原作者:博派专利论坛的cys网友。经过了编辑和整理。
abnormal engine noise diagnosis equipment 异响诊断仪
abnormal handling 异常处理
abnormal knocking 异响
abrasion wear; scratching 磨损
abrasive belt grinding machine 砂带磨床
abrasive belt gringding 砂带磨削
abscissa 横坐标
absolute dimensional factor 绝对尺寸系数
absolute motion 绝对运动
absolute velocity 绝对速度
AC arc welding machine 交流弧焊机
accelerated run 赶点
acceleration 加速度
acceleration analysis 加速度分析
acceleration diagram 加速度曲线
accidental defect 事故性缺陷
acetate fiber plastics 醋酸纤维塑料
acetylene 乙炔
acetylene cylinder 乙炔罐
acetylene generator 乙炔发生器
acetylene-welding installation 乙炔氧焊装置
acid dip tank 浸酸槽
acid refined oil 酸性精炼油
acidity 酸度
acid-prrof coating 耐酸涂料
acknowledged rule of technology 公认的技术规则
acme thread form 梯形螺纹
acrylonitrile-butadiene- styrene polymer ABS 共聚体
active plate 活动板
actual line of action 实际啮合线
actuating cable 控制电缆
add lubricating oil 加润滑油
addendum 齿顶高
addendum circle 齿顶圆
addition to standard 标准补充件
additional element 附加要素
additon agent 添加剂
adhesion 粘附
adjustable speed motors 调速电动机
adjusting 调整
administration/general affairs dept 总务部
admisinstrative regulation for adopting internatinal standards 采用国际标准管理办法
admisistration of vehicle amintenance 汽车维修管理
admisistrative standard 管理标准
adopting by equation 等同采用
adopting by equivalent 等效采用
adopting by reference 参照采用
adoption of international standard and advanced oversea standard 采用国际标准和国外先进标准
advance-to return-time ratio 急回系数
advance-to return-time ratio 行程速比系数
advisory service of standard information 标准情报咨询服务
after dripping (柴油喷射系)渗漏滴油
ageing 时效
ageing 老化
aims of standardization 标准化的目的
air circuit breaker 空气断路器
air dry 自然干燥
air jarring moulding machine 气动震实造型机
air pipe 气管
air seal 气幕
air spray gun 空气喷枪
air spring 空气弹簧
air terminal 航空集散站
air tool 风动工具
air-conditioning equipment 车厢空调设备
air-cushion eject-rod 气垫顶杆
airless spray equipment 无空气喷涂设备
alcohol 乙醇
alcohol container 沾湿台
alcohols solvent 醇类溶剂
aligning 校正
alkalidipping 脱脂
alkali-earth babbitt 碱土巴氏合金
alkaline degreasing 碱法脱脂
alkaline etch 龄咬
allowable amount of unbalance 许用不平衡量
allowable pressure angle 许用压力角
allowable stress; permissible stress 许用应力
alloy cast iron 合金铸铁
alloy structureal steel 合金结构钢
alloy tool steel 合金工具钢
alternation switch 转换开关
alumel 铝镍合金
aluminied steel sheet 渗铝钢板
aluminium bronze 铝青铜
aluminium casting alloy 铸造铝合金
aluminizing 渗铝
aluminum powder paint 铝粉漆(银色漆)
amended draft 修正草案
amendment to standard 标准修改件
amino plastics 氨基塑料
amino-filler 氨基腻子
amount of unbalance 不平衡量
amplitude of vibration 振幅
analog-mode device 类模器
analysis of mechanism 机构分析
analytical design 解析设计
analytical method 分析法
angle of contact 包角
angular acceleration 角加速度
angular contact ball bearing 角接触球轴承
angular contact bearing 角接触轴承
angular contact radial bearing 角接触向心轴承
angular contact thrust bearing 角接触推力轴承
angular velocity 角速度
angular velocity ratio 角速比
anion electrophoretic coating 阴离子型电泳涂料
anneal 退火
annealing 退火
annealing box 退火箱
annealing furnace 退火炉
annealing oven 退火炉
annex 附录
annular ball baring 径向球轴承
annular spring 环形弹簧
anode mechanical working 阳极机械加工
Anodize 阳性处理
anolyte 阳极电解液
anticorrosive bimetal 耐蚀双金属
anticorrosive paint 防蚀漆
anti-foaming additive 防泡沫添加剂
antifoaming agent 消泡剂
antifouling paint(copper paint) 防污漆
anti-freeze additive 防冻添加剂
antifriction alloy 减摩合金
antifriction bearng 减摩轴承
anti-friction quality 减摩性
anti-knock compound 抗爆剂
antirust paint 防锈漆
anti-tarnish treatment 抗暗处理
aperiodic speed fluctuation 非周期性速度波动
appended description of standard 标准附加说明
application factor 工况系数
applied force 作用力
approved by 核准
approved by / checked by / prepared by 核准/审核/承办
aqua regia 王水
arc welding machine 电弧焊机
Archimedes worm 阿基米德蜗杆
archives of standardization 标准化档案
Arctan 反正切
argon arc welding 氩弧焊
argon welding 氩焊
arm 臂部
armature tester 电枢试验器
artery 干线
articulated bus 通道式公共汽车
articulated equipment 铰接装置
articulated trolly bus 通道式无轨电车
artificial drying 人工干燥
artificial gasoline 人造汽油
artificial leather 人造胶革
artificial resin 人造树胶
artificial wool 人造羊毛
asbestos 石棉
asbestos band 石棉带
asbestos board 石棉板
asbestos fiber 石棉纤维
asbestos linen 石棉布
asbestos paper 石棉纸
asbestos steel leaf 石棉钢片
asbestos web 石棉织物
as-deposited strength 焊后强度
aseptic 防腐剂
assembling clearance 装配间隙
assembly 组装
assembly condition 装配条件
Assembly line 组装线
Assembly line 组装线
assistant manager 助理
Assur group 杆组
as-welded 焊态
atlas 图册、图谱
atomosphere quality standard 大气质量标准
attendant seat 乘务员座椅
augular offset 角度偏差
ausforming 形变热处理
austenite 奥氏体
authority 权力机构
autoclino 自动壳型机
automatic box splitter 自动分箱机
automatic closer 自动合箱机
automatic compensating device for boring cutter wear 镗刀磨损自动补偿装置
automatic gas cutting 自动气割
automatic headstock changing N/C machine 自动更换主轴箱数控机床
automatic inspection machine for piston ring tension 活塞环弹性自动检验机
automatic instruction calling device 自动指令呼叫装置
automatic line for weighting connecting rod 连杆称重去重自动线
automatic moulding productio line ofr cylinder block 缸体自动造型生产线
automatic multi-stage cold fromer 多工位自动冷镦机
automatic plating machine 自动电镀装置
automatic production line for automobile final drive housing 汽车主减速器壳加工自动线
automatic production line for connecting rod 连杆加工自动线
automatic production line for cranshaft dynamic balance 曲轴动平衡自动线
automatic production line for cylinder block 气缸体加工自动线
automatic production line for cylinder head 气缸盖加工自动线
automatic production line for gas carburization 气体渗碳自动线
automatic screwdriver 电动启子
automatic sprayer 自动喷漆机
automatic ticket checker 自动检票机
automatic tool changing N/C machine 自动换刀数控机床
automatic welding 自动焊接
automation 自动化
automation 自动化
automobile transportation enterprise 汽车运输企业
automotive alcquer 汽车用喷漆
automotive enamel 汽车漆
automotive topcoat 汽车面漆
auxiliary fuction 辅助功能
available material 良品可使用
average days during major repair of vehicles 汽车大修平均在修车日
average days in plant during major of vehicles 汽车大修平均在厂车日
average interval mileage of major repair of vehicles 汽车大修间隔里程
average main-hours of vehicle maintenance and repair 汽车维修平均工时
average stress 平均应力
average tonnage (passenger seat) 平均吨(客)位
average velocity 平均速度
avional 铝合金
axial contact bearing 轴向接触轴承
axial direction 轴向
axial internal clearance 轴向游隙
axial load 轴向载荷
axial load factor 轴向载荷系数
axial plane 轴向平面
axial thrust load 轴向分力
axial tooth profile 轴向齿廓
axle stand 轮轴架
(be)qualfied, up to grade 合格
babbit metal 巴氏合金
back cone 背锥
back cone angle 背锥角
back cone distance 背锥距
back fire 回火
back flow 回流
backlash 侧隙
backlash 齿侧间隙
backlash 间隙
back-to-back arrangement 背对背安装
bad condition of vehicle 汽车不良状况
baffle plate 挡块
bainite 贝氏体
bakelite 胶木(电木)
baking paint 烘漆
balance 平衡
balance of machinery 机械平衡
balance of mechanism 机构平衡
balance of rotor 转子平衡
balance of rotors 回转体平衡
balance of shaking force 惯性力平衡
balancing centering machine 平衡-钻中心孔机床
balancing machine 平衡机
balancing mass 平衡质量
balancing quality 平衡品质
balancing speed 平衡转速
balata 巴拉塔树胶
balata spring 橡胶弹簧
ball 球
ball bearing 球轴承
ball bearing 球轴承
ball screw 滚珠丝杆
band brake 带式制动器
band-aid 创可贴
bar stock cutting by punching 冲压下料
barcode 条码
barcode 条码
barcode 条码
barcode scanner 条码扫描器
barrel (cylindric) cam 圆柱式凸轮步进运动机构
barrel plating 滚镀
bar-type cylinder gauge 杆式气缸量规
base circle 基圆
base cone 基圆锥
base cylinder 基圆柱
base pitch 基圆齿距
basic dynamic axial load rating 轴向基本额定动载荷
basic dynamic radial load rating 径向基本额定动载荷
basic international standard 基础国际标准
basic rating life 基本额定寿命
basic standard 基础标准
basic static axial load rating 轴向基本额定静载荷
basic static radial load tating 径向基本额定静载荷
basic terms 基本术语
basket 蝴蝶竺
batch furnace 分批炉
battery hydrometer 蓄电池液体比累计
battery welder 蓄电池式焊机
be put in storage 入库
beacon 警示灯
bead 焊道
bead cracking 焊道裂纹
bead welding 堆焊
beading stress 弯曲应力
bearing 轴承
bearing alloy 轴承合金
bearing alloy 轴承合金
bearing block 轴承座
bearing bore diameter 轴承内径
bearing bush 轴瓦、轴承衬
bearing cap 轴承盖
bearing capacity 承载能力
bearing capacity factor 承载量系数
bearing clearance 轴承间隙
bearing cone 轴承内圈
bearing cup 轴承外圈
bearing cup 轴承盖
bearing height 轴承高度
bearing life 轴承寿命
bearing metal 轴承合金
bearing outside diameter 轴承外径
bearing race 轴承座圈
bearing ring 轴承套圈
bearing saddle 轴承座
bearing score 拉瓦
bearing shell 轴瓦
bearing shim 轴承垫片
bearing steel 轴承钢
bearing width 轴承宽度
beeswax 蜂蜡
behind schedule 晚点
belleville spring 碟形弹簧
belt driving 带传动
belt pulley 带轮
bender 弯曲机
bending die 压弯模
bending moment 弯矩
bending press 压弯机
bending-beading die 压弯压筋模
bending-curling die 压弯卷圆模
bending-flanging die 压弯翻边模
beryllium bronze 铍青铜
bevel gear 锥齿轮
bevel gears 圆锥齿轮机构
bevel pulley; bevel wheel 锥轮
bezel 斜视规
bezel panel 面板
bezel panel 面板
bibliography 文献书目
bilaterally harmonized standard 双边协调标准
biliographical reference 书目参考目录
bimetal strip from tin-aluminium alloy 高锡铝合金双金属带
binder 粘合剂
bisector 平分线
bituminous paint 沥青漆
black box 黑箱
black washer 黑皮垫圈
blacksmith welding 锻焊
blank 制坯
blank 齿轮轮坯
blank 轮坯
blanker 落料机
blanking 穿落模
blanking die 落料模
blanking-coining die 落料压印模
blanking-slotting die 落料切槽模
blend solvent 溶合溶剂
blinster 气泡
block diagram 框图
block hammer 落锤
blow-by 串气
blow-by meter 曲轴箱窜气量测定仪
blower 鼓风机
blueing 发蓝处理
blush 导色
board 看板
body bumping tool 车身修整工具
body guidance mechanism 刚体导引机构
body of a normative document 一个标准文件的主体
bold line 粗线
bolt 螺栓
bolt 螺栓
bolt 螺栓
bolts 螺栓
bone gum 骨胶
booth 喷漆室
boring 镗削
boring 镗
boring hole 镗孔
boron steel 硼钢
boronizing 渗硼
bottom clearance 顶隙
bottom die(counter die) 下模
boundary dimension 外形尺寸
box furnace(muffle furnace) 马弗炉
box molding machine 有箱造型机
boxing 环焊
bracket 小磁导
brake 制动器
brake bleeder 制动系空气排除器
brake depresor 制动踏板压下器
brake drum lathe 制动鼓车床
brake fade 制动失效
brake flusher 制动液自动更换装置
brake shoe grinder 制动蹄片磨削装置
branch 支线
branch line 岔线
brass 黄铜
brazing by flame 火焰钎焊
breakdown 断裂
bridge type baking oven 桥式烘干室
bright coating 光亮镀层
bright washer 光垫圈
brightener 光亮剂
brittleness 脆性
broaching 拉削
broaching gear 拉齿
bronze 青铜
bulk goods 散装货物
burn rubber 轮胎烧耗
burning 烧伤
burnishing 磨光(抛光0
burnishing 抛光
burr(金属)毛边 flash(塑件)毛边
bus bay 港湾式车站
bus priority sytem 公共汽车优先通行系统
bus shelter 候车亭
bushing block 衬套
business law and regulation 企业法规
butt resistance welding 电阻对焊
butt seam welding 滚对焊
butt welding 对接焊
buttress thread form 锯齿形螺纹
buzzle 蜂鸣器
buzzle 蜂鸣器
cabin 客舱
cable bracket 电缆托架
cadmium bronze 镉青铜
cage 保持架
calcium carbide 电石
calculated bending moment 计算弯矩
cam 凸轮
cam , cam mechanism 凸轮机构
cam block 滑块
cam driver 铡楔
cam profile 实际廓线
cam profile 凸轮廓线
cam with oscillating follower 摆动从动件凸轮机构
camber gauge 外倾测量器
camphor 樟脑
camsahft coping lathe 凸轮轴仿形车床
camshaft grinding machine 凸轮轴磨床
camshaft polishing machine 凸轮轴超精磨机床
camshaft polishing machine 凸轮轴抛光机床
camshaft(journal )turning lathe 凸轮轴(轴颈)车床
cantilever beam 悬臂梁
cantilever structure 悬臂结构
capability 能力
car row 车列
car stand (jack stand) 汽车架
carbide to water generator 投入式乙发生器
carbon arc welding 碳弧焊
carbon electrode 碳极
carbon fouling (火花塞)积碳
carbon structureal steel 普通碳素结构钢
carbon tool steel 碳素工具钢
carbon-fiber reinforced plastics 碳纤维增强塑料
carbonitriding (cyaniding) 碳氮共渗(氰化)
carbonization 碳化
carburetor icing 化油器结冰
carburizing 渗碳
carburizing alloy steel 渗碳合金钢
carburizing carbon steel 渗碳碳素钢
carburizing furnace 渗碳炉
card of goods 货卡
carriage 车厢
Cartesian coordinate manipulator 直角坐标操作器
carton 纸箱
carton 纸箱
carton box 纸箱
cascade speed control 串级调速
case-based design,CBD 基于实例设计
cash fare 普通票
casing head gasoline 气体汽油
cast bronze 锻造青铜
cast iron 铸铁
cast steel 铸钢
catalog 目录
cathode shiedl 阴极罩
catholyte 阴极电解液
cating machine 浇注机
cation electrophoretic coating 阳离子型电泳涂料
cause analysis 原因分析
cause description 原因说明
cavitation 穴蚀
cellophane 赛璐酚
celluloid 赛璐珞
cellulose acetate 醋酸纤维(脂)
cement gum 胶泥
cementite 渗碳体
center distance 中心距
center distance change 中心距变动
center of mass 质心
center of pressure 压力中心
centerless grinding 无心磨削
central gear 中心轮
centralized transportation 集中运输
centrifugal force 离心力
centrifugal force 向心力
centrifugal seal 离心密封
centrifugal stress 离心应力
cetane number 十六烷值
chain 链条
chain 链条槽
chain 链
chain dotted line 点划线
chain gearing 链传动装置
chamfer 倒角
chamois 麂皮
change gear change wheel 变速齿轮
character die 字模
characteristics 特性
chartered vehicle 包车
chassis 基座
chassis 底座
chassis 基座
chassis dynamometer 底盘测功机
chassis lubricator 底盘润滑机
check nut 锁紧螺母
checked by 初审
check-up 技术检查
chemical -heat treatment 化学热处理
chemical mechanical working 化学机械加工
chemical vaporous depositon 化学气相沉积法
chemical wear 化学磨损
chilled cast rion 冷激铸铁
chloroprene rubber 氯丁橡胶
Chromate 铬酸处理
chrome bronze 铬青铜
chromel 铬镍合金
chuck for grinding hole and end face of bevel gear 磨圆锥齿轮孔和端面用的卡盘
circuit breaker cabinet 断路器柜
circular bending die 压圆模
circular gear 圆形齿轮
circular pitch 齿距
circular pitch; pitch of teeth 节距
circular thickness 圆弧齿厚
circulating power load 循环功率流
circulation 周转
city monthly ticket 市区月票
city passenger flow 市区客流
city transposrtation 市区运输
class of vehicle maintenance 汽车维护类别
class of vehicle repair 汽车修理类别
classification 整理
classification of standards document. 标准文献分类
cleaner 清洗剂
cleaning cloth 抹布
cleaning cloth 抹布
cleanness 清扫
clearance 径向间隙
clockwise 顺时针
clogged filter 滤清器阻塞
close type socket joint 封闭式插接
closed chain mechanism 闭链机构
closed kinematic chain 闭式链
cloud point 浊点
club car 高尔夫球车
clutch 离合器
clutch explosion 离合器炸裂
coarse thread 粗牙螺纹
coating for protection against corrosion 防腐镀层
code fo practice 实施规则
coefficient of availability of vehicle 车辆完好率
coefficient of friction 摩擦系数
coefficient of speed fluctuation 机械运转不均匀系数
coefficient of speed fluctuation 速度不均匀 ( 波动 ) 系数
coefficient of travel speed variation 行程速度变化系数
coefficient of utilization of automobile 出车率
coefficient of utilization of ton-kilometers 吨公里利用系数
coefficient of velocity fluctuation 运转不均匀系数
coil stock 卷料
coincident points 重合点
coining press 精压机
coining press 精压机
coke-fired furnace 焦碳炉
cold brittleness 冷脆性
cold draw 冷拉
cold drawing low carbon seamless steel tube 冷拔低碳无缝钢管
cold drawing spring steel 冷拉弹簧钢
cold extruding 冷挤压
cold forging 冷锻
cold forging die 冷锻模
cold pressure welding 冷压焊
cold rinse bank 冷水槽
cold rolled thin steel sheet 冷轧薄钢板
cold rolling killed steel sheet 镇静钢冷轧钢板
cold rolling rimmed steel sheet 沸腾钢冷钆钢板
cold running-in 冷磨合
cold slug 冷块
cold treatment 冷处理
cold trim 冷切边
collapse of piston skirt 活塞裙部挤扁
collection of standard decumnets 标准文献收集
combination in parallel 并联式组合
combination in series 串联式组合
combinaton pliers 鲤鱼钳
combined efficiency; overall efficiency 总效率
combined mechanism 组合机构
combined stress 复合应力
combusion teste 燃烧分析仪
combustion teste 燃烧(废气)分析仪
commercial bronze 工业用铜
common apex of cone 锥顶
common equipment 常用设备
common goods 普通货物
common normal line 公法线
commuter 月票乘客
company standard(enterprise standard) 企业标准
comparable standard 可比标准
compensation 补偿
compensation fare 补票
complementary standard 补充性标准
complete annealing 完全退火
complete failure 完全故障
complete penetration 焊透
complex mechanism 复杂机构
complex steel sheet with chromate zinc 铬酸锌复合钢板
composite tooth form 组合齿形
compound (or combined) gear train 复合轮系
compound combining 复合式组合
compound die 合模
compound die 合模
compound flat belt 复合平带
compound gear train 混合轮系
compound hinge 复合铰链
Compound screw mechanism 复式螺旋机构
compressed gas 压缩煤气
compression strength 抗压强度
compressive stress 压应力
compresson coil spring 压缩螺旋弹簧
compressor 压缩机
compressor oil 压缩机机油
computer aided design, CAD 计算机辅助设计
computer aided manufacturing, CAM 计算机辅助制造
computer integrated manufacturing system, CIMS 计算机集成制造系统
concave 凸
concavity 凹面、凹度
Conceal Install 暗装
concept design, CD 方案设计、概念设计
conclusion 结论
concurred design, CD 并行设计
concurrent engineering 并行工程
condenser tester 电容器试验器
condition of self-locking 自锁条件
conduction of heat 导热性
cone angle 圆锥角
cone distance 锥距
cone-worm milling machine 球面蜗杆铣床
conical roller bearing 圆锥形滚子轴承
conical spring 锥形弹簧
conjugate cam 共轭凸轮
conjugate profiles 共轭齿廓
conjugate yoke radial cam 等径凸轮
connecting rod alignment fixture 连杆矫正器
connecting rod, coupler 连杆
connection box 接线盒
connection test 检查接线
conoid helical-coil compression spring 圆锥螺旋扭转弹簧
conservation 清洁
constantan 康铜
constant-breadth cam 等宽凸轮
constant-velocity (or double) universal joint 双万向联轴节
constitution of mechanism 机构组成
constitution of standard 标准的构成
constraining force 约束反力
constraint 约束
constraint condition 约束条件
consumption 消耗
contact points 啮合点
contact ratio 重合度
contact seal 接触式密封
contact stress 接触应力
container transport 集装箱运输
content 目次
content of normative document 标准文件的内容
continous furnace 连续炉
continuous broaching 连续拉削
control center 调度中心
control panel 控制屏
control station 调度站
Control switches 控制开关
conventional mechanism; mechanism in common use 常用机构
convex 凸的,凸面体
convex 凹
convex roller 球面滚子
Conveyer 流水线物料板
Conveyer 流水线物料板
coolant 冷却液
coordinate 座标
coordinate frame 坐标系
copper 紫铜
Copper core power cable 铜芯电力电缆
copy grinding mahcine 靠模磨床
copy lathe 仿形车床
cork 软木
correcting plane 校正平面
correcting plane 平衡平面
corrigenda 勘误表
corrosion inhibitor 搞腐蚀剂
corrosion resistance 耐腐蚀性
corrosion resisting cast iron 耐蚀铸铁
corrosion wear 腐蚀性磨损
cosine acceleration (or simple harmonic) motion 余弦加速度运动
cosmetic defect 外观不良
cosmetic inspect 外观检查
cost 成本
cost of labor 人工费
coulometer 库仑计
counter sinking 锪孔
counterclockwise (or anticlockwise) 逆时针
counterweight 平衡重
couple 力偶
coupler-curve 连杆曲线
coupling shaft coupling 联轴器
cover plate 盖板
covered arc welding 手工电弧焊
covering power 深镀能力
crank 曲柄
crank angle between extreme (or limiting) positions 极位夹角
crank arm, planet carrier 系杆
crank press 曲轴压力机
crank shaft 曲轴
crank shaft 曲柄轴
crank shaper (guide-bar) mechanism 曲柄导杆机构
crank-rocker mechanism 曲柄摇杆机构
cranksahft journal grinding machine 曲轴主轴颈磨床
crankshaft (main journal turning lathe) 曲轴(主轴颈)车床
crankshaft dynamic balancing machine 曲轴动平衡机
crankshaft grinding machine 曲轴磨床
crankshaft journal face hardening machine 曲轴轴颈表面淬火机床
crankshaft journal milling machine 曲轴轴颈铣削专用机床
crankshaft polishing machine 曲轴轴颈抛光机床
crankshaft superfinishing machine 曲轴超精磨机床
crankshaft turning lathe 曲轴车床
creation design 创新设计
crepon finish 皱纹漆
crimp paper 瓦楞纸
critical defect 极严重缺陷
critical failure 致命故障
critical point 临界点
critical speed 临界转速
cross grinding 端面磨削
cross weld 横向焊缝
cross-belt drive 交叉带传动
crossed helical gears 交错轴斜齿轮
crossover 交叉器
cross-shaped joint 十字接头
crown gear 冠轮
crown shaving 剃鼓形齿
crusher 破碎机
cryptometer 遮盖力测定仪
crystallization point 结晶温度
CSBS yearbook 中国标准化年鉴
cst bimetal 铸造双金属
culture 教养
cupola (cupola furnace) 冲天炉
curb window 安全监视窗
curling 卷边
Current by Phase 每相电流
current repair of vehicle 汽车小修
curvature 曲率
curve matching 曲线拼接
curved-shoe follower 曲面从动件
curve-tooth bevel gear milling 弧齿锥齿轮铣刀盘刃
curve-tooth bevel gear milling machine 弧齿锥齿轮铣齿机
curvilinear motion 曲线运动
cushion 缓冲
cut-off (shear-out) 切口
cutter 刀具
cutter grinding machine 工具磨床
cutting machine 切割机
cutting-out press 切断压力机
cyaniding 氰化
cycle 周波
cycle of motion 运动周期
cycloidal gear 摆线齿轮
cycloidal motion 摆线运动规律
cycloidal tooth profile 摆线齿形
cycloidal-pin wheel 摆线针轮
cylinder block broaching machine 气缸体专用拉床
cylinder block side broaching machine 气缸体侧拉床
cylinder boring machine 镗缸机
cylinder compression gauge 气缸压力表
cylinder honing machine 气缸珩磨机
cylinder leak tester 气缸漏气率检验仪
cylinder perpendicularity gauge 气缸孔垂直检验仪
cylinder pressure gauge 气缸压力表
cylinder score 拉缸
cylinder sticking 咬缸
cylindric pair 圆柱副
cylindrical cam 圆柱凸轮
cylindrical coordinate manipulator 圆柱坐标操作器
cylindrical grinding 外圆磨削
cylindrical roller 圆柱滚子
cylindrical roller bearing 圆柱滚子轴承
cylindrical worm 圆柱蜗杆
cylindroid helical-coil compression spring 圆柱螺旋压缩弹簧
cylindroid helical-coil extension spring 圆柱螺旋拉伸弹簧
cylindroid helical-coil torsion spring 圆柱螺旋扭转弹簧
D.C traction substation 直流牵引变电站
D.I. rinse 纯水次
daily sevice 每日保养
damage 损坏
date of standard implementation 标准实施日期
dated reference (to standards) 注明日期的引用(标准)
day and night line 昼夜线路
day and night vehicle 昼夜车
dead point 死点
deadener 防声胶
decantation 沉淀法
decelerated run 压点
decentralized transportation 分散运输
decision items 决议事项
decoiling unit 开卷机
dedendum 齿根高
dedendum circle 齿根圆
deemed-to-satisfy provision 认为满足规定
deep drawing sheet 深冲压用薄钢板
deep drawng 拉伸
deep groove ball bearing 深沟球轴承
deep hole working 深孔加工
deep penetration electrode 深熔焊条
deep penetration welding 深溶焊
defect 缺陷
defective product box 不良品箱
defective product label 不良标签
defective product/non-good parts 不良品
defective products 不良品
defective products, not up-to-grade products 不良品
defective shock absorber 减震器失效
defective to staking 铆合不良
defective upsiding down 抽芽不良
defective vacuum advance 真空提前失效
deficient manufacturing procedur 制造过程不良
deficient purchase 来料不良
definitive standard 限定性标准
deformation 变形
deformation 变形
deformation 变形
degate 打浇口
degrease 脱脂
degreasing 去油(脱脂)
degree of adoption 采用程度
degree of freedom, mobility 自由度
degree of reliability 可靠度
dejecting 顶固模
delamination 起鳞
delivery deadline 交货期
demagnetization 去磁;消磁
demin-water 去离子水
denominator 分母
dense deposits 焊肉致密
dents 压痕
dents 压痕
department 部门
department director 部长
depersonalized repairmethod 混装修理法
deposition techniques 熔敷工艺
depth of cut 切齿深度
deputy manager | =vice manager 副经理
deputy manager | =vice manager 副理
deputy section supervisor =vice section superisor 副课长
derivative 导数
derusting 除锈
derusting machine 除锈机
description for drawing up standard 标准编制说明
descriptive provision 叙述规定
descriptor 叙词
design constraints 设计约束
design defect 设计缺陷
design for product`s life cycle, DPLC 面向产品生命周期设计
design methodology 设计方法学
design variable 设计变量
deslag 去渣
desmut 剥黑膜
detecting test of vehicle 汽车检测
detecting test station of vehicle 汽车检测站
detergent 去垢剂
detergent 净化剂
detonation 爆震(爆燃)
detrimental resistance 有害阻力
diagnostic norms 诊断规范
diagnostic parameters 诊断参数
diagonal shaving 对角剃齿法
diameter series 直径系列
diametral pitch 径节
diametral quotient 蜗杆直径系数
diametral quotient 直径系数
diamond fine boring machine 金刚镗床
die casting machine 压铸机
die change 换模
die for first-forming 预弯模
die forging 模锻
die lifter 举模器
die locker 锁模器
die locker 锁模器
die quenching of automotive driven bevel gear 汽车从动锥齿轮淬火压模
die repair 模修
die worker 模工
diesel fuel 柴油
diesel index 柴油指数
dieseling (after run) 自燃现象
difference quantity 差异量
differential 差速器
differential gear train 差动轮系
differential screw mechanism 差动螺旋机构
differential screw mechanism 微动螺旋机构
diffusion annealing 扩散退火
dilution 稀释
dimension series 尺寸系列
dimension/size is a little bigger 尺寸偏大(小)
dip equipment 浸漆设备
dip tank 浸漆槽
dip-coatng 浸涂
dipped electrode 手涂焊条
direct (forward) kinematics 正向运动学
direct current feed control panel 直流馈电屏
direct distilled gasoline 直馏汽油
direct welding 双面点焊
directive standard 指导性标准
disassembling 拆卸
disc brake 圆盘制动器
disc friction clutch 圆盘摩擦离合器
disc lathe 制动盘专用车床
disc runout 制动盘摆动
disc spring 碟形弹簧
discoloration 羿色
disk cam 盘形凸轮
disk-like rotor 盘形转子
dismantle the die 折模
dispatch point for goods 货物发送点
dispersing agent 分散剂
displacement 位移
displacement diagram 位移曲线
disposed goods 处理品
disposed products 处理品
distillation range 馏程
distillaton test 蒸馏试验
division of standard 标准的单元
document.nbspindexing 文献标引
door light 门灯
door opening degree 车门开度
double coated electrode 双层药皮焊条
double countercurrent rinse tank 双联冷水槽
double crank mechanism 双曲柄机构
double Haas planer 龙门刨床
double head spray gun 双头喷枪
double housing planer 龙门刨床
double pillar jig borer 双柱坐标镗床
double rocker mechanism 双摇杆机构
double roller chain coupling 滚子链联轴器
double row bearing 双列轴承
double slider coupling; Oldham‘s coupling 十字滑块联轴器
double-chain conveyer 推杆悬链
double-deck bus 双层公共汽车
double-direction thrust bearing 双向推力轴承
double-ended spanner 双头扳手
double-post carnkshafttruning blathe 双工位曲轴车床
double-row ball bearing 双列滚珠轴承
double-slider mechanism, ellipsograph 双滑块机构
double-V butt joint 双V 形对接接头
double-V groove 双V 形坡口
double-vevel groove K 形坡口
down draft spray booth 下吸式喷漆室
draft internation standard 国际标准草案
draft standard for approval 标准报批稿
draft standard for discussion 标准讨论稿
draft standard for examination 标准送审稿
drag form 压锻差
drain area 沥漆区
drawing 拉延
drawing die 拉延模
drawing furnace 回火炉
drill 钻削
drill 铝
driller 钻床
drilling machine 钻床
driven gear 从动轮
driven link, follower 从动件
driven pulley 从动带轮
driven system 传动系统
driver seat 司机座椅
driving force 驱动力
driving gear 主动齿轮
driving link 原动件
driving link 主动件
driving moment (torque) 驱动力矩
driving pulley 主动带轮
drop press 模锻压力机
droplet 熔滴
dropping point 滴点
drum milling machine 转鼓铣床
drum type double face drilling and boring combined machine 转鼓式双面钻镗组合机床
dry grinding 干打磨
dry spray booth 干式喷漆室
dryer 烘干机
dummying 用假阴极电镀
dust collector 除尘装置
dwell 停歇
dwell meter 断电器触点闭合角
dyad II 级杆组
dydraulic coping lathe 液压仿形车床
dynamic analysis design 动态分析设计
dynamic analysis of machinery 机械动力分析
dynamic balance 动平衡
dynamic balancing machine 动平衡机
dynamic characteristics 动态特性
dynamic design of machinery 机械动力设计
dynamic energy 动能
dynamic equivalent axial load 轴向当量动载荷
dynamic equivalent radial load 径向当量动载荷
dynamic load 动载荷
dynamic lubrication 动力润滑
dynamic reaction 动压力
dynamic viscosity 动力粘度
dynamic wheel balancer 车轮动平衡机
dynamically equivalent model 等效动力学模型
dynamics 动力学
dynamics of machinery 机械动力学
earthing bus 接地母线
earthing jumper 接地跨接线
earthing twisted pair 接地绞线
eccentric 偏心盘
eccentric mass 偏心质量
eccentric valve seat grinder 气门座偏心磨光机
eccentricity ratio 偏心率
edge finder 巡边器
edging 折边
edging machine 折边机
EDM 放电机
education and training 教育与训练
effective circle force 有效圆周力
effective resistance 工作阻力
effective resistance moment 工作阻力矩
effective tension 有效拉力
elastic coupling flexible coupling 弹性联轴器
elasticity sliding motion 弹性滑动
electical -contacted type detecting fixture 电接触式检验夹具
electophoretic coating 电泳涂层
electric arc welding 电弧焊
electric brazing 电子加热钎焊
electric condenser 电容器
electric furnace 电炉
electric resistance welding 电阻焊
Electric screw driver 电动起子
electric upsetting machine 电镦机
electric welding 电焊机
electrical grinding 导电磨削
electrical sparkle 电火花
electro apparatus 电泳涂漆设备
electrocoating installation 电涂漆设备
electrode 电极(焊条)
electrogas arc welding 气电焊
electroless plating 化学电镀
electrolysis 电解
electrolyte 电解液
electrolytic cleaner 电解去油槽
electrolytic machining 电解加工
electron (dow metal) 电子合金
electron beam curing 电子束固化
electron beam welding 电子束焊接
electron gun 电子枪
electronic beam machining 电子束加工
electronic -diagnostis engine tester 电子诊断式发动机试验仪
electronic ignition tester 电子点火试验器
electrophoretic primer 电泳底漆
electroplate 电镀
electroplating 电镀
electroslag welding 电渣焊机
electro-spark machining 电脉冲加工
electro-spark machining 电火花加工
electrostatic dust collector 静电除尘装置
electrostatic spray equipment 静电喷漆设备
electro-thermic working 电热加工
electrowinning 电解沉积
eletric welding 电焊
elevated line 高架线路
embedded lump 镶块
embedded lump 镶块
emergency exit 安全门
emergency pulbic transport system 应急公共交通系统
EMI gasket 导电条
EMI gasket 导电条
enamel 面漆
enamel paint 瓷漆
end-effector 末端执行器
energy 能量
engagement, mesh, gearing 啮合
engaging-in 啮入
engaging-out 啮出
engine analysis apparatus 发动机分析仪
engine analyzer 发动机综合试验机
engine dynamomete 发动机测功机
engine oil 发动机油
engine scope(oscillograph0 发动机示波器
engineering 工程
engineering, project difficulty 工程瓶颈
enterprise of vehicle maintenance and repair 汽车维护企业
enterprise plan = enterprise expansion projects 企划
enterprise standardization 企业标准化
environmental protection law 环境保护法
environmental protection standard 环境保护标准
epicyclic gear train 周转轮系
epoxy paint 环氧树脂漆
epoxy resin electrophoretic primer 环氧电泳底漆
epoxy resin filler 环氧腻子
epoxy resin(EP) 环氧树脂
equilibrium 力平衡
equipment 设备
equivalence of standards 标准的等效性
equivalent 等效量
equivalent coefficient of friction 当量摩擦系数
equivalent force 等效力
equivalent link 等效构件
equivalent load 当量载荷
equivalent mass 等效质量
equivalent mechanism 替代机构
equivalent moment of force 等效力矩
equivalent moment of inertia 等效转动惯量
equivalent spur gear of the bevel gear 锥齿轮的当量直齿轮
equivalent spur gear of the helical gear 斜齿轮的当量直齿轮
equivalent spur gear; virtual gear 当量齿轮
equivalent teeth number; virtual number of teeth 当量齿数
escalator 自动扶梯
esters solvent 酯类溶剂
etch primer 磷化底漆
ether solvent 醚类溶剂
ethylene-propylene rubber (EPR) 乙烯丙烯橡胶
ethylized gasoline 乙基汽油
eutectic 共晶
eutectic alloy 共晶合金
evaluation 评估
evaluation and decision 评价与决策
evenign peak 晚高峰
excessive consumption of fuel and oil 费油
excessive defects 过多的缺陷
excesssive gap 间隙过大
exclusive requirement 必要要求
executive autority 执行机构
executive link; working link 执行构件
expanded plastics 多孔塑料(泡沫塑料)
expansion dwg 展开图
Explosion-proof socket 防爆插座
exposed metal/bare metal 金属裸露
express bus 快车
express bus stop 快车站
express line 快车线路
extension coil spring 拉伸螺旋弹簧
external force 外力
external gear 外齿轮
external loads 工作载荷
extra vehicle 加班车
extreme (or limiting) position 极限位置
extruded electrode 机械压涂焊条
extrusion 挤压
extrusion finishing 挤压光加工
extrusion press 挤压机
eye bolt 吊环螺栓
face width 齿宽
face width 平底宽度
face-to-face arrangement 面对面安装
face-up bonding 仰焊
factor 系数
factor of stress concentration 应力集中系数
factored moment; calculation moment 计算力矩
factory director 厂长
factory director 厂长
failure rate 故障率
failure wear 故障磨损
fare 票价
fare ticket type 票类
fare-kilometre 票价里程
fasten 锁紧(螺丝)
fasten 锁紧(螺丝)
fastener 紧固件
fatigue 疲劳
fatigue limit 疲劳极限
fatigue strength 疲劳强度
fatigue wear 疲劳磨损
fault tree analysis 故障树型分析法
feather key 滑键、导键
feature change 特性变更
feature die 公母模
feedback combining 反馈式组合
feeder 送料机
feeder 馈线
feeder network 馈线网
feeding is not in place 送料不到位
feeler gauge 厚度规
felt 毛毡
felt ring seal 毡圈密封
female die 母模
ferrisulphas 硫酸亚铁
ferrite 铁素体
ferrofluid seal 铁磁流体密封
ferrous metal 黑金属
fiber carton 纤维纸板
fiber washer 纤维垫圈
field balancing 现场平衡
field fo standardization 标准化领域
file 锉刀
fillet 镶;嵌边
fillet radius 圆角半径
fillister(raised cheese)head screw 球面圆柱头螺钉
final boiling point 干点
final contact, end of contact 终止啮合点
final inspection 终检
final inspection 终检
final run vehicle 末班车
fine threads 细牙螺纹
fineness gauge 细度计
finish heat treatment 最终热处理
finish primer 末道底漆
finish varnish 罩光清漆
finished product 成品
finished products 成品
fire-cracker welding 躺焊
first -run vehicle 首班车
first step height 一级踏板高度
fit together 组装在一起
fit together 组装在一起
fitting 装配
fixed line 固定线路
fixed link; frame 固定构件
fixture 夹具(治具)
fixture 夹具(治具)
flake 白点
flame case hardening 火焰加热表面淬火
flange coupling 凸缘联轴器
flanging 翻边
flanging forming die 翻边成形模
flash off 凉干
flat belt 平带
flat belt driving 平带传动
flat fare 单一票制
flat leaf spring 板簧
flat position welding 平焊(俯焊)
flat spot 过度停顿
flat steel 扁钢
flat(countersunk)head screw 沉头螺钉
flat-die forging 自由锻造
flat-face follower 平底从动件
flattening 压扁
flattening die 压扁模
flexible automation 柔性自动化
flexible impulse; soft shock 柔性冲击
flexible manufacturing system; FMS 柔性制造系统
flexible rotor 挠性转子
flexspline 柔轮
float level gauge 浮子室液面仪
flocculant 絮凝剂
floor 地板
floor height 车厢地板高度
floor model 落地式
flow board 流水板
flow chart 流程表单
flow coating equipment 热喷漆机
flow coating equipment 淋漆设备
flow method of vehicle maintenance 汽车维护流水作业法
flow of freight 货流
fluctuating circulating stress 脉动循环应力
fluctuating load 脉动载荷
flush 冲洗
fluttering 振抖
flyspun electrode 包丝焊条
flywheel 飞轮
foam plastics 泡沫塑料
foaming inhibitor 泡沫抑制剂
fold of pakaging belt 打包带折皱
folding machine 卷边机
follower dwell 从动件停歇
follower motion 从动件运动规律
force 力
force polygon 力多边形
forced vibration 强迫振动
force-drive (or force-closed) cam mechanism 力封闭型凸轮机构
forefinger 食指
forge 锻造
forging 锻造
forging blank 锻造毛坯
forging die 型锻模
forging die 锻压机
forging hammer without anvilbed 无砧坐模锻锤
forging roll 辊锻机
forklift 叉车
forklift 叉车
forklift 叉车
form block 折刀
form broaching 成型拉削
form cutting 仿形法
form factor 齿形系数
forming 成形
forming die 精整模
four-bar linkage 四杆机构
frame gauge 车架量规
frame, fixed link 机架
framework of standard 标准的结构
free acceleraton engine tester 发动机加速测功仪
free cutting steel 易削钢
freezing inhibitor 防冻剂
freezing point 凝固点
freezing point; solidifying point 凝固点
freight bill(freight notes) 运费单
freight flow diagram 货流图
freight rate 运费率
freight tariff 运费表
freight transportation 货物运输
frequency 频率
frequency control of motor speed 变频调速
frequency converters 变频器
frequency of current repair of vehicles 汽车小修频率
frequency of vibration 振动频率
fretting 侵蚀
friction 摩擦
friction angle 摩擦角
friction circle 摩擦圆
friction force 摩擦力
friction moment 摩擦力矩
frictional resistance 摩擦阻力
frog 分线器
front fillet weld 正面角焊缝
front number plate 前路牌
front plate 前板
front plate 前板
fuel 燃料(燃油)
fuel density 燃油密度
fuel distillation range 燃油馏程
fuel fouling 呛油
fuel knock(gas knock) 燃料爆燃
fuel mixture 燃油混合气
fuel specific gravity 燃油比重
fuel vapor pressure 燃油蒸气压力
full balance of shaking force 惯性力完全平衡
full fare 全程票价
function analyses design 功能分析设计
function generation 函数生成
function generator 函数发生器
fundamental mechanism 基础机构
fungus proof paint 防霉涂料
fuse machine 热熔机
fuse machine 热熔机
fuse together 熔合
fuse together 熔合
fusion welding 熔焊
fuzzy evaluation 模糊评价
fuzzy set 模糊集
galvanized iron 白铁
galvanized steel sheet 镀锌钢板
galvanizing 镀锌
garbage bag 垃圾袋
garbage can 垃圾箱
garbage container 灰箕
gas bearing 气体轴承
gas cylinder 气瓶
gas mark 焦痕
gas pressure welding 加压气焊
gas shield arc welding 气体保护电弧焊
gas shielded magnetic flux arc welding 磁性气体保护焊
gas welding 气焊
gas-fired furnace 煤气炉
gasket 垫圈
gasket seal 垫片密封
gasoline (petrol) 汽油
gauge 轨距
gauge(or jig) 治具
gauge(or jig) 治具
gear 齿轮
gear 齿轮机构
gear burnishing machine 挤齿机
gear coupling 齿轮联轴器
gear extruding 挤齿
gear face machining 齿面加工
gear grinding 磨齿
gear grinding machine 齿轮磨床
gear hardening press 齿轮淬火压床
gear hobbing 滚齿
gear honing 珩齿
gear honing machine 珩齿机
gear lapping 研齿
gear milling 铣齿
gear oil 齿轮油
gear planing 刨齿
gear ratio 齿数比
gear shaper 插齿机
gear shaping 插齿
gear shaving 剃齿
gear shaving machine 剃齿机
gear train 轮系
gear wheel 大齿轮
gear-cutting with form copying method 仿形法切齿
gear-cutting with generating method 展成法切齿
gearing; transmission gear 传动装置
gearrolling mill 齿轮滚轧机
gelatin 动物胶
general constraint 公共约束
general manager 总经理
general manager 总经理
general monthly ticket 通用月票
general shaving 普通剃齿法
general standard 通用标准
generalized coordinate 广义坐标
generalized kinematic chain 一般化运动链
generating 展成法
generating cutting 范成法
generating line 发生线
generating line of involute 渐开线发生线
generating plane 发生面
generation mechanism 广义机构
generator 发电机
generator control panel 发电机控制面板
generator gas 发生炉煤气
Geneva mechanism 槽轮机构
Geneva numerate 槽数
Geneva wheel 槽轮
Geneva wheel Geneva gear 马耳他机构
glaring 出光
glass cloth 玻璃布
glass-fiber reinforced plastics 玻璃纤维增强塑料
glazing 罩光
glossmeter 光泽计
glove(s) 手套
glove(s) with exposed fingers 割手套
glue stripper 脱胶剂
glue(gum) 胶
good condition of vehicle 汽车完好技术状况
good product/accepted goods/ accepted parts/good parts 良品
good products 良品
goods transportation 货物运输
goods-circulating quantity 货物周围量
gouge 沟槽;凿槽
government standard 政府标准
governmental regulation 政府规程
governor hunting 调速器工作不匀
Grade of Protection 防护等级
grain size 晶体大小
granule=peuet=grain 细粒
graphical method 图解法
Grashoff`s law 格拉晓夫定理
Grashoff`s law 曲柄存在条件
gravimeter 比重计
grease 黄油
grease gun 黄油枪
grease/oil stains 油污
green design design for environment 绿色设计
grey cast iron 灰铸铁
grey cast iron 灰铸铁
grind 磨
grinder 磨床
grinder 磨床
grinding 磨削
grinding machine for spiral spring 弹簧端面磨床
grinding paster 打磨膏
grinding wheel groove 砂轮越程槽
grit 砂砾
grit 沙砾
grit maker 抽粒机
groove cam 槽凸轮
groove punch 压线冲子
groove welding 坡口焊
ground glass 毛玻璃
ground line 地面线路
grounding chanin 接地链
group leader/supervisor 组长
gum deposit 结胶
gum resin 树胶脂
gypsum 石膏
gyroscope 陀螺仪
H. Hertz equation 赫兹公式
half-killed steel 半镇静钢
hammer finish 锤纹面漆
hammer forging 锤锻(自由锻)
hand dip equipment 手工浸漆设备
hand held gun 手动焊枪
hand torch 手动焊炬
handrail 扶手
hands of worm 蜗杆旋向
hard pedal 制动踏板费力
hardenability 淬硬性(淬透性)
hardened and tempered steel 调质钢
hardened glass 钢化玻璃
hardening 淬火
hardening and high temperature tempering 调质
haring cell 哈林电槽
harmonic driving 谐波传动
harmonic gear 谐波齿轮
harmonic generator 谐波发生器
harmonization of standards 标准的协调
harmonized stndard 协调标准
hastelloy electrode 合金焊条
head light checking equipment 前照灯检验仪
head of screwdriver 起子头
headless screw 无头螺钉
hearth 炉床
heat balance; thermal equilibrium 热平衡
heat dissipation 热传
heat resisting steel 耐热钢
heat treatment 热处理
heat treatment furnace 热处理炉
heater band 加热片
heating frunace 加热炉
heat-resistant paint 耐热漆
heavy metal 重金属
heavy-duty oil 重工况润滑油
height series 高度系列
height series 高度系列
helical bevel gear 螺旋锥齿轮
helical gear 斜齿圆柱齿轮
helical pair 螺旋副
helical torsion spring 扭簧
helix ,helical line 螺旋线
helix angle 螺旋角
helix angle at reference cylinder 分度圆柱螺旋角
helmet shield 焊工用面罩
herringbone gear 人字齿轮
hexagon bolt 六角头螺栓
hexagon nut 六角螺母
hexagonal plating barrel 六角滚筒
hezagon castle (slotted )nut 开槽六角螺母
hide glue 皮胶
high frequency case hardening 高频表面淬火
high gloss finish 高光泽面漆
high pressure blasting machine 喷丸机
high pressure cabinet 高压柜
High Pressure Mercury Lamp 高压汞灯
high pressure moulding machine 高压造型机
High Pressure Sodium Lamp 高压钠灯
high speed belt 高速带
high speed boringh 高速精镗
high speed cropping machine 高速棒料剪切机
high speed cutting 高速切削
high speed hobbing 高速滚削
high speed steel 高速工具钢
high strength duralumin 高强度锻造铝合金
high temperature tempering 高温回火
higher pair 高副
high-frequency furnace 高频炉
high-speed grinding 高速磨削
high-speed transmission 高速传递
hindley worm 直廓环面蜗杆
hinge 铰链、枢纽
Hi-pot test of SPS 高源高压测试
hob 滚刀
hob ,hobbing cutter 齿轮滚刀
hobbing machine 滚齿机
holder 焊把
hole flanging-sizing die 翻孔整形模
hollow flank worm 圆弧圆柱蜗杆
honing 珩磨
honing machine 珩磨机
Hooks coupling universal coupling 万向联轴器
horizontal continuous broaching machine 卧式连续式拉床
horizontal fillet welding 水平角焊
horizontal forging machine 平锻机
horizontal forging machine 卧式锻造机
horizontal parting 水平分模(平锻机)
horizontal spindle double ended grinding machine for piston ring 活塞环卧轴双端面磨床
horizontally fully-immersed barrel 水平全浸式滚筒
horzontal forging 平锻
horzontal position welding 横焊
hose for brake bleeding 制动器放气软管
hot draw 热拉
hot rise tank 热水槽
hot rolled thin steel sheet 热轧薄钢板
hot rolling spring steel 热轧弹簧钢
hot running-in 热磨合
hot spray 热喷漆
hot trim 热切边
hot water rinse 热水清洗
hot weld 热焊
hot-chamber die casting machine 热室压铸机
hour-glass 砂漏
hub puller 轮毂拆卸器
hull cell 赫尔槽
hunting 调速不匀
hyatt roller bearing 挠性滚子轴承
hydraulic blasting 水力清理
hydraulic copy wheel dresser 液压仿形砂轮修整器
hydraulic couplers 液力耦合器
hydraulic extrusion press 滚压挤压机
hydraulic forging 水压机锻造
hydraulic handjack 油压板车
hydraulic machine 油压机
hydraulic mechanism 液压机构
hydraulic servo tool setting device 液压伺服对刀装置
hydraulic stepless speed changes 液压无级变速
hydraulic traching center test 液压跟踪中心架
hydrochloric acid 盐酸
hydrodynamic drive 液力传动
hydrophilic 亲水的
hydrophobic 疏水的
hydro-planing (aqua-planing) 漂滑效应
hyperboloid gear 双曲面齿轮
hypoid gear 准双曲面齿轮
hypoid gear oil 准双曲线齿轮油
identical standard 相同标准
identifying sheet list 标示单
idle 空转
idle gear 惰轮
idpatching vehicle 调车
ignition coil tester 点火线圈试验器
ignition timing light (stroboscope) 点火正时灯(正时观测灯)
Iine number plate 路牌
illegal exhaust and noise 污染超限
imbalance (or unbalance) 不平衡
immersion plating 浸镀
imncomplete annealing 不完全退火
impending skid (由于紧急制动)紧急滑行
impermeable carton 防水纸板
impression 压痕
improved carbon structural steel 优质碳素结构钢
inclusion 杂质
incomplete penetration 未焊透
inconel 因科镍合金
increment or decrement work 盈亏功
index 索引
indices of vehicle maintenance and repari 汽车维修指标
indirect welding 单面点焊
individual repair 单独修理
induction 感应
induction furnace 感应炉
induction light 感应光
industrial robot 工业用机器人
inert-gas welding 惰性气体保护焊
inertia force 惯性力
inertia knock-out grid 惯性落砂机
inertia type brake tester 惯性式制动试验台
infinite 无穷大
information work of standards 标准情报工作
infrared pyrometer 红外线高温计
infrared rays exhaust gas analyzer 红外线废气分析仪
inhibitor 阻蚀剂
initial boiling point 初沸点
initial contact , beginning of contact 起始啮合点
injected-formative plastics 注射成型塑料
in-line slider-crank (or crank-slider) mechanism 对心曲柄滑块机构
inner bearing 内轴承
inner parts inspect 内部检查
inner quality standard 内控标准
inner ring 内圈
inner-outer happing machine 内外圆研磨床
innovation creation 创新
input link 输入构件
insert 入块
inspection 检视
inspection and clasification of parts 零件检验分类
instantaneous center 瞬心
instantaneous center of velocity 速度瞬心
instruction 细则
instructon 指示
instrument and device for vehicle maintenance and repair 汽车维修工具和设备
insulating paint 绝缘漆
insulating paint 绝缘涂料
intake manifold vacuum meter 进气歧管真空度表
integrate 积分
integrated standardization 综合标准化
intelligent design, ID 智能化设计
interchangeable gears 互换性齿轮
intercity line 长途线路
interface standard 接口标准
interference 干涉
interior height 车内净高
intermediate alloy 中间合金
intermediate control office 中途调度站
intermittent gearing 不完全齿轮机构
intermittent motion mechanism 间歇运动机构
inter-mode transport 联合运输
internal and cylindrical centerless grinder for pistone ring 活塞环内外圆无心磨床
internal force 内力
internal gear 内齿轮
internal grinding 内圆磨削
international standard 国际标准
international standardization organization 国际标准化组织
international standards organization 国际标准组织
international standarkdization 国际标准化
internationally harmonized standard 国际协调标准
inter-region transportatin 区间运输
inter-transportation of freight in opposite direction 相向运输
inter-zone vehicle 区间车
introduction 引言
invalid ticket 废票
invalidated ticket box 废票箱
inverse ( or backward) kinematics 反向运动学
inverse cam mechanism 凸轮倒置机构
involute 渐开线
involute equation 渐开线方程
involute function 渐开线函数
involute gear 渐开线齿轮
involute helicoid 渐开螺旋面
involute profile 渐开线齿廓
involute spline 渐开线花键
involute worm 渐开线蜗杆
ion 离子
ion injection 离子束注入
ion-nitriding 离子氮化
IR curing 红外线固化
iron powder electrode 铁粉焊条
island platform 岛式站台
isolating plate baffle plate; barricade 隔板
isothermal annealing 等温退火
isothermal hardenning 等温淬火
isothermal transformation 等温转变
item/group/class 类别
iudustrial alcohol 工业酒精
jack 升降机
jack 千斤顶
Jacobi matrix 雅可比矩阵
jaw (teeth) positive-contact coupling 牙嵌式联轴器
jerk 跃度
jerk diagram 跃度曲线
jig-boring machine 坐标镗床
joggling die 顶锻模
joint radiation convection oven 辐射对流烘干室
jointed manipulator 关节型操作器
journal 轴颈
journal score 轴颈擦伤
journey 运程段
jump hammer 摩擦锤
junction box 分线箱
junction station 枢扭站
kenematic viscosity 运动粘度
Kennedy`s theorem 三心定理
kerosine 煤油
ketones solvent 酮类溶剂
key 键
keyway 键槽
killed steel 镇静钢(脱氧钢)
kinematic analysis 运动分析
kinematic chain 运动链
kinematic design 运动设计
kinematic design of mechanism 机构运动设计
kinematic inversion 反转法
kinematic inversion 机架变换
kinematic inversion 运动倒置
kinematic pair 运动副
kinematic precept design 运动方案设计
kinematic sketch 运动简图
kinematic sketch of mechanism 机构运动简图
kinematic synthesis 运动综合
kinematic viscosity 运动粘度
kinematical seal 动密封
knife-edge follower 尖底从动件
knock 敲缸
knuckle-joint press 曲柄压力机
knurled nut 滚花螺母
labour hygiene standard 劳动卫生标准
labour productivity of repair man 汽车修理工人实物劳动生产率
labour protectig standard 劳动保护标准
labyrinth seal 迷宫密封
lack of painting 烤漆不到位
lack of power 乏力
ladle 浇包
lamp holder 灯架
lap welding 搭接焊
lapping 研磨
lapping 打光
lapping machine 研磨机
large spool 大焊丝盘
laser hardening 激光硬化
laser machining 激光加工
laser welding 激光焊接
lasering heat treatmetn 激光热处理
latex 胶乳
lathe 车床
lathe 车床
lathe 车床
lathe 车
Layout 布置图
Layout 布置图
layout of cam profile 凸轮廓线绘制
lbs. Inch 镑、英寸
lbs. inch 镑、英寸
lead 导程
lead 螺纹导程
lead alloy 铅合金
lead angle 导程角
lead angle at reference cylinder 分度圆柱导程角
lead base babbitt 铅基巴氏合金
lead bronze 铅青铜
lead fouling (火花塞)铅沉积
lead lined steel tank 衬铅槽
lead-base alloy 铅基合金
lead-bronze bearing 铅表铜轴承
lead-covered steel sheet 镀铅钢板
leakage 泄漏
leakage 泄漏
leatherette 人造革
ledeburite 莱氏体
left fork 叉车
left fork 叉车
length of line of action 啮合线长度
level of standardization 标准化的水平
levelling power 均镀力
levels of standards 标准的级别
liaison 联络单
lift 升距
light cargo 轻泡货物
light metal alloy 轻金属合金
light rail rapid transit car 快速有轨电车
Light Source 光源
lighting cable 照明电缆
lightning conductor 接地极
lime grease 钙基润滑脂
lime-sodium base grease 钙-钠基润滑脂
limiting clearance 极限间隙
limiting condition of vehicle 汽车极限技术状况
limiting wear 极限磨损
line borer 直线镗削机
line number 路别
line of action 啮合线
line of centers 连心线
line supervisor 线长
line supervisor 线长
linear cutting 线切割
linear cutting 线切割
linear motion 直线运动
link 构件
linkage 连杆机构
lip rubber seal 唇形橡胶密封
lipowit's metal 李彼威特合金
liquefied petroleum gas(LPG) 液化石油气
liquid spring 液体弹簧
list 目录
little finger 小指
load 载荷
load balancing mechanism 均衡装置
load rating 额定载荷
load—deformation curve 载荷 — 变形曲线
load—deformation diagram 载荷 — 变形图
loader 上料器
loading and unloading charge 装卸费用
loading mileage 载货行程
load-shedding equipment 减负荷装置
local bus 慢车
local hardening 局部淬火
location 地点
long distance bus sto 长途公共汽车站
long distance transportation 长途运输
long goods 长型货物
long-distance bus 长途公共汽车
loom 织布机
loop line 环形线路
lots of production 生产批量
loudspeaker 扬声器
low alloy steel sheet with high strength 高强度底合金钢板
low brake pedal 制动踏板过低
low lead fuel 低含铅汽油
low temperature annealing 低温退火
low temperature tempering 低温回火
lower die 下锤头
lower pair 低副
low-floor bus 低地板式公共汽车
low-shaft furnace 坑式炉
lubricant 润滑剂
lubricant 润滑剂
lubricant film 润滑油膜
lubrication 润滑
lubrication device 润滑装置
lubricity 润滑性
Luft Dushe steel 顶吹氧转炉钢
luminous paint 发光漆
maceration 侵渍作用
machine 机器
machine design; mechanical design 机械设计
machine forging 机器锻造
machinery 机械
machining 机加工
macrography 低倍照相
macro-structure 宏观组织
magnalium 镁铝合金
magnesium 镁金
magnetic fluid bearing 磁流体轴承
magnetic levitated vehicle 磁垫车
magnetic steel 磁钢
magnetic tickeet 磁性月票
magnetizer 加磁器
main bearing aligning gauge 主轴承座孔同轴度检验仪
main flow during the peak period 高峰主流向
main line 正线
main manifold 主集流脉
maintainability of vehicle 汽车维修性
maintenance depot (station )of vehicle 汽车维修场(站)
major defect 主要缺陷
major failure 严重故障
major repair of vehicle 汽车大修
male die 公模
malfunctioning 故障
malleable cast iron 可锻铸铁
Maltese cross 马耳他十字
mandatory standard 强制性标准
Man-day total/work-day total 工日合计
manganese brass 锰黄铜
manganese bronze 锰青铜
manganin 锰铜
manifold pressure gauge set 歧管压力表
manipulator 机器人操作器
manipulator 机械手
manual fuel pump 手油泵
manual welding 手工焊
manufactruing equipment of automobile 汽车制造设备
manufacture management 制造管理
manufacture procedure 制造过程
manufacturing defect 制造缺陷
marquenching 分级淬火
martensite 马氏体
masking 遮蔽
mass 质量
mass transit system 大运量客运系统
mass-radius product 质径积
matching 拼接
material change, stock change 材料变更
material check list 物料检查表
materials 物料
materials expenses 材料费
materials used in auto manufacturing 汽车用材料
mathematic model 数学模型
matrix 矩阵
maximum difference work between plus and minus work 最大盈亏功
maximum passenger capacity 最大载客量
ME 制造工程师
ME 制造工程师
mean diameter 中径
mean screw diameter 平均中径
mechanical 机械的
mechanical advantage 机械利益
mechanical behavior 机械特性
mechanical creation design, MCD 机械创新设计
mechanical efficiency 机械效率
mechanical plating 机械电镀
mechanical press 机械压力机
mechanical speed governors 机械调速
mechanical stepless speed changes 机械无级变速
mechanical system 机械系统
mechanical system design, MSD 机械系统设计
mechanical wear 机械磨损
mechanical-electrical integration system design 机电一体化系统设计
mechanism 机构
mechanism 机构学
mechanism with flexible elements 挠性机构
medium repair of vehicle 汽车中修
medium temperature tempering 中温回火
membership 隶属度
Mercury Lamp 水银灯具
metal 金属
metal arc welding 金属极电弧焊接
metal case hardening 金属表面强化处理
metal halide lamp 金属卤化物灯
metal heat treatment 金属热处理
metal inert gas arc welding 金属极惰性气体保护点焊
metal plate 钣金
Metallic Halide Lamp 金属卤化物灯
metallography 金相学
metered fare 计程票制
metering panel 计量盘
methanol 甲醇
method of vehicle maintenance 汽车维护方法
method of vehicle maintenance on universal post 汽车维护定位作业法
methylated spirit 含甲醇酒精
metric gears 公制齿轮
micro-structure 显微组织
midfinger 中指
mid-plane 中间平面
mild steel 软钢
mildewed=moldy=mouldy 发霉
mileage between repair 修理里程
mill 锉
milled helicoids worm 锥面包络圆柱蜗杆
miller 铣床
miller 铣床
minibus 小公共汽车
minimum radius 最小向径
minimum teeth number 最少齿数
ministerial standard 部标准
minor defect 次要缺陷
minor diameter 小径
minor failure 一般故障
misfiring 不发火(不点火)
missing part 漏件
mixed color 杂色
mixture robbery 抢气
model 机锺
modern machine design 机械的现代设计
modification coefficient 变位系数
modified gear 变位齿轮
modified sine acceleration motion 修正正弦加速度运动规律
modified trapezoidal acceleration motion 修正梯形加速度运动规律
modular design, MD 模块化设计
modular system 模块式传动系统
modulation, regulation 调节
module 模数
molding 成型
molding factory 成型厂
molding factory 成型厂
moly high speed steel 钼高速钢
moment 力矩
moment of couple 力偶矩
moment of flywheel 飞轮矩
moment of inertia ,shaking moment 惯性力矩
moment of torque 扭矩
monel 蒙乃尔合金
mongline 单线
monorail car 单轨车
monorail transit system 单轨运输系统
monthly ticket 月票
mop 拖把
morning peak 早高峰
morphology box 模幅箱
motor vehicle liquidation 汽车报废
moulded bearing metal 浇铸式合金轴承
moving link 运动构件
multi-diameter shaft 阶梯轴
multilaterally harmonized standard 多边协调标准
multilayer welding 多层焊
multilingual international standard 多种语言的国际标准
multi-operator welding set 多站电焊机
multipass welding 多道焊
multiple abrasive wheels surface grinding machine 多砂轮平面磨床
multiple impression forging 多型槽锻造
multiple projection welding 多点凸焊
multiple spot welder 多点焊机
multiple station combined machine for piston machining 活塞加工多工位组合机床
multipurpose additive 多用途添加剂
multi-row bearing 多列轴承
multi-spindle deep hole drilling machine 多轴深孔钻床
multi-steel 多层钢
multi-steel sheet with plastic plate 塑料夹层消声钢板
multi-tool cutting 多刀切削
N/C crankshaft milling machine 数控曲轴铣床
name of a department 部门名称
narrow V belt 窄 V 带
national standard 国家标准
national standardization 国家标准化
national standardization plan 国家标准化计划
national standards body 国家标准机构
national technical committee for standardization 全国标准化技术委员会
natural gasoline 天然汽油
natural rubber 天然橡胶
neckling die 缩口模
needle bearing 滚针轴承
needle roller 滚针
needle roller bearing 滚针轴承
neon spark tester 氖管火花试验器
nephelometer 浊度计
network element 网络单元
network of vehicle maintenance and repair 汽车维修网点
new work item proposal 新工作项目建议
nick 缺口
nickel brass 镍黄铜
nickel bronze 镍青铜
night bus 夜班车
night line 夜间线路
night-bus stop board 夜班车站牌
nitriding 渗氮(氮化)
nitriding steel 氮化钢
nitrile butadiene rubber(NBR) 腈基丁二烯橡胶
nitrile rubber 丁腈橡胶
nitrocellulose enamel 硝基面漆
nitrocellulose filler 硝化腻子
nitrocellulose primer 硝基底漆
no-draft forging 挤压模锻
nodular cast iron 球墨铸铁
noisy brake 制动器发响
no-loading mileage 不载货行程
nomenclature 名称
nominal diameter 公称直径
nominal stress 名义应力、公称应力
Nomogram 诺模图
non gas shielded arc welding 无气体保护电弧焊
non=ferrous metal 有色金属
non-chip finish 少无切削加工
non-circular gear 非圆齿轮
non-contact seal 非接触式密封
non-cyanide plating 无氰电镀
nonflammable paint 耐火漆
nonstandard gear 非标准齿轮
normal circular pitch 法面齿距
normal force 法向力
normal load 垂直载荷、法向载荷
normal module 法面模数
normal parameters 法面参数
normal pitch 法向齿距
normal plane 法面
normal pressure angle 法面压力角
normal stress 正应力、法向应力
normal tooth profile 法向齿廓
normal wear 正常磨损
normalizing 正火
normative element 标准的成分
normative reference 参考标准
normative requirement 标准的要求
not up to grade, not qualified 不合格
not up to standard 不合规格
notes 说明
nugget 焊核
number of threads 蜗杆头数
number of vehicles being received from maintenance or repair 汽车维修竣工辆次
number of waves 波数
numerator 分子
nut 螺母
nylon 尼龙
O ring seal O 形密封圈密封
object 目标
objective function 目标函数
oblique-barrel plating machine 钟形滚镀机
observed mean failure rate 平均故障率的观察值
obsolete material 良品已呆滞
occupation standard 行业标准
octane number 辛烷值
off-line vehicle 下线车
off-peak time 非高峰时间
offset 偏置式
offset circle 偏距圆
offset distance 偏 ( 心 ) 距
offset knife-edge follower 偏置尖底从动件
offset roller follower 偏置滚子从动件
of
