实在是没时间解释。= =。。自己看吧。
用了graph,crt,dos单元,最好用fp或者lazarus编译。
1.0.1905版
Program FiveInARow;
uses
graph,crt,dos;
label
Ex;
const
version='Version 1.0.1895 Beta [2010/08/03]';
ChessW=19;
BlankW=24;
_Color1=Red;
_Color2=Green;
Delta:array [1..4,0..1] of Integer=((1,0),(0,1),(1,1),(1,-1));
VV:array [0..4] of Word=(0,8,64,512,4096);
EGAMode=16;
VGAMode=18;
CGAMode=6;
IconWidth=300;
Pri='Neoix Organization';
WebSite='XXXXXXXXXXXXXXXXXXXX/';
type
ValueDot=record
V:Word;
VN,D,LD,RD:Byte;
LB,RB:Boolean;
end;
ValueD=record
X,Y,D,LD,RD:Byte;
LB,RB:Boolean;
VN,V:Word;
end;
var
V0:ValueDot;
Value:array [1..2,1..ChessW,1..ChessW,0..4] of ValueDot;
ValueC:array [1..2,0..ChessW*ChessW,1..4] of ValueD;
BeginX,BeginY,CurrentX,CurrentY:Word;
Order:array[0..ChessW+1,0..ChessW+1] of Byte;
ChessRecord:array[0..ChessW*ChessW,0..2]of integer;
JustBegin:Boolean;
R:Registers;
chose:integer;
Step:integer;
i:integer;
x0:integer;
i0,j0,ix,jx,iy,jy:integer;
IconX,IconY,IconWidth0:integer;
Point:array[1..1024,1..768]of integer;
procedure InitChess;
var
grDriver: Integer;
grMode: Integer;
ErrCode: Integer;
HalfX,HalfY,H:Word;
ex,ey,i,j:Word;
k:integer;
strtemp:string;
begin
DirectVideo:=False;
Randomize;
JustBegin:=True;
XXXXX:=0;
V0.V:=0;V0.D:=25;
V0.LD:=5;V0.RD:=5;
XXXXX:=False;
V0.RB:=False;
for i:=1 to ChessW do
for j:=1 to ChessW do
begin
Order[i,j]:=0;
Value[1,i,j,0]:=V0;
Value[1,i,j,1]:=V0;
Value[1,i,j,2]:=V0;
Value[1,i,j,3]:=V0;
Value[1,i,j,4]:=V0;
Value[2,i,j,0]:=V0;
Value[2,i,j,1]:=V0;
Value[2,i,j,2]:=V0;
Value[2,i,j,3]:=V0;
Value[2,i,j,4]:=V0;
end;
for i:=0 to ChessW+1 do
begin
Order[i,0]:=$ff;
Order[0,i]:=$ff;
Order[i,ChessW+1]:=$ff;
Order[ChessW+1,0]:=$ff;
end;
CurrentX:=ChessW div 2;CurrentY:=ChessW div 2;
grDriver := Detect;
InitGraph(grDriver, grMode,'C:\TP\BGI');
ErrCode := GraphResult;
if ErrCode <> grOk then halt;
SetFillStyle(1,White);
FloodFill(1,1,White);
IconWidth0:=IconWidth div 5;
IconX:=(GetMaxX-IconWidth) div 2;
IconY:=(GetMaxY-IconWidth) div 2;
SetColor(LightGray);
SetFillStyle(1,LightGray);
Circle(IconX+IconWidth0*1+IconWidth0 div 2,IconY+IconWidth0*1+IconWidth0 div 2,IconWidth0*1+IconWidth0 div 2);
FloodFill(IconX+IconWidth0*1+IconWidth0 div 2,IconY+IconWidth0*1+IconWidth0 div 2,LightGray);
Circle(IconX+IconWidth-IconWidth0-IconWidth0 div 2,IconY+IconWidth-IconWidth0-IconWidth0 div 2,IconWidth0*1+IconWidth0 div 2);
FloodFill(IconX+IconWidth-IconWidth0-IconWidth0 div 2,IconY+IconWidth-IconWidth0-IconWidth0 div 2,LightGray);
SetColor(White);
Circle(IconX+IconWidth-IconWidth0-IconWidth0 div 2,IconY+IconWidth-IconWidth0-IconWidth0 div 2,IconWidth0 div 2);
FloodFill(IconX+IconWidth-IconWidth0-IconWidth0 div 2,IconY+IconWidth-IconWidth0-IconWidth0 div 2,White);
Circle(IconX+IconWidth0*1+IconWidth0 div 2,IconY+IconWidth0*1+IconWidth0 div 2,IconWidth0 div 2);
FloodFill(IconX+IconWidth0*1+IconWidth0 div 2,IconY+IconWidth0*1+IconWidth0 div 2,White);
for i:=IconY to IconY+IconWidth0 do
for j:=IconX+IconWidth0*1+IconWidth0 div 2 to IconX+IconWidth do
PutPixel(j,i,LightGray);
for i:=IconY+IconWidth0*2 to IconY+IconWidth0*3 do
for j:=IconX+IconWidth0*1+IconWidth0 div 2 to IconX+IconWidth-(IconWidth0*1+IconWidth0 div 2) do
for i:=IconY+IconWidth0*4 to IconY+IconWidth0*5 do
for j:=IconX to IconX+IconWidth-(IconWidth0*1+IconWidth0 div 2) do
for i:=IconY+IconWidth0 to IconY+IconWidth0*2 do
for j:=IconX+IconWidth0*1+IconWidth0 div 2 to IconX+IconWidth-IconWidth0 do
PutPixel(j,i,White);
for i:=IconY+IconWidth0*3 to IconY+IconWidth0*4 do
for j:=IconX+IconWidth0 to IconX+IconWidth-(IconWidth0*1+IconWidth0 div 2) do
for i:=IconX+IconWidth0 to IconX+IconWidth0*2 do
for j:=IconY+IconWidth0*1+IconWidth0 div 2 to IconY+IconWidth-IconWidth0 do
if GetPixel(i,j)=LightGray then Point[i,j]:=1;
for i:=IconX+IconWidth0*3 to IconX+IconWidth0*4 do
for j:=IconY+IconWidth0 to IconY+IconWidth-(IconWidth0*1+IconWidth0 div 2) do
SetColor(DarkGray);
SetFillStyle(1,DarkGray);
FloodFill(IconX+IconWidth0*1+IconWidth0 div 2,IconY+IconWidth0*1+IconWidth0 div 2,DarkGray);
FloodFill(IconX+IconWidth-IconWidth0-IconWidth0 div 2,IconY+IconWidth-IconWidth0-IconWidth0 div 2,DarkGray);
SetColor(White);
for i:=IconX to IconX+IconWidth0 do
for j:=IconY+IconWidth0*1+IconWidth0 div 2 to IconY+IconWidth do
PutPixel(i,j,DarkGray);
for i:=IconX+IconWidth0*2 to IconX+IconWidth0*3 do
for j:=IconY+IconWidth0*1+IconWidth0 div 2 to IconY+IconWidth-(IconWidth0*1+IconWidth0 div 2) do
for i:=IconX+IconWidth0*4 to IconX+IconWidth0*5 do
for j:=IconY to IconY+IconWidth-(IconWidth0*1+IconWidth0 div 2) do
if Point[i,j]=1 then PutPixel(i,j,LightGray) else PutPixel(i,j,White);
for i:=IconX-IconWidth0+IconWidth to IconX+IconWidth do
for j:=IconY to IconY+IconWidth0 do
PutPixel(i,j,Yellow);
for i:=IconX to IconX+IconWidth do
for j:=IconY to IconY+IconWidth do
if GetPixel(i,j)<>White then Point[i,j]:=GetPixel(i,j) else Point[i,j]:=0;
if Point[i,j]<>0 then PutPixel(i+5,j+5,Black);
if Point[i,j]<>0 then PutPixel(i,j,Point[i,j]);
SetTextStyle(DefaultFont,HorizDir,2);
for i:=1 to length(pri) do
begin
Delay(70);
OutTextXY((GetMaxX-TextWidth(pri)) div 2+2,IconY+IconWidth+20+2,Copy(pri,1,i));
SetColor(DarkGray);
OutTextXY((GetMaxX-TextWidth(pri)) div 2+1,IconY+IconWidth+20+1,Copy(pri,1,i));
SetColor(Black);
OutTextXY((GetMaxX-TextWidth(pri)) div 2,IconY+IconWidth+20,Copy(pri,1,i));
end;
x0:=IconY+IconWidth+25+TextHeight(pri);
SetTextStyle(DefaultFont,HorizDir,1);
for i:=1 to length(website) do
begin
Delay(50);
OutTextXY((GetMaxX-TextWidth(website)) div 2+2,x0,Copy(website,1,i));
SetColor(DarkGray);
OutTextXY((GetMaxX-TextWidth(website)) div 2+1,x0,Copy(website,1,i));
SetColor(Black);
OutTextXY((GetMaxX-TextWidth(website)) div 2,x0,Copy(website,1,i));
end;
Delay(1000);
CloseGraph;
BeginX:=GetMaxX div 2-(ChessW*BlankW div 2);
BeginY:=GetMaxY div 2-(ChessW*BlankW div 2);
ex:=GetMaxX div 2+(ChessW*BlankW div 2);
ey:=GetMaxY div 2+(ChessW*BlankW div 2);
Bar(BeginX,BeginY,ex,ey);
SetColor(White);
for i:=1 to ChessW+1 do
begin
Line(BeginX+(i-1)*BlankW,BeginY,BeginX+(i-1)*BlankW,ey);
Line(BeginX,BeginY+(i-1)*BlankW,ex,BeginY+(i-1)*BlankW);
end;
begin
str(i,strtemp);
if i<10 then strtemp:='0'+strtemp;
outtextxy(BeginX+(i-1)*BlankW+5,beginY-15,strtemp);
end;
for k:=1 to ChessW do
outtextxy(BeginX-15,BeginY+(k-1)*BlankW+5,chr(k+96));
SetTextStyle(DefaultFont,HorizDir,3);
OutTextXY(10,10,'Five In A Row');
k:=TextHeight('Five In A Row');
OutTextXY(GetMaxX-TextWidth(version)-10,k+10-TextHeight(version),version);
OutTextXY(75,GetMaxY-23,'Steps');
OutTextXY(20,GetMaxY-30,'0');
Line(0,k+20,GetMaxX,k+20);
OutTextXY(10,k+30,'[s:9]lease use the main window to control.');
case chose of
1:begin
OutTextXY(BeginX-330+32,BeginY,'[s:9]C ');
OutTextXY(BeginX-200,BeginY,'[s:9]layer');
end;
2:begin
OutTextXY(BeginX-330,BeginY,'[s:9]layer');
OutTextXY(BeginX-200+32,BeginY,'[s:9]C ');
end;
3:begin
end;
4:begin
OutTextXY(BeginX-330+32,BeginY,'[s:9]C');
OutTextXY(BeginX-200+32,BeginY,'[s:9]C');
end;
end;
end;
procedure ViewState0(state0:integer);
var
r:word;
begin
r:=(BlankW div 2);
SetColor(black);
Circle(BeginX-330+48,BeginY+50,r-3);
SetFillStyle(1,black);
FloodFill(BeginX-330+48,BeginY+50,black);
Circle(BeginX-200+48,BeginY+50,r-3);
FloodFill(BeginX-200+48,BeginY+50,black);
if state0=1 then
begin
SetColor(_Color1);
SetFillStyle(1,_Color1);
FloodFill(BeginX-330+48,BeginY+50,_Color1);
end
else
begin
SetColor(_Color2);
SetFillStyle(1,_Color2);
FloodFill(BeginX-200+48,BeginY+50,_Color2);
end;
end;
procedure ViewResult(state0:integer);
var
r:word;
begin
r:=(BlankW div 2);
SetColor(black);
Circle(BeginX-330+50,BeginY+50,r-3);
FloodFill(BeginX-330+50,BeginY+50,black);
Circle(BeginX-200+50,BeginY+50,r-3);
FloodFill(BeginX-200+50,BeginY+50,black);
SetColor(white);
if state0=1 then
begin
OutTextXY(BeginX-330+24,BeginY+50,'Win');
end
else
begin
OutTextXY(BeginX-200+24,BeginY+50,'Win');
end;
end;
procedure RecordChess(_x,_y,player:Word);
var
strtemp:string;
begin
SetColor(black);
for i:=GetMaxY-40 to GetMaxY do
Line(10,i,74,i);
Step:=Step+1;
SetColor(white);
str(Step,strTemp);
//strTemp:=strTemp+' Steps';
OutTextXY(20,GetMaxY-30,strtemp);
ChessRecord[Step,0]:=player;
ChessRecord[Step,1]:=_x;
ChessRecord[Step,2]:=_y;
str(_x,strtemp);
if _x<10 then strtemp:='0'+strtemp;
strtemp:=chr(_y+96)+' '+strtemp;
if player=1 then
OutTextXY(BeginX-325+(step div 76)*50,BeginY+80+10*((Step mod 76 -1) div 2),strtemp)
else
OutTextXY(BeginX-195+(step div 76)*50,BeginY+80+10*((Step mod 76 -1) div 2),strtemp);
end;
procedure PutRect(_x,_y:Word;Erase:Boolean);
var
r:Word;
begin
r:=BlankW -2;
if Erase then SetColor(Black) else SetColor(White);
Rectangle(BeginX+_x*BlankW-r,BeginY+_y*BlankW-r,BeginX+_x*BlankW-1,BeginY+_y*BlankW-1);
Rectangle(BeginX+_x*BlankW-r-1,BeginY+_y*BlankW-r-1,BeginX+_x*BlankW-2,BeginY+_y*BlankW-2);
end;
procedure TPut(x,y,p:Byte);forward;
procedure PutChess(_x,_y:Word;player:Byte);
var
r:Word;
color:Byte;
begin
recordchess(_x,_y,player);
r:=(BlankW div 2);
if (_x>ChessW)or(_y>ChessW)or(Order[_x,_y]<>0) then exit;
if player=1 then color:=_Color1 else
if player=2 then color:=_Color2 else exit;
SetColor(color);
Circle(BeginX+_x*BlankW-r,BeginY+_y*BlankW-r,r-3);
SetFillStyle(1,color);
FloodFill(BeginX+_x*BlankW-r,BeginY+_y*BlankW-r,color);
PutRect(CurrentX,CurrentY,True);
Order[_x,_y]:=player;
CurrentX:=_x;CurrentY:=_y;
Value[1,_x,_y,0]:=V0;
Value[2,_x,_y,0]:=V0;
Value[1,_x,_y,1]:=V0;
Value[2,_x,_y,1]:=V0;
Value[1,_x,_y,2]:=V0;
Value[2,_x,_y,2]:=V0;
Value[1,_x,_y,3]:=V0;
Value[2,_x,_y,3]:=V0;
Value[1,_x,_y,4]:=V0;
Value[2,_x,_y,4]:=V0;
PutRect(CurrentX,CurrentY,False);
end;
procedure ManTake(player:Byte);
var
ch:Char;
Take:Boolean;
begin
Take:=False;
repeat
ch:=#0;
if KeyPressed then
begin
ch:=ReadKey;
GotoXY(12,25);
write(' ');
GotoXY(12,25);
write('#',ord(ch));
end;
case ch of
#71:{UpLeft}
begin
if CurrentX>1 then CurrentX:=CurrentX-1;
if CurrentY>1 then CurrentY:=CurrentY-1;
end;
#72:{Up}
begin
end;
#73:{UpRight}
begin
if CurrentX<ChessW then CurrentX:=CurrentX+1;
end;
#75:{Left}
begin
end;
#77:{Right}
begin
end;
#79:{DownLeft}
begin
if CurrentY<ChessW then CurrentY:=CurrentY+1;
end;
#80:{Down}
begin
end;
#81:{DownRight}
begin
end;
#13:{For sure}
begin
if Order[CurrentX,CurrentY]=0 then
begin
TPut(CurrentX,CurrentY,player);
Take:=True;
end;
end;
else;
end;
until Take;
end;
function CheckWin(player:Byte):Boolean;
function CheckLine(bx,by:Word;dx,dy:Integer):Byte;
var
sum,maxsum:Byte;
begin
maxsum:=0;sum:=0;
repeat
if Order[bx,by]=player then
begin
sum:=sum+1;
if sum>maxsum then maxsum:=sum;
end
else
sum:=0;
bx:=bx+dx;by:=by+dy;
until (bx<1)or(bx>ChessW)or(by<1)or(by>ChessW);
CheckLine:=maxsum;
end;
var
i:Byte;
begin
CheckWin:=False;
if CheckLine(1,i,1,0)>4 then
begin
CheckWin:=True;Exit;
end;
if CheckLine(i,1,0,1)>4 then
begin
end;
for i:=1 to ChessW-4 do
if CheckLine(1,i,1,1)>4 then
begin
end;
if CheckLine(i,1,1,1)>4 then
begin
end;
for i:=5 to ChessW do
if CheckLine(i,1,-1,1)>4 then
begin
end;
if CheckLine(ChessW,i,-1,1)>4 then
begin
end;
end;
procedure VD(x0,y0,d,p:Byte);
var
dx,dy:Integer;
x,y,x1,y1,x2,y2,i,j,s0,s1,s2,ls,rs,s,_p,r0,l0,rd,ld,d0:Byte;
lb,rb,rb0,lb0:Boolean;ll,rr:Byte;
t,t0:Word;
out,bb:Boolean;
d1,d2:ValueDot;
begin
if Order[x0,y0]<>0 then Exit;
dx:=Delta[d,0];dy:=Delta[d,1];
if p=1 then _p:=2 else _p:=1;
t0:=0;s0:=0;
x:=x0;y:=y0;s1:=0;out:=false;
repeat
x:=x+dx;y:=y+dy;
Inc(s1);
if (s1>4)or(Order[x,y]=$ff)or(Order[x,y]=_p) then out:=True;
until out;
if (Order[x,y]=$ff)or(Order[x,y]=_p) then Dec(s1);
x:=x0;y:=y0;s2:=0;out:=false;
repeat
x:=x-dx;y:=y-dy;
Inc(s2);
if (s2>4)or(Order[x,y]=$ff)or(Order[x,y]=_p) then out:=True;
until out;
if (Order[x,y]=$ff)or(Order[x,y]=_p) then Dec(s2);
if s1+s2<4 then
Value[p,x0,y0,d]:=V0
else
begin
for i:=0 to s1 do
if (4-i>=0)and(4-i<=s2) then
begin
ld:=1;rd:=1;rs:=0;ls:=0;
x:=x0;y:=y0;ll:=0;bb:=True;lb:=False;
for j:=1 to i do
begin
x:=x+dx;y:=y+dy;
if Order[x,y]=p then Inc(ls);
if (ls=0)and(Order[x,y]=0) then Inc(ld);
if (bb)and(ls>0)and(Order[x,y]=0) then begin lb:=True;ll:=ls;bb:=False;end;
end;
if ls=ll then lb:=False;
if ls=0 then ld:=5;
x1:=x+dx;y1:=y+dy;
x:=x0;y:=y0;rr:=0;bb:=True;rb:=False;
for j:=1 to 4-i do
begin
x:=x-dx;y:=y-dy;
if Order[x,y]=p then Inc(rs);
if (rs=0)and(Order[x,y]=0) then Inc(rd);
if (bb)and(rs>0)and(Order[x,y]=0) then begin rb:=True;rr:=rs;bb:=False;end;
end;
if rs=0 then rd:=5;
if rs=rr then rb:=False;
x2:=x-dx;y2:=y-dy;
s:=ls+rs;
t:=VV[s];
if (Order[x1,y1]=$ff)or(Order[x1,y1]=_p) then t:=t div 2;
if (Order[x2,y2]=$ff)or(Order[x2,y2]=_p) then t:=t div 2;
if t0<t then
begin
t0:=t;s0:=s;r0:=rd;l0:=ld;rb0:=rb;lb0:=lb;
end;
end;
Value[p,x0,y0,d].V:=t0;
Value[p,x0,y0,d].VN:=s0;
Value[p,x0,y0,d].LD:=l0;
Value[p,x0,y0,d].RD:=r0;
Value[p,x0,y0,d].LB:=lb0;
Value[p,x0,y0,d].RB:=rb0;
Value[p,x0,y0,d].D:=l0*r0;
end;
Value[p,x0,y0,0].V:=Value[p,x0,y0,1].V+Value[p,x0,y0,2].V+Value[p,x0,y0,3].V+Value[p,x0,y0,4].V;
if Value[p,x0,y0,1].V>Value[p,x0,y0,2].V then d1:=Value[p,x0,y0,1] else d1:=Value[p,x0,y0,2];
if Value[p,x0,y0,3].V>Value[p,x0,y0,4].V then d2:=Value[p,x0,y0,3] else d2:=Value[p,x0,y0,4];
if d1.V>d2.V then d2:=d1;
Value[p,x0,y0,0].VN:=XXXXX;
Value[p,x0,y0,0].D:=d2.D;
Value[p,x0,y0,0].RD:=d2.RD;
Value[p,x0,y0,0].LD:=d2.LD;
Value[p,x0,y0,0].RB:=d2.RB;
Value[p,x0,y0,0].LB:=XXXXX;
end;
procedure VAdd(x0,y0,dir,p:Byte);
var
dx,dy:Integer;
x,y,i,_p:Byte;
out:Boolean;
begin
dx:=Delta[dir,0];dy:=Delta[dir,1];
x:=x0;y:=y0;i:=0;out:=false;
repeat
x:=x+dx;y:=y+dy;
Inc(i);
if (i>4)or(Order[x,y]=$ff)or(Order[x,y]=_p) then out:=True;
if Order[x,y]=0 then VD(x,y,dir,p);
until out;
repeat
x:=x-dx;y:=y-dy;
Inc(i);
until out;
end;
var
x0,y0:Byte;
d1,d2:ValueDot;
begin
begin
PutChess(x,y,p);
VAdd(x,y,1,2);
VAdd(x,y,2,2);
VAdd(x,y,3,2);
VAdd(x,y,4,2);
VAdd(x,y,1,1);
VAdd(x,y,2,1);
VAdd(x,y,3,1);
VAdd(x,y,4,1);
end;
end;
procedure Ps(x,y:Byte;s:string);{调试}
var
i:Byte;
begin
for i:=2 to Length(s) do
case s[1] of
'-':begin
x:=x+1;TPut(x,y,Ord(s[i])-48);
end;
'|':begin
y:=y+1;TPut(x,y,Ord(s[i])-48);
end;
'\':begin
x:=x+1;y:=y+1;TPut(x,y,Ord(s[i])-48);
end;
'/':begin
x:=x-1;y:=y+1;TPut(x,y,Ord(s[i])-48);
end;
end;
end;
function CheckC(p,n:Byte):Word;
var
i,j:Byte;
t:Word;
begin
t:=0;
if Value[p,i,j,0].V>=VV[n] then
begin
Inc(t);
ValueC[p,t,n].X:=i;
ValueC[p,t,n].Y:=j;
ValueC[p,t,n].V:=Value[p,i,j,0].V;
ValueC[p,t,n].VN:=Value[p,i,j,0].VN;
ValueC[p,t,n].D:=Value[p,i,j,0].D;
ValueC[p,t,n].RD:=Value[p,i,j,0].RD;
ValueC[p,t,n].LD:=Value[p,i,j,0].LD;
ValueC[p,t,n].RB:=Value[p,i,j,0].RB;
ValueC[p,t,n].LB:=Value[p,i,j,0].LB;
end;
ValueC[p,0,n].V:=t;CheckC:=t;
end;
procedure SortC(p,n,xx:Byte);
var
t,i,j:Word;
t0:ValueD;
begin
t:=ValueC[p,0,n].V;
for i:=1 to t-1 do
for j:=i+1 to t do
begin
if xx=1 then
begin
if ValueC[p,i,n].V<ValueC[p,j,n].V then
begin
t0:=ValueC[p,i,n];ValueC[p,i,n]:=ValueC[p,j,n];ValueC[p,j,n]:=t0;
end
else
if ValueC[p,i,n].V=ValueC[p,j,n].V then
if ValueC[p,i,n].D>ValueC[p,j,n].D then
begin
end;
end;
if xx=2 then
begin
begin
end
else
if ValueC[p,i,n].D=ValueC[p,j,n].D then
begin
end;
end;
end;
end;
procedure PC(p:Byte);
var
_p,x,y,i,j,k,s,t:Byte;
b:Boolean;
begin
if Value[p,i,j,0].VN=4 then begin TPut(i,j,p);Exit;end;
if Value[_p,i,j,0].VN=4 then begin TPut(i,j,p);Exit;end;
if (Value[p,i,j,0].VN=3) and (Value[p,i,j,0].V>=VV[3]) and not(Value[p,i,j,0].LB)
and not(Value[p,i,j,0].RB) and (Value[p,i,j,0].D<=5) then
begin
if (Value[p,i,j,0].VN=3) then
begin
s:=0;
if Value[p,i,j,1].VN=3 then Inc(s);
if Value[p,i,j,2].VN=3 then Inc(s);
if Value[p,i,j,3].VN=3 then Inc(s);
if Value[p,i,j,4].VN=3 then Inc(s);
if s>=2 then begin TPut(i,j,p);Exit;end;
b:=False;
for k:=1 to 4 do
if (Value[p,i,j,k].V=VV[2]) then b:=True;
if b then begin TPut(i,j,p);Exit;end;
if Value[p,i,j,0].V>=VV[3] then
begin
s:=0;
for k:=1 to 4 do
if (Value[_p,i,j,k].V=VV[2])and(
(Value[_p,i,j,k].D=1)or(Value[_p,i,j,k].D=2)
or(Value[_p,i,j,k].D=5)or(Value[_p,i,j,k].D=10) )
then Inc(s);
if s>1 then begin TPut(i,j,p);Exit;end;
end;
end;
end;
s:=0;
if (Value[_p,i,j,0].V>=VV[3]) then Inc(s);
if s>4 then
if (Value[p,i,j,0].VN=3)and(Value[p,i,j,0].D<=5) then
begin
if (Value[_p,i,j,0].VN=3) then
begin
if (Value[_p,i,j,0].V>=VV[3]) and not(Value[_p,i,j,0].LB)
and not(Value[_p,i,j,0].RB) and (Value[_p,i,j,0].D<=5) then
s:=0;
if Value[_p,i,j,1].VN=3 then Inc(s);
if Value[_p,i,j,2].VN=3 then Inc(s);
if Value[_p,i,j,3].VN=3 then Inc(s);
if Value[_p,i,j,4].VN=3 then Inc(s);
b:=False;
for k:=1 to 4 do
if (Value[_p,i,j,k].V=VV[2]) then b:=True;
end;
end;
begin
s:=0;
for k:=1 to 4 do
if (Value[p,i,j,k].V=VV[2])and(
(Value[p,i,j,k].D=1)or(Value[p,i,j,k].D=2)
or(Value[p,i,j,k].D=5)or(Value[p,i,j,k].D=10) )
then Inc(s);
end;
begin
s:=0;
for k:=1 to 4 do
then Inc(s);
end;
if (Value[p,i,j,0].V>=VV[3]) then begin TPut(i,j,p);Exit;end;
if (Value[p,i,j,0].VN=2) and (Value[p,i,j,0].V>=VV[2]) and not(Value[p,i,j,0].LB)
if CheckC(p,2)>0 then
begin
SortC(p,2,1);
TPut(ValueC[p,1,2].X,ValueC[p,1,2].Y,p);
Exit;
end;
if CheckC(_p,2)>0 then
begin
SortC(_p,2,2);
TPut(ValueC[_p,1,2].X,ValueC[_p,1,2].Y,p);
Exit;
end;
if CheckC(p,1)>0 then
begin
SortC(p,1,2);
TPut(ValueC[p,1,1].X,ValueC[p,1,1].Y,p);
Exit;
end;
if JustBegin then
if CheckC(_p,1)>0 then
begin
SortC(_p,1,2);
t:=ValueC[_p,0,1].V;
if t>3 then t:=Random(8)+1;
TPut(ValueC[_p,t,1].X,ValueC[_p,t,1].Y,p);
JustBegin:=False;
Exit;
end;
begin
x:=(ChessW div 3)+Random(ChessW div 3);
y:=(ChessW div 3)+Random(ChessW div 3);
TPut(x,y,p);
end;
end;
procedure Wait;
var
ch:Char;
begin
repeat
until KeyPressed;
ch:=ReadKey;
end;
procedure Pre;
var
i:integer;
begin
for i:=1 to 6 do
begin
delay(100+random(300));
write('.');
end;
InitChess;
ViewState0(1);
writeln('初始化成功');
writeln('[s:9]reset Successfully');
writeln;
writeln('使用方向键和回车键控制');
writeln('Use directiion keys and enter key to control');
writeln;
writeln('单击任何按键开始');
writeln('Click any key to start');
writeln;
writeln;
TextColor(Black);
TextBackground(White);
write(' Command ');
TextColor(White);
TextBackground(Black);
end;
var
tx,ty,dt:Word;ch:Char;
begin
writeln('Free Pascal IDE Version 1.0.8 [2006/08/21]');
writeln('Compiler Version 2.0.4');
writeln('GBD Version GDB 6.2.1');
writeln;
randomize;
writeln('Detect Driver ');
writeln('XXXXAMode');
writeln('Choose graph mode (Auto choose VGA) ? ');
i:=0;
repeat
i:=i+1;
delay(1000);
write('.');
until (keypressed) or (i=7);
if i<>7 then Ch:=ReadKey else ch:='0';
writeln;
R.AH:=0;
case ch of
'1':begin
XXXX:=VGAMode;
writeln('Chosen VGAMode');
end;
'2':begin
XXXX:=EGAMode;
writeln('Chosen EGAMode');
end;
'3':begin
XXXX:=CGAMode;
writeln('Chosen CGAMode');
end;
else
begin
writeln;
repeat
clrscr;
TextColor(Yellow+blink);
TextBackground(Red);
Write('Error');
delay(1000);
clrscr;
TextColor(White);
Write('Error');
delay(1000);
until keypressed;
halt;
end;
end;
Intr(16,R);
DirectVideo:=False;
writeln;
write('[s:9]reset Graph Window ');
for i:=1 to 3 do
begin
delay(100+random(100));
write('.');
end;
writeln;
write('Loading 936-Chinese Page ');
delay(200+random(1000));
writeln;
writeln;
writeln('超级五子棋');
writeln('Five In A Row');
writeln;
writeln(version);
writeln('By Rijn - Neoix');
writeln;
delay(200+random(200));
writeln('1.电脑对玩家 PC(First) Player');
writeln('2.玩家对电脑 Player(First) PC');
writeln('3.玩家对玩家 Player Player');
writeln('4.电脑对电脑 PC PC (Test)');
write('选择模式 Choose a mode ? ');
repeat until KeyPressed;
Ch:=ReadKey;
chose:=ord(ch)-48;
Case chose of
1:begin
writeln(1);
Pre;
wait;
repeat
PC(1);
if CheckWin(1) then begin ViewResult(1);goto Ex;end;
ViewState0(2);
ManTake(2);
if CheckWin(2) then begin ViewResult(2);goto Ex;end;
ViewState0(1);
until FALSE;
end;
2:begin
writeln(2);
Pre;
repeat
ManTake(1);
ViewState0(2);
Pc(2);
ViewState0(1);
until FALSE;
end;
3:begin
writeln(3);
Pre;
repeat
ManTake(1);
ViewState0(2);
ManTake(2);
ViewState0(1);
until FALSE;
end;
4:begin
writeln(4);
Pre;
wait;
repeat
PC(1);
ViewState0(2);
PC(2);
ViewState0(1);
until FALSE;
end;
else
begin
writeln;
repeat
clrscr;
Write('Error');
delay(1000);
clrscr;
TextColor(White);
Write('Error');
delay(1000);
until keypressed;
halt;
end;
end;
Ex:
TextColor(LightGray);
writeln;
writeln;
writeln('游戏结束');
writeln('Game Over');
writeln;
writeln('感谢使用');
writeln('Thank you for playing');
writeln('Rijn制作');
writeln('Made by Rijn');
writeln('版权归 Neoix Org 所有');
writeln('Copyright <c> Neoix Org, 2009-2010');
writeln;
writeln('单击回车键退出');
writeln('Click enter to exit');
readln
end.
