我写的图像缩放程序(双立方插值算法)
小俊2010/01/10软件综合 IP:北京
#include <cmath>
typedef struct
  unsigned char x;
  unsigned char y;
  unsigned char z;
  unsigned char w;
} uchar4;
#define INT_SCALE  256
#define INT_SCALE_SHF  8
// w0, w1, w2, and w3 are the four cubic B-spline basis functions
__inline long w0_int(long a)
  return ((a*(a*(-a + 3*INT_SCALE) - 3*INT_SCALE*INT_SCALE) + INT_SCALE*INT_SCALE*INT_SCALE)/6)>>(INT_SCALE_SHF*2);   // optimized
__inline long w1_int(long a)
   return ((a*a*(3*a - 6*INT_SCALE) + 4*INT_SCALE*INT_SCALE*INT_SCALE)/6)>>(INT_SCALE_SHF*2);
__inline long w2_int(long a)
  return ((a*(a*(-3*a + 3*INT_SCALE) + 3*INT_SCALE*INT_SCALE) + INT_SCALE*INT_SCALE*INT_SCALE)/6)>>(INT_SCALE_SHF*2);
__inline long w3_int(long a)
  return ((a*a*a)/6)>>(INT_SCALE_SHF*2);
__inline unsigned long texPick(unsigned long *image, int x, int y, unsigned long p, unsigned long h)
  if(x < 0)
    x = 0;
  else if(x >= p)
    x = p - 1;
  if(y < 0)
    y = 0;
  else if (y >= h)
    y = h - 1;
  return image[y * p + x];
__inline unsigned long cubicFilter_int(long x, unsigned long c0, unsigned long c1, unsigned long c2, unsigned long c3)
  uchar4 *p[4];
  p[0] = (uchar4 *)&c0;
  p[1] = (uchar4 *)&c1;
  p[2] = (uchar4 *)&c2;
  p[3] = (uchar4 *)&c3;
  uchar4 r;
  long w0x = w0_int(x);
  long w1x = w1_int(x);
  long w2x = w2_int(x);
  long w3x = w3_int(x);
  r.x = (p[0]->x * w0x + p[1]->x * w1x + p[2]->x * w2x + p[3]->x * w3x + INT_SCALE / 2) >> INT_SCALE_SHF;
  r.y = (p[0]->y * w0x + p[1]->y * w1x + p[2]->y * w2x + p[3]->y * w3x + INT_SCALE / 2) >> INT_SCALE_SHF;
  r.z = (p[0]->z * w0x + p[1]->z * w1x + p[2]->z * w2x + p[3]->z * w3x + INT_SCALE / 2) >> INT_SCALE_SHF;
  r.w = 0xff;
  return *((unsigned long *)&r);
// using 16 texture lookups
__inline unsigned long tex2DBicubic(unsigned long *image, float x, float y, unsigned long pitch4, unsigned long height)
  x -= 0.5f;
  y -= 0.5f;
  int px = (int)x;
  int py = (int)y;
  long fx = (x - px) * INT_SCALE + 0.500001f;
  long fy = (y - py) * INT_SCALE + 0.500001f;
  return cubicFilter_int(fy,
               cubicFilter_int(fx, texPick(image, px-1, py-1, pitch4, height), texPick(image, px, py-1, pitch4, height), texPick(image, px+1, py-1, pitch4, height), texPick(image, px+2,py-1, pitch4, height)),
               cubicFilter_int(fx, texPick(image, px-1, py, pitch4, height),   texPick(image, px, py, pitch4, height),   texPick(image, px+1, py, pitch4, height),   texPick(image, px+2, py, pitch4, height)),
               cubicFilter_int(fx, texPick(image, px-1, py+1, pitch4, height), texPick(image, px, py+1, pitch4, height), texPick(image, px+1, py+1, pitch4, height), texPick(image, px+2, py+1, pitch4, height)),
               cubicFilter_int(fx, texPick(image, px-1, py+2, pitch4, height), texPick(image, px, py+2, pitch4, height), texPick(image, px+1, py+2, pitch4, height), texPick(image, px+2, py+2, pitch4, height))
UINT AFX_CDECL CPUBicubicThread(LPVOID param)
  unsigned long *p = (unsigned long *)param;
  unsigned long *image = (unsigned long *)p[0];
  unsigned long pitch = p[1];
  unsigned long pitch4 = p[1] / 4;
  unsigned long width = p[2];
  unsigned long height = p[3];
  unsigned long y_amount = p[4];
  unsigned long y_start = p[5];
  unsigned long *image_out = (unsigned long *)p[6];
  float scale = *((float *)&p[7]);
  unsigned long pitch_org = p[8];
  unsigned long pitch4_org = p[8] / 4;
  unsigned long height_org = p[9];
  long x, y;
  image_out += pitch4 * y_start;
  for(y = y_start; y < y_start + y_amount; y ++)
    if(y >= height)
      break;
    for(x = 0; x < width; x ++)
      float u = x / scale;
      float v = y / scale;
      image_out[x] = tex2DBicubic(image, u, v, pitch4_org, height_org);
    image_out += pitch4;
  return 0;
双立方插值,没什么可解释的,看看photoshop的缩放就知道了。用的是比较常规的方法,目标图像的每个点由原图像相应坐标附近16个点插值得到。主函数我写成线程函数了,就是为了调动几个核一起跑。关键函数是tex2DBicubic。
在E7200双核CPU上能跑出每秒处理1128万像素的速度。
计算过程我全部改成整型计算了。如果用float的话会慢约50%。
+300  科创币    虎哥    2010/01/10
+200  科创币    我说要有光    2010/01/10 开放源代码的分享
来自:计算机科学 / 软件综合
16
小俊 作者
15年6个月前 IP:未同步
177042
我用Geforce GTX285跑这个程序的OpenCL版本(利用纹理单元优化),速度达到每秒23亿像素,是双核E7200的200多倍,是4核QX6600的100多倍。用4GHz的i7估计也要输六七十倍。
小俊作者
15年5个月前 IP:未同步
181063
引用第4楼10班陈大葱22号于2010-01-24 00:17发表的  :
白痴问一下,为什么显卡比CPU快那么多?
1、本地存储器带宽超高
2、运算单元超多,能并行调度
小俊作者
15年4个月前 IP:未同步
195582
撇开软件环境不讲,旧GPU架构不适合这些较复杂的算法,而新的统一架构是近几年才出现的。
小俊作者
15年4个月前 IP:未同步
195775
对,跟编译选项有关。只要选择对应的计算能力,无论是哪个CUDA版本对哪个GPU都是可以支持的。
小俊
进士 学者 机友 笔友
2006/12/29注册,3个月16天前活动
