求助:一个奇怪的FUTABA的VFD显示屏上的驱动芯片数据手册
Aromatisation2021/01/29电子技术 IP:广东
(原谅,这个标题有点难懂)
事情:FUTABA的一块VFD显示屏,目测是商店的客显(收银台的那种竖起来的显示器)里面拆出来的。已找到类似型号的屏幕模块的数据手册,但是无论如何都找不到里面几块芯片的手册,如下:
厂家型号数量接近的产品
TISN7557422(48Pin,PSOP(也许))
SN755742 Datasheet, PDF
Search Partnumber : Match&Start with "SN755" - Total : 47 ( 1/3 Page)
Electronic Manufacturer Part no Datasheet Electronics Description
Texas Instruments
Texas Instruments SN75508 TI-SN75508 Datasheet [Old version datasheet]   AC PLASMA DISPLAY DRIVERS
SN75509 TI-SN75509 Datasheet [Old version datasheet]   AC PLASMA DISPLAY DRIVERS
SN75512 TI1-SN75512 Datasheet [Old version datasheet]   VACUUM FLUORESCENT DISPLAY DRIVERS
SN75518 TI-SN75518 Datasheet [Old version datasheet]   VACUUM FLUORESCENT DISPLAY DRIVERS
SN75518 TI-SN75518 Datasheet [Old version datasheet]   VACUUMFLUORESCENT DISPLAY DRIVERS
SN75551 TI-SN75551 Datasheet [Old version datasheet]   ELECTROLUMINESCENT ROW DRIVERS
SN75552 TI-SN75552 Datasheet [Old version datasheet]   ELECTROLUMINESCENT ROW DRIVERS
SN75553 TI-SN75553 Datasheet [Old version datasheet]   ELECTROLUMINESCENT COLUMIN DRIVERS
SN75554 TI-SN75554 Datasheet [Old version datasheet]   ELECTROLUMINESCENT COLUMIN DRIVERS
SN75555 TI-SN75555 Datasheet [Old version datasheet]   ELECTROLUMINESCENT COLUMIN DRIVERS
SN75556 TI-SN75556 Datasheet [Old version datasheet]   ELECTROLUMINESCENT COLUMIN DRIVERS
SN75557 TI-SN75557 Datasheet [Old version datasheet]   ELECTROLUMINESCENT ROW DRIVERS
SN75558 TI-SN75558 Datasheet [Old version datasheet]   ELECTROLUMINESCENT ROW DRIVERS
SN75559 TI-SN75559 Datasheet [Old version datasheet]   ELECTROLUMINESCENT DISPLAY COLUMIN DRIVERS
SN75560 TI-SN75560 Datasheet [Old version datasheet]   ELECTROLUMINESCENT DISPLAY COLUMIN DRIVERS
SN75500E TI-SN75500E Datasheet [Old version datasheet]   AC PLASMA DISPLAY DRIVERS
SN75501E TI-SN75501E Datasheet [Old version datasheet]   AC PLASMA DISPLAY DRIVERS
SN75512B TI1-SN75512B Datasheet [Old version datasheet]   VACUUM FLUORESCENT DISPLAY DRIVERS
SN75512C TI-SN75512C Datasheet [Old version datasheet]   VACUUM FLUORESCENT DISPLAY DRIVERS
SN75512C TI1-SN75512C Datasheet [Old version datasheet]   VACUUM FLUORESCENT DISPLAY DRIVERS
TI
01501(不能确定是否把0看作O之类)5(60Pin,PSOP(也许))
mitsumi5P23A013-021(横向24,纵向16,MQFP)几乎无
故发文章求助。谢谢!
0x00000000
4年3个月前 修改于 4年3个月前 IP:海南
889801
SN755742这玩意根本不是Ti的,如果是,官网直接能找到型号对应的手册,甚至还有设计资源,但是你这个型号根本没有。
然后第三方的搜索能找到诸如SN75508的手册,但是结果显示这是1986年左右的产品,也就是说现在已经完全停产,资料估计早已消失,因为已经被业界忘记了吧无人再使用。
话说这类芯片它好像是一些简单的逻辑单元,可能是配合主控实现屏幕的驱动的,正常情况下使用这块屏幕无需关心方案实现,你只需要找到屏幕主控得协议资料就行,难道你那块屏幕没有主控吗,就是一些逻辑电路搭成的驱动电路吗?
大仙
4年3个月前 IP:江苏
889803
VFD很多是TTL串口的,你可以研究下线的定义。
Aromatisation作者
4年3个月前 IP:广东
889941
有主控,是一片日立的单片机,(估计PROM之类),这几个芯片明显是串转并+高压驱动。现在主要在找引脚定义。
SN755742,为何不是TI?似乎TI有之类的定制产品。
Aromatisation作者
4年3个月前 IP:广东
889942
Aromatisation作者
4年3个月前 IP:广东
889945
板子大图
0x00000000
4年3个月前 IP:海南
889956
引用Aromatisation发表于5楼的内容
板子大图
驱动屏幕的主控估计就是那片MCU了,以前可能会拿一个MCU负责刷屏,现在都交给专门的驱动芯片了。
所以你要搞清楚的是这块屏幕原先设计的通信协议是什么,如何给MCU输入数据和命令,使其在屏幕上刷新自己想要的图案,至于屏幕模块本身怎么实现的可以不用关心。
如果你搞不到资料的话,则只能自己接手屏幕的驱动工作,但是就像之前说的一样,年份太久很多信息都烟消云散了,搞清楚每一片IC的作用再绕过MCU自己驱动有点不太现实,所以建议自己重新设计这个屏幕模块,只保留屏幕本身,驱动电路板用现在的IC重做,反正VFD屏幕驱动相关的工程案例现在并不少,这可能是比较好的方法了。
Aromatisation作者
4年3个月前 IP:广东
890283
引用0x00000000发表于6楼的内容
驱动屏幕的主控估计就是那片MCU了,以前可能会拿一个MCU负责刷屏,现在都交给专门的驱动芯片了。所以...
屏幕有接近型号的数据表,可以拿来用(hhh,注意只是近似),而且这个屏幕要是全部自己来比较难,首先拆下这个玻璃屏就很困难(像SOP那种封装,引脚非常非常多)
怪人卡文迪许
4年3个月前 IP:甘肃
890284
是在闲鱼买的屏?
Aromatisation作者
4年2个月前 IP:广东
890643
引用怪人卡文迪许发表于8楼的内容
是在闲鱼买的屏?
Aromatisation
2018/01/06注册,1天18时前活动
中国科学技术大学 化学物理系(003) XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
IP归属地:浙江
