编译运行wii模拟器-dolphin
smith2015/02/28软件综合 IP:广东
楼主之前发过一个psp模拟器的帖子,在这里:
XXXXXXXXXXXXXXXXXXXXXXXX/t/69817
今天在发一个wii模拟器的编译介绍帖子,这个模拟器不错,打算后续花一点时间分析一下wii的架构[s::lol],看看能不能山寨些什么东西。
wii不用介绍吧,任天堂的主机,这个游戏大家玩过吧:福利满满不错的东西 SL2J01-4.png
来自:计算机科学 / 软件综合
smith 作者
9年10个月前 IP:广东
753045
环境,ubuntu14.04 我没有用window是没有vs2012,按照这个文档的步骤即可:
XXXXXXXXXXXXXXXXXXXXXXXXXXXX/XXXXXXXXp?title=Building_Dolphin_on_Linux
smith作者
9年10个月前 IP:广东
753047
先安装一些库:
12.04 (LTS)
Follow this step for Ubuntu 12.04 (LTS).
You need to install a g++ version with C++0x/C++11 support, so install this PPA first:
sudo add-apt-repository ppa:dolphin-emu/gcc-4.8-precise
sudo apt-get update
This PPA will update libstdc++6 package too, which is an important component from the system, so be careful and use at your own risk.
Cmake needs to be updated too:
sudo add-apt-repository ppa:kalakris/cmake
sudo apt-get update
Now, install all necessary packages by running the following command:
sudo apt-get install cmake git gcc-4.8 g++-4.8 pkg-config libao-dev libasound2-dev libbluetooth-dev libgl1-mesa-dev libgtk2.0-dev liblzo2-dev libopenal-dev libpulse-dev libreadline6-dev libsdl1.2-dev libsoil-dev libsoundtouch-dev libusb-1.0-0-dev libxext-dev libxrandr-dev zlib1g-dev
14.04 (LTS)
Follow this step for Ubuntu 14.04 (LTS).
Install all necessary packages by running the following command:
sudo apt-get install cmake pkg-config git g++ libao-dev libasound2-dev libavcodec-dev libavformat-dev libbluetooth-dev libgtk2.0-dev liblzo2-dev libopenal-dev libpolarssl-dev portaudio19-dev libpulse-dev libreadline6-dev libsdl2-dev libsfml-dev libsoil-dev libsoundtouch-dev libswscale-dev libusb-1.0-0-dev libwxbase3.0-dev libwxgtk3.0-dev libxext-dev libxrandr-dev zlib1g-dev
14.10 and newer
Follow this step for Ubuntu 14.10 and future versions.
sudo apt-get install cmake pkg-config git g++ libao-dev libasound2-dev libavcodec-dev libavformat-dev libbluetooth-dev libgtk2.0-dev liblzo2-dev libminiupnpc-dev libopenal-dev libpolarssl-dev portaudio19-dev libpulse-dev libreadline6-dev libsdl2-dev libsfml-dev libsoil-dev libsoundtouch-dev libswscale-dev libusb-1.0-0-dev libwxbase3.0-dev libwxgtk3.0-dev libxext-dev libxrandr-dev zlib1g-dev
楼主是14.04的机器,就按照14.04的方法安装就行了
smith作者
9年10个月前 IP:广东
753048
安装完成之后git clone 代码
git clone XXXXXXXXXXXXXXXXXX/dolphin-emu/XXXXXXXXXXt
下载代码大概要30~40分钟左右,不必科学上网,github可以访问的
smith作者
9年10个月前 IP:广东
753051
下载完成后再dolphin的代码目录里面建立一个build目录
mkdir Build && cd Build
在里面执行:
cmake ..
make
smith作者
9年10个月前 IP:广东
753053
编译完成之后,执行sudo make install 就开始安装,安装了之后,在命令行敲一个dolphin-emu就可以把模拟器跑起来 IMG_20150228_230309.jpg
smith作者
9年10个月前 IP:广东
753054
wii游戏资源可以在3DM这些网站上面找,楼主玩的是《零真红之蝶》,试着跑了一下,还是挺流畅的,按键设置可以参考一下这个。我按照贴吧的方式设置的 3477fa3d70an.jpg
smith作者
9年10个月前 IP:广东
753055
wii的CPU是IBM搞的PowerPC架构,用PC来模拟绰绰有余,用ARM来搞,就有些吃力了,所以这个模拟器的手机版还在alpha阶段。
不过网上也可以下载得到。
后面会花一点时间看看这东西的代码,看看能不能搞到Android盒子上,这样就可以做出一台Android的wii主机了[s::lol]
另外感觉这个模拟器似乎比psp的模拟器要高效一些,可能渲染流程与psp的不同,要研究一下
潜伏
9年10个月前 IP:浙江
753154
这个不错感谢分享。
cccyl
9年10个月前 IP:广东
753163
把wii看成了wifi,瞎狗眼了
smith
2015/01/11注册,11时11分前活动
收音机爱好者
IP归属地:广东
