Xilinx bit文件格式解析
warmonkey2023/03/05电子技术 IP:广东
注意这不是转载。
已经在Spartan 6, ZYNQ 7000, ZYNQ Ultrascale三个系列的器件上验证过。每个系列测试了1种器件。
提供文件解析代码。
C++
The Xilinx .bit format is pretty simple. It uses keys and lengths to  divide the file. Here is an example.  Below is a hex dump from the beginning of a .bit file: 00000000:  00 00f f0 0f f0 0f f0 0f f0 00 00 01 61 00 0a  .............a.. 00000010:  78 66 672 62663 64 00 62 00 076 31 30  xform.ncd.b..v10 00000020:  30 30 65 66 67 38 36 30 00 63 00 032 30 30 31  00efg860.c..2001 00000030:  230 38 231 30 00 64 00 030 36 335 35 3a  /08/10.d..06:55: 00000040:  30 34 00 65 00 028 18 ff ff ff ff aa 99 55 66  04.e..(.......Uf Field 1 2 bytes          length 0x0009           (big endian) 9 bytes          some sort of header     0f f0 0f f0 0f f0 0f f0 00 Field 2 2 bytes          length 0x0001           (key-length-value below) Field 3 1 byte           key 0x61                (The letter "a") 2 bytes          length 0x000a           (value depends on file name length) 10 bytes         string design name "xform.ncd" end with \0 Field 4 1 byte           key 0x62                (The letter "b") 2 bytes          length 0x000c           (value depends on part name length) 12 bytes         string part name "v1000efg860" end with \0 Field 4 1 byte           key 0x63                (The letter "c") 2 bytes          length 0x000b 11 bytes         string date "2001/08/10" end with \0 Field 5 1 byte           key 0x64                (The letter "d") 2 bytes          length 0x0009 9 bytes          string time "06:55:04" end with \0 Field 6 1 byte           key 0x65                (The letter "e") 4 bytes          length 0x000c2818       (configuration length) 796696 bytes     raw bitstream starting with ffff ffff aa99 5566 sync word
C++
//Xilinx .bit file header parser class HeaderParser { private:     uint8_t state;     //0=header len, 1=header data,     //2=key, 3=length, 4=value,     //5=bitstream len, 6=bitstream     uint32_t len;     uint8_t n;     uint8_t key; protected:     virtual void parseKey(uint8_t k, char c) {         qDebug() << "key" << (int)k << ":" << c;     } public:     bool done() {         return (state == 6);     }     void reset() {         state = 0;         n = 2;     }     size_t bitstream_len() {         if(state == 6return len;         else return 0;     }     HeaderParser() {         reset();     }     void operator()(char x) {         switch(state) {         case 0: { //record header len             len = (len << 8) | x;             n--;             if(n == 0) {                 n = len & 0x0000ffff;                 if(n == 0x0001) state = 2;  //go key-length-value mode                 else state = 1//go bitstream len             }         } break;         case 1//consume header data             n--;             if(n == 0) {                 n = 2;                 state = 0;             }             break;         case 2:   //parse key             key = x;             if(key == 0x65) {                 n = 4;                 state = 5;             } else {                 n = 2;                 state = 3;             }             break;         case 3: { //record value len             len = (len << 8) | x;             n--;             if(n == 0) {                 n = len & 0x0000ffff;                 state = 4;             }         } break;         case 4: { //consume value             parseKey(key, x);             n--;             if(n == 0) state = 2;         } break;         case 5: { //record bitstream len             len = (len << 8) | x;             n--;             if(n == 0) state = 6//bitstream len acquired         }         case 6:         default:;         }     } };
[修改于 2年2个月前 - 2023/03/05 17:30:28]
学者 机友
2008/10/11注册,1天19时前活动
Cubesat
