio_length_label = Label(root, text="直径收敛比(Dc/Dt):") diameter_convergence_ratio_length_label.grid(row=7, column=0, padx=5, pady=5) diameter_convergence_ratio_length_entry = Entry(root) diameter_convergence_ratio_length_entry.grid(row=7, column=1, padx=5, pady=5) convergence_half_angle_label = Label(root, text="敛段半角(°):") convergence_half_angle_label.grid(row=8, column=0, padx=5, pady=5) convergence_half_angle_entry = Entry(root) convergence_half_angle_entry.grid(row=8, column=1, padx=5, pady=5) def save():     with open(f"{askdirectory()}/液机推力室内弹道计算.txt"'w+', encoding="utf-8"as file:         file.write(f"推力室形状:\n")         file.write(f"燃烧室直径Dc(mm):{chamber_diameter.get()}\n")         file.write(f"圆筒段长度Lcyl(mm):{cylinder_length.get()}\n")         file.write(f"喷喉直径Dt(mm):{throat_diameter.get()}\n")         file.write(f"收敛段长度(mm):{convergence_length.get()}\n")         file.write(f"出口直径De(mm):{expansion_diameter.get()}\n")         file.write(f"膨胀比Ae/At:{expansion_ratio.get()}\n") calculate_button = Button(root, text="计算", command=calculate) calculate_button.grid(row=9, column=0, columnspan=2, padx=5, pady=5, sticky="ew") save_button = Button(root, text="保存", command=save) save_button.grid(row=10, column=0, columnspan=2, padx=5, pady=5, sticky="ew") chamber_diameter = StringVar() chamber_diameter_label = Label(root, text='燃烧室直径Dc(mm):') chamber_diameter_label.grid(row=11, column=0) chamber_diameter_value = Label(root, textvariable=chamber_diameter) chamber_diameter_value.grid(row=11, column=1) cylinder_length = StringVar() cylinder_length_label = Label(root, text='圆筒段长度Lcyl(mm):') cylinder_length_label.grid(row=12, column=0) cylinder_length_value = Label(root, textvariable=cylinder_length) cylinder_length_value.grid(row=12, column=1) throat_diameter = StringVar() throat_diameter_label = Label(root, text='喷喉直径Dt(mm):') throat_diameter_label.grid(row=13, column=0) throat_diameter_value = Label(root, textvariable=throat_diameter) throat_diameter_value.grid(row=13, column=1) convergence_length = StringVar() convergence_length_label = Label(root, text='收敛段长度(mm):') convergence_length_label.grid(row=14, column=0) convergence_length_value = Label(root, textvariable=convergence_length) convergence_length_value.grid(row=14, column=1) expansion_diameter = StringVar() expansion_diameter_label = Label(root, text='出口直径De(mm):') expansion_diameter_label.grid(row=15, column=0) expansion_diameter_value = Label(root, textvariable=expansion_diameter) expansion_diameter_value.grid(row=15, column=1) expansion_ratio = StringVar() expansion_ratio_label = Label(root, text='膨胀比Ae/At:') expansion_ratio_label.grid(row=16, column=0) expansion_ratio_value = Label(root, textvariable=expansion_ratio) expansion_ratio_value.grid(row=16, column=1) root.mainloop()
算出来的数据可能有问题,给大家提供一个可能正确的方法
ZiRui 作者
8个月4天前 IP:广东
934967
收敛段长度计算有误,已改正并改为PyQt5:
Python
from PyQt5.QtWidgets import QApplication, QMainWindow, QLabel, QLineEdit, QPushButton, QVBoxLayout, QHBoxLayout, \     QWidget, QFileDialog, QMessageBox from PyQt5.QtCore import Qt from math import sqrt, tan, radians class RocketChamberDesign(QMainWindow):     def __init__(self):         super().__init__()         self.setWindowTitle("推力室内弹道")         self.setGeometry(100100600400)         self.setStyleSheet("""             QMainWindow {                 background-color: #f0f0f0;             }             QLabel {                 font-size: 14px;                 color: #333333;             }             QLineEdit {                 font-size: 14px;                 border: 1px solid #cccccc;                 padding: 5px;                 background-color: white;                 border-radius: 5px;             }             QPushButton {                 font-size: 16px;                 padding: 10px 20px;                 border: none;                 background-color: #007acc;                 color: white;                 border-radius: 5px;             }             QPushButton:hover {                 background-color: #005fa3;             }         """)         self.initUI()     def initUI(self):         central_widget = QWidget(self)         main_layout = QVBoxLayout()         central_widget.setLayout(main_layout)         self.setCentralWidget(central_widget)         # Labels and LineEdits         self.create_input("质量流量(Kg/s):", main_layout)         self.create_input("气体比热比(γ):", main_layout)         self.create_input("燃室压力(MPa):", main_layout)         self.create_input("燃室温度(K):", main_layout)         self.create_input("气体常数(J/(Kg·K)):", main_layout)         self.create_input("出口压力(MPa):", main_layout)         self.create_input("特征长度(m):", main_layout)         self.create_input("径收敛比(Dc/Dt):", main_layout)         self.create_input("敛段半角(°):", main_layout)         # Button layout         button_layout = QHBoxLayout()         calculate_button = QPushButton("计算"self)         calculate_button.clicked.connect(self.calculate)         button_layout.addWidget(calculate_button, alignment=Qt.AlignHCenter)         save_button = QPushButton("保存"self)         save_button.clicked.connect(self.save)         button_layout.addWidget(save_button, alignment=Qt.AlignHCenter)         # Add the button layout to the main layout         main_layout.addLayout(button_layout)         # Output labels and line edits         output_layout = QVBoxLayout()         self.create_output("燃烧室直径Dc(mm):", output_layout)         self.create_output("圆筒段长度Lcyl(mm):", output_layout)         self.create_output("喷喉直径Dt(mm):", output_layout)         self.create_output("收敛段长度(mm):", output_layout)         self.create_output("出口直径De(mm):", output_layout)         self.create_output("膨胀比Ae/At:", output_layout)         # Add the output layout to the main layout         main_layout.addLayout(output_layout)     def create_input(self, label_text, layout):         input_layout = QHBoxLayout()         label = QLabel(label_text, self)         label.setAlignment(Qt.AlignRight | Qt.AlignVCenter)         input_layout.addWidget(label)         line_edit = QLineEdit(self)         line_edit.setAlignment(Qt.AlignLeft)         input_layout.addWidget(line_edit)         layout.addLayout(input_layout)         attr_name = self._format_attribute_name(label_text)         setattr(self, attr_name, line_edit)         print(f"Created attribute: {attr_name}")     def create_output(self, label_text, layout):         output_layout = QHBoxLayout()         label = QLabel(label_text, self)         label.setAlignment(Qt.AlignRight | Qt.AlignVCenter)         output_layout.addWidget(label)         line_edit = QLineEdit(self)         line_edit.setReadOnly(True)         output_layout.addWidget(line_edit)         layout.addLayout(output_layout)         attr_name = self._format_attribute_name(label_text) + '_output'         setattr(self, attr_name, line_edit)         print(f"Created attribute: {attr_name}")     @staticmethod     def _format_attribute_name(text):         # Replace non-alphanumeric characters with underscores and remove leading numbers         return ''.join([char if char.isalnum() else '_' for char in text]).lstrip('_')     def calculate(self):         try:             gamma = float(getattr(selfself._format_attribute_name("比热比(γ):")).text())             mass_flow = float(getattr(selfself._format_attribute_name("质量流量(Kg/s):")).text())             pressure = float(getattr(selfself._format_attribute_name("压力(MPa):")).text())             temperature = float(getattr(selfself._format_attribute_name("温度(K):")).text())             gas_constant = float(getattr(selfself._format_attribute_name("气体常数(J/(Kg·K)):")).text())             pressure_export = float(getattr(selfself._format_attribute_name("出口压力(MPa):")).text())             characteristic_length = float(getattr(selfself._format_attribute_name("特征长度(m):")).text())             diameter_convergence_ratio_length = float(                 getattr(selfself._format_attribute_name("直径收敛比(Dc/Dt):")).text())             convergence_half_angle = float(getattr(selfself._format_attribute_name("敛段半角(°):")).text())             G = sqrt(gamma) * (2 / (gamma + 1)) ** ((gamma + 1) / (2 * (gamma - 1)))             throat_area = mass_flow / (G * (pressure / sqrt(gas_constant * temperature)))             compute_throat_diameter = sqrt(throat_area / 3.14159) * 2             expansion_area_ratio = ((2 / (gamma + 1)) ** (1 / (gamma - 1)) * (                     (pressure / pressure_export) ** (1 / gamma))) / sqrt(                 ((gamma + 1) / (gamma - 1)) * (1 - ((pressure_export / pressure) ** ((gamma - 1) / gamma))))             compute_export_diameter = sqrt(throat_area * expansion_area_ratio / 3.14159) * 2             chamber_volume = throat_area * characteristic_length             compute_chamber_radius = round(compute_throat_diameter * diameter_convergence_ratio_length + 0.40) / 2             compute_convergence_length = (compute_chamber_radius * 2 - compute_throat_diameter) / (                     2 * tan(radians(convergence_half_angle)))             chamber_volume -= float(compute_convergence_length) * 3.14159 * float(compute_chamber_radius ** 2 +        (compute_throat_diameter / 2) ** 2 +        compute_throat_diameter / 2 * compute_chamber_radius) / 3000             compute_cylinder_length = chamber_volume * 1000 / (compute_chamber_radius ** 2 * 3.14159)             getattr(selfself._format_attribute_name("燃烧室直径Dc(mm):") + '_output').setText(                 f'{compute_chamber_radius * 2}')             getattr(selfself._format_attribute_name("圆筒段长度Lcyl(mm):") + '_output').setText(                 f'{round(compute_cylinder_length + 0.40)}')             getattr(selfself._format_attribute_name("喷喉直径Dt(mm):") + '_output').setText(                 f'{round(compute_throat_diameter, 3)}')             getattr(selfself._format_attribute_name("收敛段长度(mm):") + '_output').setText(                 f'{round(compute_convergence_length + 0.40)}')             getattr(selfself._format_attribute_name("出口直径De(mm):") + '_output').setText(                 f'{round(compute_export_diameter, 3)}')             getattr(selfself._format_attribute_name("膨胀比Ae/At:") + '_output').setText(                 f'{round(expansion_area_ratio, 3)}')         except Exception as e:             QMessageBox.critical(self"错误"f"计算过程中发生错误:\n{str(e)}")             print(e)     def save(self):         filename, _ = QFileDialog.getSaveFileName(self"保存文件""""Text Files (*.txt)")         if filename:             with open(filename, 'w', encoding="utf-8"as file:                 file.write("推力室设计参数:\n")                 file.write(f"燃烧室直径Dc(mm):{getattr(self, '燃烧室直径Dc_mm___output').text()}\n")                 file.write(f"圆筒段长度Lcyl(mm):{getattr(self, '圆筒段长度Lcyl_mm___output').text()}\n")                 file.write(f"喷喉直径Dt(mm):{getattr(self, '喷喉直径Dt_mm___output').text()}\n")                 file.write(f"收敛段长度(mm):{getattr(self, '收敛段长度_mm___output').text()}\n")                 file.write(f"出口直径De(mm):{getattr(self, '出口直径De_mm___output').text()}\n")                 file.write(f"膨胀比Ae/At:{getattr(self, '膨胀比Ae_At__output').text()}") if __name__ == '__main__':     import sys     app = QApplication(sys.argv)     main_window = RocketChamberDesign()     main_window.show()     app.exec_()     app.quit()
ZiRui
2023/12/12注册,6时18分前活动
<div class="btn btn-default btn-xs" onclick="changeUsername()">修改</div> <a href="XXXXXXXXXXXXXXXXXXXXXXX">Web</a>
IP归属地:广东
