奇怪的while(Expressions)
张静茹2016/04/26软件综合 IP:江苏
<code class="lang-c">typedef struct _KEYBOARD_INPUT_DATA {
    // Unit number.  E.g., for \Device\KeyboardPort0 the unit is '0',
    // for \Device\KeyboardPort1 the unit is '1', and so on.
    USHORT UnitId;
    // The "make" scan code (key depression).
    char MakeCode;
    // The flags field indicates a "break" (key release) and other
    // miscellaneous scan code information defined below.
    USHORT Flags;
    USHORT Reserved;
    // Device-specific additional information for the event.
    ULONG ExtraInformation;
} KEYBOARD_INPUT_DATA, *PKEYBOARD_INPUT_DATA;
typedef struct _WriteDataStruct
    UINT8 Command;
    UINT8 Data[];
}WriteData, *PWriteData;
typedef void(__stdcall*PUserRing0Fun)(); //C++函数指针
void UserFun()
    printf("被调用了!!!!!!!!!!!!");
typedef struct _ListData
    KEYBOARD_INPUT_DATA DATA;
    struct _ListData *Next;
}ListData, *PListData;
volatile PListData PldFirst;
volatile PListData *PPldLast;
//PListData *PldCurrent;
void Add(PListData ld)
    (*PPldLast) = (PListData)malloc(sizeof(ListData));
    (*PPldLast)->DATA.ExtraInformation = ld->DATA.ExtraInformation;
    (*PPldLast)->DATA.Flags = ld->DATA.Flags;
    (*PPldLast)->DATA.MakeCode = ld->DATA.MakeCode;
    (*PPldLast)->DATA.Reserved = ld->DATA.Reserved;
    (*PPldLast)->DATA.UnitId = ld->DATA.UnitId;
    (*PPldLast)->Next = nullptr;
    PPldLast = &((*PPldLast)->Next);
void Init()
    PldFirst = nullptr;
    PPldLast = &PldFirst;
volatile PListData ldNext;
BOOL RemoveFirst(void)
    if (PldFirst != nullptr)
        ldNext = (PldFirst->Next);
        if (ldNext != nullptr)
            free(PldFirst);
            PldFirst = ldNext;
            return TRUE;
        else
            free(PldFirst);
            PldFirst = nullptr;
            return FALSE;
    else
        return FALSE;
int main()
    Init();
    ListData ld = {0};
    for (size_t i = 0; i < 3; i++)
        ld.DATA.MakeCode = getchar();
        Add(&ld);
    std::cout << PldFirst->DATA.MakeCode;
    RemoveFirst();
    //while (RemoveFirst()); //注意这里,如果RemoveFirst()在while括号中的话,执行后 PldFirst指向0
    return 0;
}</code>
<code class="lang-cpp">std::cout << PldFirst->DATA.MakeCode;
    std::cout << PldFirst->DATA.MakeCode; //PldFirst指向0
return 0;</code>
RemoveFirst();
    std::cout << PldFirst->DATA.MakeCode; //PldFirst指针正常
return 0;</code>
来自:计算机科学 / 软件综合
张静茹 作者
8年1个月前 IP:江苏
817369
额,没睡醒
多了个分号
可是我只F11了一次呀,难道编译器优化掉了吗?
张静茹
进士 学者 机友 笔友
2010/12/30注册,10天7时前活动
