这个需要.net3.5,上面的需要.net4.5
<code class="lang-c">public partial class Form2 : Form { public Form2() { InitializeComponent(); } [System.Runtime.InteropServices.DllImport("user32.dll", EntryPoint = "SetForegroundWindow")] public static extern bool SetForegroundWindow(IntPtr hWnd);//设置此窗体为活动窗体 private void Form2_Load(object sender, EventArgs e) { webBrowser.ScriptErrorsSuppressed = true; } IntPtr _form1; public void Navigate(string urlString, IntPtr __form1) { _form1 = __form1; webBrowser.Navigate(urlString); } private void webBrowser_DocumentCompleted(object sender, WebBrowserDocumentCompletedEventArgs e) { SetForegroundWindow(_form1); } private void Form2_Activated(object sender, EventArgs e) { SetForegroundWindow(_form1); } }</code>
引用 acmilan:
源码能否一发?
<code class="lang-c">public partial class Form1 : Form { public Form1() { InitializeComponent(); } //调用API [System.Runtime.InteropServices.DllImport("user32.dll", CharSet = System.Runtime.InteropServices.CharSet.Auto, ExactSpelling = true)] public static extern IntPtr GetForegroundWindow(); //获得本窗体的句柄 [System.Runtime.InteropServices.DllImport("user32.dll", EntryPoint = "SetForegroundWindow")] public static extern bool SetForegroundWindow(IntPtr hWnd);//设置此窗体为活动窗体 //定义变量,句柄类型 public IntPtr han; private void textBox1_MouseDown(object sender, MouseEventArgs e) { //Text = string.Format("当前选中位置 {0} 当前选中字符长度 {1} 当前选中文本 {2}", textBoxSou.SelectionStart, textBoxSou.SelectionLength, textBoxSou.SelectedText); string poram = WordStartEnd(textBoxSou.Text,textBoxSou.SelectionStart); if (string.IsNullOrEmpty(poram)) { return; } IntPtr _form1 = GetForegroundWindow(); F2.Navigate(string.Format("http://www.bing.com/dict/search?q={0}&go=%E6%8F%90%E4%BA%A4&qs=bs&form=CM", poram), _form1); Text = _form1.ToString("X"); //this.Focus(); //SetForegroundWindow(_form1); //MessageBox.Show(textBoxSou.Text.Substring(start, end - start)); } /// <summary> /// 寻找单词起点与终点 /// </summary> /// <param name="Text"> /// <param name="SelectionStart"> /// <param name="start"> /// <param name="end"> private string WordStartEnd(string Text, int SelectionStart) { int start = 0,end = 0; for (int i = SelectionStart; i < Text.Length; i++) //确定结束点 { if (!char.IsLetter(Text<i>)) { end = i; break; } } if (end == 0) end = Text.Length; for (int i = SelectionStart - 1; i >= 0; i--) //确定起始点 { if (!char.IsLetter(Text<i>)) { start = i + 1; break; } } string temp = Text.Substring(start, end - start); if (!Regex.IsMatch(temp,"[a-z]")) { return temp; } for (int i = SelectionStart; i < end; i++) //往终点寻找大写 { if(char.IsUpper(Text<i>)) { end = i; break; } } for (int i = SelectionStart-1; i >= start; i--)//往起点寻找大写 { if (char.IsUpper(Text<i>)) { start = i; break; } } return Text.Substring(start, end - start); } private void 设置ToolStripMenuItem_Click(object sender, EventArgs e) { MessageBox.Show("asd"); } private void 字体ToolStripMenuItem_Click(object sender, EventArgs e) { fontDialog字体.Font = textBoxSou.Font; fontDialog字体.Color = textBoxSou.ForeColor; fontDialog字体.ShowColor = true; fontDialog字体.ShowDialog(); textBoxSou.Font = fontDialog字体.Font; textBoxSou.ForeColor = fontDialog字体.Color; } private void 背景颜色ToolStripMenuItem_Click(object sender, EventArgs e) { colorDialog颜色.ShowDialog(); textBoxSou.BackColor = colorDialog颜色.Color; } private void textBoxSou_KeyDown(object sender, KeyEventArgs e) { TextBox tbtem = (TextBox)sender; if (e.Control && e.KeyCode == Keys.A) { tbtem.SelectionStart = 0; tbtem.SelectionLength = tbtem.Text.Length; e.Handled = true; } } private void 测试ToolStripMenuItem_Click(object sender, EventArgs e) { //webBrowser.DocumentText = Http.Get("http://www.bing.com/dict/search?q=" + "browser" + "&go=%E6%8F%90%E4%BA%A4&qs=bs&form=CM", ""); IntPtr ip = GetForegroundWindow(); int i = ip.ToInt32(); Text = i.ToString("X"); SetForegroundWindow(new IntPtr(0x00391422)); } Form2 F2 ; private void Form1_Load(object sender, EventArgs e) { F2 = new Form2(); F2.Show(); } }</i></i></i></i></code>
