python实现阿帕奇的热成像瞄准OSD界面
smith2023/08/05极客DIY IP:广东
代码写得比较简单, 但效果做出来还可以。。。
配合着一个能跑python的win平板和一个热成像摄像头可以玩得不亦乐乎
不过就是电源的问题没解决, 解决了就可以户外了
用这段python代码就可以采集摄像头的数据了,我们接着要做的就是, 在上面画出十字和方框
import cv2
import numpy as np
if __name__ == '__main__':
    cap = cv2.VideoCapture(url)
    while(True):
        ret, frame = cap.read()
        cv2.imshow('frame',frame)
        if cv2.waitKey(1) & 0xFF == ord('q'):
            break
    cap.release()
    cv2.destroyAllWindows()
画的过程不难, 但是毕竟麻烦
话不多说, 直接放出来吧
import cv2
import numpy as np
    img_count = 0
    cap = cv2.VideoCapture('url')
    w  = int(cap.get(cv2.CAP_PROP_FRAME_WIDTH))   # float `width`
    h = int(cap.get(cv2.CAP_PROP_FRAME_HEIGHT))  # float `height`
    CROSS_W = int(w / 8)
    CROSS_H = int(h / 8)
    RETICLE_W_SIZE = int(w / 7)
    RETICLE_H_SIZE = int(w / 7)
    DELTA = 40
    SHIFT = 40
    DASH = 80
    while(True):
        text_color = (255,0,0)
        c1 = int(w/2)
        c2 = int(h/2)
        x1 = int(w/2 - CROSS_W/2)
        y1 = int(h/2)
        x11 = int(w/2 - CROSS_W/2 + DASH/2)
        y11 = int(h/2)
        x2 = int(w/2 + CROSS_W/2)
        y2 = int(h/2)
        x21 = int(w/2 + CROSS_W/2 - DASH/2)
        y21 = int(h/2)
        x3 = int(w/2)
        y3 = int(h/2 - CROSS_H/2)
        x31 = int(w/2)
        y31 = int(h/2 - CROSS_H/2 + DASH/2)
        x4 = int(w/2)
        y4 = int(h/2 + CROSS_H/2)
        x41 = int(w/2)
        y41 = int(h/2 + CROSS_H/2 - DASH/2)
        x5 = int(w/2 - RETICLE_W_SIZE/2 - SHIFT)
        y5 = int(h/2 - RETICLE_H_SIZE/2)
        x51 = int(w/2 - RETICLE_W_SIZE/2 - SHIFT)
        y51 = int(h/2 - RETICLE_H_SIZE/2 +  DELTA)
        x52 = int(w/2 - RETICLE_W_SIZE/2 -SHIFT + DELTA)
        y52 = int(h/2 - RETICLE_H_SIZE/2)
        x6 = int(w/2 + RETICLE_W_SIZE/2 + SHIFT)
        y6 = int(h/2 - RETICLE_H_SIZE/2)
        x61 = int(w/2 + RETICLE_W_SIZE/2 + SHIFT)
        y61 = int(h/2 - RETICLE_H_SIZE/2 +  DELTA)
        x62 = int(w/2 + RETICLE_W_SIZE/2 + SHIFT - DELTA)
        y62 = int(h/2 - RETICLE_H_SIZE/2)
        x7 = int(w/2 - RETICLE_W_SIZE/2 - SHIFT)
        y7 = int(h/2 + RETICLE_H_SIZE/2)
        x71 = int(w/2 - RETICLE_W_SIZE/2 - SHIFT)
        y71 = int(h/2 + RETICLE_H_SIZE/2 -  DELTA)
        x72 = int(w/2 - RETICLE_W_SIZE/2 - SHIFT + DELTA)
        y72 = int(h/2 + RETICLE_H_SIZE/2)
        x8 = int(w/2 + RETICLE_W_SIZE/2 + SHIFT)
        y8 = int(h/2 + RETICLE_H_SIZE/2)
        x81 = int(w/2 + RETICLE_W_SIZE/2 - SHIFT + DELTA)
        y81 = int(h/2 + RETICLE_H_SIZE/2)
        x82 = int(w/2 + RETICLE_W_SIZE/2 + SHIFT)
        y82 = int(h/2 + RETICLE_H_SIZE/2 - DELTA)
        #cv2.line(frame,(x1,y1),(x2,y2),(255,255,255),1,cv2.LINE_AA)
        #cv2.line(frame,(x3,y3),(x4,y4),(255,255,255),1,cv2.LINE_AA)
        cv2.circle(frame, (c1,c2), radius=0, color=(255, 255, 255), thickness=-1)
        cv2.line(frame,(x1,y1),(x11,y11),(255,255,255),1,cv2.LINE_AA)
        cv2.line(frame,(x2,y2),(x21,y21),(255,255,255),1,cv2.LINE_AA)
        cv2.line(frame,(x3,y3),(x31,y31),(255,255,255),1,cv2.LINE_AA)
        cv2.line(frame,(x4,y4),(x41,y41),(255,255,255),1,cv2.LINE_AA)
        cv2.line(frame,(x5,y5),(x51,y51),(255,255,255),1,cv2.LINE_AA)
        cv2.line(frame,(x5,y5),(x52,y52),(255,255,255),1,cv2.LINE_AA)
        cv2.line(frame,(x6,y6),(x61,y61),(255,255,255),1,cv2.LINE_AA)
        cv2.line(frame,(x6,y6),(x62,y62),(255,255,255),1,cv2.LINE_AA)
        cv2.line(frame,(x7,y7),(x71,y71),(255,255,255),1,cv2.LINE_AA)
        cv2.line(frame,(x7,y7),(x72,y72),(255,255,255),1,cv2.LINE_AA)
        cv2.line(frame,(x8,y8),(x81,y81),(255,255,255),1,cv2.LINE_AA)
        cv2.line(frame,(x8,y8),(x82,y82),(255,255,255),1,cv2.LINE_AA)
        cv2.putText(frame,'Thermal IR',(64,64),cv2.FONT_HERSHEY_COMPLEX,1,(255,255,255),1,cv2.LINE_AA)
        if cv2.waitKey(1) & 0xFF == ord('s'):
            cv2.imwrite("frame%d.jpg" % img_count, frame)
            img_count = img_count + 1
            print("save one frame ok!")
            break
    cap.release()
如果你身边没有热成像摄像头, 用一般的摄像头也可以, 但是
这一行要换成自己的摄像头地址
[修改于 1年3个月前 - 2023/08/06 10:03:48]
来自:综合交流区 / 极客DIY
smith 作者
1年3个月前 IP:广东
923647
改进了一下,
后面再考虑加上测距和陀螺仪模块
smith
2015/01/11注册,3秒前活动
收音机爱好者
IP归属地:广东
