AI编写的推力计程序
warmonkey2023/03/16软件综合 IP:广东
由于你懂的原因,该服务已被厉害国禁用。
本人评价:打败了制造业大国90%的电子工程师
#include "HX711.h"
// Define the pins used for the HX711 chip
const int LOAD_CELL_DATA_PIN = 2;
const int LOAD_CELL_CLOCK_PIN = 3;
// Define the calibration values for the HX711 chip
const float LOAD_CELL_CALIBRATION_FACTOR = 1000.0;  // replace with your calibration factor
// Define the pin used to trigger the measurement
const int TRIGGER_PIN = 4;
// Define the pin used to output the measurement
const int OUTPUT_PIN = 5;
// Create an instance of the HX711 library
HX711 load_cell(LOAD_CELL_DATA_PIN, LOAD_CELL_CLOCK_PIN);
void setup() {
  Serial.begin(9600);
  pinMode(TRIGGER_PIN, INPUT_PULLUP);
  pinMode(OUTPUT_PIN, OUTPUT);
  load_cell.set_scale(LOAD_CELL_CALIBRATION_FACTOR);
  load_cell.tare();
void loop() {
  if (digitalRead(TRIGGER_PIN) == LOW) {
    // Trigger the measurement
    float thrust = load_cell.get_units(10);
    digitalWrite(OUTPUT_PIN, HIGH);
    Serial.println(thrust);
    delay(1000);
    digitalWrite(OUTPUT_PIN, LOW);
In this example, we first define the pins used for the HX711 chip, as well as the calibration factor for the load cell. We also define the pins used to trigger the measurement and output the measurement results. We then create an instance of the HX711 library using the HX711 constructor, passing in the data pin and clock pin for the load cell. In the setup() function, we initialize the serial communication and set the calibration factor and tare value for the load cell. In the loop() function, we wait for the trigger pin to be pulled low, indicating that a measurement should be taken. We then use the get_units() method of the HX711 library to read the thrust measurement, and output the result to the serial port and the output pin. Finally, we delay for a second before resetting the output pin to low and waiting for the next trigger signal.
Note that the specific pins used for the HX711 chip, trigger pin, and output pin may vary depending on your hardware setup. You should consult the datasheets and pinout diagrams for your particular components to determine the correct pins to use. Also, you may need to adjust the calibration factor to match the sensitivity of your load cell.
来自:计算机科学 / 软件综合
warmonkey 作者
1年8个月前 修改于 1年8个月前 IP:广东
918140
Q: 为嵌入式系统设计一个极简的文件系统,支持POSIX api,断电安全
A: 为支持 POSIX API 和安全断电恢复的嵌入式系统设计文件系统可能是一项复杂的任务,具体要求将取决于具体用例和硬件限制。 但是,这是此类文件系统的极简设计:
*使用日志结构的文件系统设计,其中对文件系统的所有更改都按顺序写入日志。 这种设计非常适合嵌入式系统,因为它确保对文件系统的所有更改都是原子的,这意味着在断电的情况下,可以通过重放日志将文件系统恢复到一致的状态
*使用将 POSIX 系统调用映射到适当的文件系统操作的薄兼容层实现对文件系统的 POSIX API 支持。 该层应该为文件的创建、删除、读取、写入、打开、关闭和查找操作提供基本支持。  实施磨损均衡以确保存储介质的使用寿命最大化。 磨损均衡涉及在存储介质上均匀分布写入操作,以避免比其他块更快地磨损特定块。
*实施记录元数据更改(例如文件创建和删除)的日志机制,以确保即使在元数据更新期间断电,文件系统也可以恢复到一致的状态。  实施垃圾收集机制以回收已删除文件不再使用的空间。 垃圾收集可以在文件系统活动较少时在后台完成。
*使用针对闪存优化的闪存友好文件系统 (FFS),以最大限度地减少文件系统操作对闪存的开销。  在断电恢复期间使用 CRC 或校验和来验证日志的完整性。
*如果可能,请使用备用电池以提供额外的断电保护。
这种极简主义设计提供了基本的 POSIX API 支持,同时确保文件系统在断电时是安全的,并针对资源有限的嵌入式系统进行了优化。 但是,请务必注意,根据具体用例,可能需要其他功能,例如文件系统压缩、加密和权限。
Q: 有开源项目吗?
A: 是的,有许多可用的开源文件系统项目可以用作为嵌入式系统设计极简文件系统的起点。 一些流行的开源项目是:
*FatFS:为小型嵌入式系统设计的文件系统。 它支持 FAT12、FAT16 和 FAT32 文件系统。
*LittleFS:设计用于小型嵌入式系统的轻量级文件系统。 它支持磨损均衡和掉电安全操作。
*YAFFS:Yet Another Flash File System,是一种开源文件系统,专门为基于闪存的设备设计。
*UBIFS:Unsorted Block Image File System,一种专门设计用于闪存设备的文件系统,具有内置的磨损均衡和垃圾收集功能。
这些文件系统通常都有详细的文档记录,并附带示例代码和库,可用于将它们集成到您的项目中。 它们还提供范围广泛的功能,可根据您的具体要求进行定制。
WernerPleischner
918147
有点小问题是FatFS不支持断电安全
铅球脑袋
1年8个月前 修改于 1年8个月前 IP:辽宁
918492
不会上chatgpt,  就找到一个opanai的通用AI,不用翻墙。
https://nasaai.xyz/#/home/chat
先打听社会上的事情,可是让我很失望,答案都太弱质了。
回答简单技术问题好像还行,感觉这AI像是从教科书里爬出来的, 基本上专卷中国学生。
warmonkey作者
1年8个月前 IP:广东
918495
引用铅球脑袋发表于3楼的内容
不会上chatgpt,  就找到一个opanai的通用AI,不用翻墙。 https://nasaai...
这一看就是百度做的,百度文库的味道。
我刚试了一下:
#include <c6x.h>
#include <csl.h>
#include <math.h>
#define PI 3.14159265358979323846
/* Initialize PLL */
void initPLL(unsigned int pllm, unsigned int plld, unsigned int pllf)
    PLL_CONFIG pllcfg;
    /* Configure PLL */
    pllcfg.PLLM = pllm;
    pllcfg.PLLD = plld;
    pllcfg.PLLF = pllf;
    pllcfg.PLLR = 4;  // Divide system clock by 4
    pllcfg.PLLM2 = 2;
    pllcfg.odiv1_div = 1;
    pllcfg.odiv2_div = 1;
    PLL_init(&pllcfg);
    /* Wait for PLL to lock */
    while (!PLL_locked());
/* Initialize DAC */
void initDAC(void)
    /* Configure DAC */
    DAC_config(DAC_CHANNEL_BOTH, DAC_FMT_SIGN_MAG, DAC_POL_UNIPOLAR, DAC_REF_INTERNAL, DAC_ALIGN_LEFT);
    DAC_enable(DAC_CHANNEL_BOTH);
/* FM Modulation */
void FMModulate(float freqDeviation, float sampleRate, float *inputBuffer, float *outputBuffer, int numSamples)
    float phi = 0.0;
    float deltaPhi = 2 * PI * freqDeviation / sampleRate;
    /* FM modulation loop */
    for (int i = 0; i < numSamples; i++) {
        /* Update phase */
        phi += deltaPhi + 2 * PI * inputBuffer[i] / sampleRate;
        if (phi > 2 * PI) {
            phi -= 2 * PI;
        /* Generate modulated output */
        outputBuffer[i] = sinf(phi);
int main(void)
    float sampleRate = 44100.0;   // Sample rate in Hz
    float freqDeviation = 75000.0;   // Frequency deviation in Hz
    float *inputBuffer, *outputBuffer;
    int numSamples = 1024;
    /* Initialize PLL and DAC */
    initPLL(40, 2, 200);
    initDAC();
    /* Allocate memory for input and output buffers */
    inputBuffer = (float *)malloc(numSamples * sizeof(float));
    outputBuffer = (float *)malloc(numSamples * sizeof(float));
    /* Generate input signal */
        inputBuffer[i] = sinf(2 * PI * 1000.0 * i / sampleRate);
    /* Perform FM modulation */
    FMModulate(freqDeviation, sampleRate, inputBuffer, outputBuffer, numSamples);
    /* Output modulated signal to DAC */
        DAC_write(DAC_CHANNEL_BOTH, outputBuffer[i]);
    /* Free memory */
    free(inputBuffer);
    free(outputBuffer);
    return 0;
#define ORDER 1  // Pre-emphasis filter order
#define COEFF 0.95  // Pre-emphasis filter coefficient
float preEmphasisFilter(float x, float *z)
    float y;
    y = x + COEFF * z[0];  // Filter equation
    z[0] = x;  // Update filter state
    return y;
int main(void)
    float x, y, z[ORDER];
    /* Initialize filter state */
    for (int i = 0; i < ORDER; i++) {
        z[i] = 0;
    /* Pre-emphasis loop */
    while (1) {
        /* Read input signal */
        x = readInput();
        /* Apply pre-emphasis filter */
        y = preEmphasisFilter(x, z);
        /* Process output signal */
        processOutput(y);
    return 0;
学者 机友
2008/10/11注册,23时32分前活动
Cubesat
