向小俊同志学习,发一个基于Mean Shift的运动物体跟踪
93°2010/06/18软件综合 IP:广东
当然没有小俊同志高深 。。。 = =
Mean Shift,业内人士称为Mean Sh!t,比较慢,剧烈运动的物体跟踪效果较差 好像是废话 = =
PDF截图两张 敏感部位
“敏感部位”代码
[size=3]int MeanShift::CalcHisSp(unsigned char* frame, float* histogram){
    int pxValue = 0;
    for(int i = 0 ; i < HISLENGTH; i++)
        histogram[i] = 0;
        for(int j = max(0,cY - trackWinHeight / 2);j < min(cY + trackWinHeight / 2,imgH - 1); j ++){
            for(int i = max(0,cX - TrackwWidth/ 2); i < min(cX + TrackwWidth/ 2,imgW - 1);i ++){
                pixel r = frame[j * imgW * 3 + i * 3] / 16;
                pixel g = frame[j * imgW * 3 + i * 3 + 1] / 16;
                pixel b = frame[j * imgW * 3 + i * 3 + 2] / 16;
                histogram[256 * (int)r + 16 * (int)g + (int)b] += 1;
                pxValue ++;
        for(int i = 0; i < HISLENGTH; i ++)
            histogram[i] /= pxValue;
    else
        return 0;
    return pxValue;
void MeanShift::MSPSp(unsigned char * frame){
    float weights[HISLENGTH];
    float newX = 0.0;
    float newY = 0.0;
    for (int i=0;i<HISLENGTH;i++)
        if (currHistogram[i] >0.0 )
            weights[i] = (float)tempHistogram[i]/(float)currHistogram[i];
        else
            weights[i] = 0;
    float sumOfWeights = 0.0;
            int ptr = (int)(256 * (int)r + 16 * (int)g + (int)b);
            newX += (weights[ptr] * (float)i);
            newY += (weights[ptr] * (float)j);
            sumOfWeights += weights[ptr];
    if(sumOfWeights != 0){
        cX = int((newX/sumOfWeights) + 0.5);
        cY = int((newY/sumOfWeights) + 0.5);
    return;
void MeanShift::MSTP(unsigned char*  frame,int frameNumber)
    if(frameNumber == 0){
        CalcHisSp(frame ,this->tempHistogram);
    else
        int stopThreshold = 10;
        int iteratorCoumt = 0;
        while(iteratorCoumt < stopThreshold){
            CalcHisSp(frame ,this->currHistogram);
            MSPSp(frame);
            iteratorCoumt++;
[/size]
misuzu什么的最喜欢了
attachment icon YDD_CVPR_05.pdf 571.13KB PDF 66次下载 预览
+794  科创币    phpskycn    2010/06/18 &nbsp;
+800  科创币    小俊    2010/06/18 厉害厉害!佩服佩服!
来自:计算机科学 / 软件综合
15
93° 作者
14年7个月前 IP:未同步
225751
XXXXXXXXXXXXXXXXXXXXXXXX/t/24617
用的就是Mean Sh!t,加上目标检测算法。。。啥算法来着 忘了 = =
93°作者
14年7个月前 IP:未同步
225898
引用第5楼ltl于2010-06-19 10:26发表的  :
代码不大美……
敢吐点有意义的槽么= =
晒下限自重
93°
2007/04/10注册,6年11个月前活动
