使用mailslot实现本地C/S双工通信
acmilan2016/12/04软件综合 IP:四川
Windows中有两种基于虚拟文件系统的进程间通信方式——邮件槽和管道。邮件槽的优点是简单稳定,不会动不动就管道损坏,缺点是一次传输数据不能超过64kB,而且是单工模式,只能客户端发给服务器。不过我们可以手工实现有连接的双工通信。
客户端一般采用无限长等待方式,而服务端一般采用无等待循环检查的方式实现。
项目属性里的字符集设置为[使用多字节字符集]。
客户端:
<code class="language-cpp">#include <stdio.h>
#include <windows.h>
char appname[] = "myapp1";
int main()
	char namebuf[1024] = "";
	wsprintf(namebuf, "//./mailslot/%s/listen", appname);
	HANDLE hlisten;
	while (INVALID_HANDLE_VALUE == (hlisten = CreateFile(namebuf, GENERIC_WRITE, 0, NULL, OPEN_EXISTING, 0, NULL)))
	DWORD threadid = GetCurrentThreadId();
	DWORD writenum = 0;
	DWORD readnum = 0;
	int clientid = -1;
	DWORD sentnum = 0;
	wsprintf(namebuf, "//./mailslot/%s/%u/client", appname, threadid);
	HANDLE hclient = CreateMailslot(namebuf, 0, MAILSLOT_WAIT_FOREVER, NULL);
	WriteFile(hlisten, &threadid, sizeof threadid, &writenum, NULL);
	ReadFile(hclient, &clientid, sizeof clientid, &readnum, NULL);
	CloseHandle(hlisten);
	printf("connect established, connection id %d\n", clientid);
	wsprintf(namebuf, "//./mailslot/%s/%u/server", appname, threadid);
	HANDLE hserver = CreateFile(namebuf, GENERIC_WRITE, 0, NULL, OPEN_EXISTING, 0, NULL);
	WriteFile(hserver, "来自邮件槽客户端的问候", 22, &writenum, NULL);
	ReadFile(hclient, &sentnum, sizeof sentnum, &readnum, NULL);
	printf("sent %u bytes\n", sentnum);
	WriteFile(hserver, "\033disconnect", 11, &writenum, NULL);
</windows.h></stdio.h></code>
服务端:
HANDLE listen_handle;
#define CONNECTION_NUM 16
HANDLE client_handle[CONNECTION_NUM];
HANDLE server_handle[CONNECTION_NUM];
int main()
	listen_handle = CreateMailslot(namebuf, 0, 0, NULL);
	if (listen_handle == INVALID_HANDLE_VALUE)
		printf("ERR - cannot listen on %s\n", namebuf);
		return 1;
	printf("SUC - listen on %s\n", namebuf);
	for (int i = 0; i < CONNECTION_NUM; i++)
		client_handle[i] = INVALID_HANDLE_VALUE;
		server_handle[i] = INVALID_HANDLE_VALUE;
	DWORD threadid = 0;
	DWORD readnum = 0;
	DWORD writenum = 0;
	while (true)
			if (client_handle[i] == INVALID_HANDLE_VALUE || server_handle == INVALID_HANDLE_VALUE)
				CloseHandle(client_handle[i]);
				CloseHandle(server_handle[i]);
				ReadFile(listen_handle, &threadid, sizeof threadid, &readnum, NULL);
				if (readnum < sizeof threadid)
					continue;
				client_handle[i] = CreateFile(namebuf, GENERIC_WRITE, 0, NULL, OPEN_EXISTING, 0, NULL);
				if (client_handle[i] == INVALID_HANDLE_VALUE)
					printf("ERR - connection %d cannot open %s\n", i, namebuf);
					continue;
				SetMailslotInfo(client_handle[i], 0);
				printf("SUC - connection %d open %s\n", i, namebuf);
				wsprintf(namebuf, "//./mailslot/%s/%d/server", appname, threadid);
				server_handle[i] = CreateMailslot(namebuf, 0, 0, NULL);
				if (server_handle[i] == INVALID_HANDLE_VALUE)
					printf("ERR - connection %d cannot create %s\n", i, namebuf);
					continue;
				printf("SUC - connection %d create %s\n", i, namebuf);
				WriteFile(client_handle[i], &i, sizeof i, &writenum, NULL);
			else
				char buf[65537] = "";
				char msgbuf[1024] = "";
				ReadFile(server_handle[i], buf, 65536, &readnum, NULL);
				if (readnum == 0)
					continue;
				printf("SUC - connection %d read %u bytes: %s\n", i, readnum, buf);
				WriteFile(client_handle[i], &readnum, sizeof readnum, &writenum, NULL);
				if (lstrcmpi(buf, "\033disconnect") == 0)
					printf("SUC - connection %d closed\n", i);
					continue;
[修改于 8年0个月前 - 2016/12/04 17:41:56]
来自:计算机科学 / 软件综合
acmilan 作者
8年0个月前 修改于 8年0个月前 IP:四川
828185
mailslot和namedpipe有一点不好,它们是网络接口,容易被dos。
如果能使用USER32的话,可以各建立一个窗口,然后用WM_COPYDATA。
如果不能使用USER32,可以用命名事件和共享内存,不过要麻烦一些。
acmilan
进士 学者 笔友
2009/05/30注册,5年10个月前活动
