【源码】GDI+画正弦
acmilan2015/10/12软件综合 IP:四川
ATL版:
<code class="lang-cpp">#pragma comment(lib, "gdiplus.lib")
#include <windows.h>
#include <gdiplus.h>
#include <math.h>
#include <atlbase.h>
#include <atlwin.h>
class CMainWnd : public CWindowImpl<cmainwnd, cwindow, cframewintraits>
    BEGIN_MSG_MAP(CMainWnd)
        MESSAGE_HANDLER(WM_PAINT, OnPaint)
        MESSAGE_HANDLER(WM_DESTROY, OnDestroy)
    END_MSG_MAP()
    LRESULT OnPaint(UINT uMsg, WPARAM wParam, LPARAM lParam, BOOL& bHandled)
        PAINTSTRUCT ps;
        HDC hDC = BeginPaint(&ps);
        DrawAxises(hDC);
        DrawCurve(hDC);
        EndPaint(&ps);
        return 0;
    LRESULT OnDestroy(UINT uMsg, WPARAM wParam, LPARAM lParam, BOOL& bHandled)
        PostQuitMessage(0);
        return 0;
    void DrawAxises(HDC hDC)
        using namespace Gdiplus;
        Graphics g(hDC);
        Pen blue(Color(255, 0, 0, 255), 1);
        PointF x_axis[] = { PointF(10, 155), PointF(310, 155),
                            PointF(305, 150), PointF(305, 160), PointF(310, 155) };
        g.DrawLines(&blue, x_axis, 5);
        PointF y_axis[] = { PointF(155, 310), PointF(155, 10),
                            PointF(150, 15), PointF(160, 15), PointF(155, 10) };
        g.DrawLines(&blue, y_axis, 5);
    static const int curve_points = 281;
    void DrawCurve(HDC hDC)
        Graphics g(hDC);
        Pen red(Color(255, 255, 0, 0), 1);
        PointF curve[curve_points];
        for (int j = 0; j < curve_points; j++)
            double x = j - curve_points / 2;
            double y = - sin(x / 10) * 50;
            curve[j] = PointF(x + 155, y + 155);
        g.DrawCurve(&red, curve, curve_points);
int __stdcall wWinMain(HINSTANCE hinst, HINSTANCE hpi, wchar_t *cl, int ns)
    ULONG_PTR gdiplus_token;
    Gdiplus::GdiplusStartup(&gdiplus_token, &Gdiplus::GdiplusStartupInput(), NULL);
    CMainWnd wnd;
    wnd.Create(NULL, NULL, L"GDI+ Sine");
    wnd.ShowWindow(ns);
    wnd.UpdateWindow();
    MSG msg;
    while (GetMessage(&msg, 0, 0, 0))
        TranslateMessage(&msg);
        DispatchMessage(&msg);
    Gdiplus::GdiplusShutdown(gdiplus_token);
    return (int)msg.wParam;
}</cmainwnd,></atlwin.h></atlbase.h></math.h></gdiplus.h></windows.h></code>
WinSDK版:
#include <math.h>
HWND hMainWnd;
    Graphics g(hDC);
    Graphics g(hDC);
LRESULT __stdcall WndProc(HWND hWnd, UINT msg, WPARAM wp, LPARAM lp)
    PAINTSTRUCT ps;
    HDC hDC;
    switch (msg)
    case WM_PAINT:
        hDC = BeginPaint(hWnd, &ps);
        DrawAxises(hDC);
        DrawCurve(hDC);
        EndPaint(hWnd, &ps);
        return 0;
    case WM_DESTROY:
        PostQuitMessage(0);
        return 0;
    return DefWindowProc(hWnd, msg, wp, lp);
    WNDCLASSEX wc = {
        sizeof wc,
        CS_VREDRAW|CS_HREDRAW,
        WndProc,
        0, 0,
        NULL,
        LoadIcon(NULL, IDI_APPLICATION),
        LoadCursor(NULL, IDC_ARROW),
        (HBRUSH)GetStockObject(WHITE_BRUSH),
        NULL,
        L"MyWndClass",
        LoadIcon(hinst, IDI_APPLICATION)
    if (!RegisterClassEx(&wc))
        return 1;
    hMainWnd = CreateWindowEx(0, L"MyWndClass", L"GDI+ Sine", WS_OVERLAPPEDWINDOW,
                CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT,
                NULL, NULL, NULL, NULL);
    ShowWindow(hMainWnd, ns);
    UpdateWindow(hMainWnd);
    MSG msg;
}</math.h></gdiplus.h></windows.h></code>
来自:计算机科学 / 软件综合
acmilan 作者
9年2个月前 IP:四川
793273
虽说微软现在急着想要把GDI+换成Direct2D,但是实际上GDI+还是简单易用易上手。。。
acmilan作者
9年2个月前 IP:四川
793309
个人感觉GDI+的原理应该是封装了AlphaBlend这个GDI函数→_→
acmilan作者
9年2个月前 IP:四川
794380
GDI+只能在C++和.NET (C#/VB)中使用。
如果想在C或VB6中使用GDI+,需要调用GDI+ Flat API,但是这些GDI+ Flat API是没有文档的。
C或VB6中可以调用Windows GDI或Direct2D绘图,但是GDI比较简陋,而Direct2D可能会比较麻烦。
acmilan
进士 学者 笔友
2009/05/30注册,5年10个月前活动
