对,不是C++/CLI。用的是.NET的非托管接口和反射特性。
优点是与编译器无关,缺点是比较麻烦,需要用反射进行调用。
<code class="language-app.config"><configuration> <startup uselegacyv2runtimeactivationpolicy="true"> <supportedruntime version="v4.0.30319"> <supportedruntime version="v2.0.50727"> </supportedruntime></supportedruntime></startup> </configuration> </code>
<code class="language-cpp">// bindcoree.cpp : 定义控制台应用程序的入口点。 // #include "stdafx.h" #pragma warning(disable: 4996) #include <windows.h> #include <shlwapi.h> #include <mscoree.h> #import <mscorlib.tlb> rename("ReportEvent", "ReportEvent_mscor") #pragma comment(lib, "shlwapi.lib") #pragma comment(lib, "mscoree.lib") using namespace mscorlib; int _tmain(int argc, _TCHAR* argv[]) { // 初始化COM线程模型 HRESULT hr = CoInitialize(NULL); // 重要!运行WinForms和WPF必需 // 构造app.config路径 WCHAR path[MAX_PATH]; GetModuleFileName(NULL, path, MAX_PATH); PathRemoveFileSpec(path); PathAppend(path, L"app.config"); // 初始化.NET运行库(没找到app.config按.NET2.0/3.x加载) ICorRuntimeHost *crh = NULL; hr = CorBindToCurrentRuntime(path, CLSID_CorRuntimeHost, IID_ICorRuntimeHost, (void**)&crh); crh->Start(); // 获取当前程序域 IUnknownPtr domainunk; crh->CurrentDomain(&domainunk); _AppDomainPtr domain; domain = domainunk; // 加载WPF运行库程序集(只加载需要的就行了) // 注册程序集一般要强名称才能加载,可以去以下两个地方找到相关信息: // C:\Windows\assembly - .NET 2.0/3.x // C:\Windows\Microsoft.NET\assembly - .NET 4.x _AssemblyPtr prefx = domain->Load_2(_bstr_t(L"PresentationFramework, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35")); //_AssemblyPtr precore = domain->Load_2(_bstr_t(L"PresentationCore, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35")); //_AssemblyPtr winbase = domain->Load_2(_bstr_t(L"WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35")); // 获取Window类型信息 _TypePtr twindow = prefx->GetType_2(_bstr_t(L"System.Windows.Window")); // 创建Window类型实例 variant_t objwindow = prefx->CreateInstance(_bstr_t(L"System.Windows.Window")); // 调用ShowDialog方法 twindow->InvokeMember_3(_bstr_t(L"ShowDialog"), (BindingFlags)(BindingFlags_InvokeMethod|BindingFlags_Instance|BindingFlags_Public), NULL, objwindow, NULL); ///////////////////////////////////////////////////////////////////////////////////////////////// // 下面是调用没有强名称的一般程序集的做法 //_AssemblyPtr assembly = domain->Load_2(_bstr_t(L"ClassLibrary")); //_TypePtr t = assembly->GetType_2(_bstr_t(L"ClassLibrary.Class1")); //variant_t nullobj; //t->InvokeMember_3(_bstr_t(L"WriteVersion"), // (BindingFlags)(BindingFlags_InvokeMethod|BindingFlags_Static|BindingFlags_Public), // NULL, nullobj, NULL); /////////////////////////////////////////////////////////////////////////////////////////////////// // 卸载ICorRuntimeHost(只有它不是智能指针) crh->Release(); crh = NULL; // 卸载COM CoUninitialize(); return 0; } </mscorlib.tlb></mscoree.h></shlwapi.h></windows.h></code>
[修改于 8年5个月前 - 2016/07/07 05:41:04]
