Memory Initialization File (.mif) 规定及生成的C程序
wldshy2011/02/13电子技术 IP:内蒙古
An ASCII text file (with the extension .mif) that specifies the initial content of a memory block (CAM, RAM, or ROM), that is, the initial values for each address. This file is used during project compilation and/or simulation. You can create a Memory Initialization File in the Memory Editor, the In-System Memory Content Editor, or the Quartus II Text Editor.
A Memory Initialization File serves as an input file for memory initialization in the Compiler and Simulator. You can also use a Hexadecimal (Intel-Format) File (.hex) to provide memory initialization data.
A Memory Initialization File contains the initial values for each address in the memory. A separate file is required for each memory block. In a Memory Initialization File, you must specify the memory depth and width values. In addition, you can specify data radixes as binary (BIN), hexadecimal (HEX), octal (OCT), signed decimal (DEC), or unsigned decimal (UNS) to display and interpret addresses and data values. Data values must match the specified data radix.
When creating a Memory Initialization File in the Quartus II Text Editor, you must start with the DEPTH, WIDTH, ADDRESS_RADIX and DATA_RADIX keywords. You can use Tab "\t" and Space " " characters as separators, and insert multiple lines of comments with the percent "%" character, or a single comment with double dash "–" characters. Address : data pairs represent data contained inside certain memory addresses and you must place them between the CONTENT BEGIN and END keywords, as shown in the following examples.
%  multiple-line comment
multiple-line comment  %
– single-line comment
DEPTH = 32;                   — The size of data in bits
WIDTH = 8;                    – The size of memory in words
ADDRESS_RADIX = HEX;          – The radix for address values
DATA_RADIX = BIN;             — The radix for data values
CONTENT                       — start of (address : data pairs)
BEGIN
00 : 00000000;                – memory address : data
01 : 00000001;
02 : 00000010;
03 : 00000011;
04 : 00000100;
05 : 00000101;
06 : 00000110;
07 : 00000111;
08 : 00001000;
09 : 00001001;
0A : 00001010;
0B : 00001011;
0C : 00001100;
END;
Address : Data Pairs Syntax Rules
Definition
Example
A : D
Addr[A] = D
2 : 4
Address: 01234567
Data:    00400000
[A0..A1] : D
Addr[A0] to [A1] contain data D
[0..7] : 6
Address: 01234567
Data:    66666666
[A0..A1] : D0 D1
Addr[A0] = D0,
Addr[A0+1] = D1,
Add [A0+2] = D0,
Addr[A0+3] = D1,
until A0+n = A1
[0..7] : 5 6
Address: 01234567
Data:    56565656
A : D0 D1 D2
Addr[A] = D0,
Addr[A+1] = D1,
Addr[A+2] = D2
2 : 4 5 6
Address: 01234567
Data:    00456000
wldshy
进士 学者 机友 笔友
2011/02/06注册,7个月24天前活动
