发点编程的东西,非局部均值法(NLM)降噪
小俊2010/06/18软件综合 IP:荷兰
图像降噪专用,不解释。
算法描述:
超慢的方法,处理每个像素的算法复杂度与处理半径的关系为O(N^4)。
偷懒一下加快算法:
代码(写成了线程函数模式,以便多线程处理,NOISE为降噪强度,LERPC为lerp系数):
#include "stdafx.h"
#include <cmath>
#define NLM_WINDOW_RADIUS    3
#define NLM_BLOCK_RADIUS    3
#define NLM_WINDOW_AREA        ((2 * NLM_WINDOW_RADIUS + 1) * (2 * NLM_WINDOW_RADIUS + 1))
#define INV_NLM_WINDOW_AREA    (1.0f / (float)NLM_WINDOW_AREA)
#define NLM_WEIGHT_THRESHOLD    0.10f
#define NLM_LERP_THRESHOLD        0.10f
#define BLOCKDIM_X        8
#define BLOCKDIM_Y        8
__inline unsigned long vecLen(unsigned long p1, unsigned long p2)
    unsigned char *a = (unsigned char *)&p1;
    unsigned char *b = (unsigned char *)&p2;
    return ((b[0] - a[0]) * (b[0] - a[0])
          + (b[1] - a[1]) * (b[1] - a[1])
          + (b[2] - a[2]) * (b[2] - a[2]));
__inline float lerpf(float a, float b, float c)
    return a + (b - a) * c;
__inline unsigned long lerpf(unsigned long a, unsigned long b, long c)
    return a + (b - a) * c / 65536;
__inline unsigned long tex2D(unsigned long *image, int p, int h, int x, int y)
    if(x < 0)
        x = 0;
    else if(x >= p)
        x = p - 1;
    if(y < 0)
        y = 0;
    else if (y >= h)
        y = h - 1;
    return image[y * p + x];
#define NOISE        0.25f
#define LERPC        0.15f
UINT AFX_CDECL CPUFastNLMThread(LPVOID param)
    unsigned long *p = (unsigned long *)param;
    unsigned long *image = (unsigned long *)p[0];
    unsigned long pitch = p[1];
    unsigned long pitch4 = p[1] / 4;
    unsigned long width = p[2];
    unsigned long height = p[3];
    unsigned long y_amount = p[4];
    unsigned long y_start = p[5];
    unsigned long *image_out = (unsigned long *)p[6];
    float Noise = 1.0f / (NOISE * NOISE);
    float lerpC = LERPC;
    long bx, by, tx, ty;
    for(by = y_start; by < y_start + y_amount; by += BLOCKDIM_Y)
        for(bx = 0; bx < width; bx += BLOCKDIM_Y)
            // float fWeights[BLOCKDIM_X * BLOCKDIM_Y];
            long fWeights[BLOCKDIM_X * BLOCKDIM_Y];
            for(ty = 0; ty < BLOCKDIM_Y; ty ++)
                for(tx = 0; tx < BLOCKDIM_X; tx ++)
                    long x = bx + tx;
                    long y = by + ty;
                    long cx = bx + NLM_WINDOW_RADIUS;
                    long cy = by + NLM_WINDOW_RADIUS;
                    if((x < width) && (y < height))
                        //Find color distance from current texel to the center of NLM window
                        // float weight = 0;
                        long weight = 0;
                        for(int n = -NLM_BLOCK_RADIUS; n <= NLM_BLOCK_RADIUS; n ++)
                            for(int m = -NLM_BLOCK_RADIUS; m <= NLM_BLOCK_RADIUS; m ++)
                                weight += vecLen(tex2D(image, pitch4, height, cx + m, cy + n), tex2D(image, pitch4, height, x + m, y + n));
                        //Geometric distance from current texel to the center of NLM window
                        float dist = (float)((tx - NLM_WINDOW_RADIUS) * (tx - NLM_WINDOW_RADIUS) + (ty - NLM_WINDOW_RADIUS) * (ty - NLM_WINDOW_RADIUS));
                        //Derive final weight from color and geometric distance
                        // weight = exp(-(weight / 65536.0f * Noise + dist * INV_NLM_WINDOW_AREA));
                        //Write the result to memory
                        // fWeights[ty * BLOCKDIM_X + tx] = weight;
                        fWeights[ty * BLOCKDIM_X + tx] = exp(-(weight / 65536.0f * Noise + dist * INV_NLM_WINDOW_AREA)) * 65536;
                    long x = bx + tx;
                    long y = by + ty;
                        //Normalized counter for the NLM weight threshold
                        // float fCount = 0;
                        long fCount = 0;
                        //Total sum of pixel weights
                        // float sumWeights = 0;
                        long sumWeights = 0;
                        //Result accumulator
                        // float clr[3] = {0, 0, 0};
                        long clr[3] = {0, 0, 0};
                        int idx = 0;
                        //Cycle through NLM window, surrounding (x, y) texel
                        for(long i = -NLM_WINDOW_RADIUS; i <= NLM_WINDOW_RADIUS + 1; i ++)
                            for(long j = -NLM_WINDOW_RADIUS; j <= NLM_WINDOW_RADIUS + 1; j ++)
                                //Load precomputed weight
                                // float weightIJ = fWeights[idx ++];
                                long weightIJ = fWeights[idx ++];
                                //Accumulate (x + j, y + i) texel color with computed weight
                                long clrIJ = tex2D(image, pitch4, height, x + j, y + i);
                                clr[0] += (clrIJ & 0xff) * weightIJ;
                                clr[1] += ((clrIJ >> 8) & 0xff) * weightIJ;
                                clr[2] += ((clrIJ >> 16) & 0xff) * weightIJ;
                                //Sum of weights for color normalization to [0..1] range
                                sumWeights  += weightIJ;
                                //Update weight counter, if NLM weight for current window texel
                                //exceeds the weight threshold
                                // fCount += (weightIJ > NLM_WEIGHT_THRESHOLD) ? INV_NLM_WINDOW_AREA : 0;
                                fCount += (weightIJ > 6553) ? 1337 : 0;
                        //Normalize result color by sum of weights
                        sumWeights = 1.0f / sumWeights;
                        clr[0] *= sumWeights;
                        clr[1] *= sumWeights;
                        clr[2] *= sumWeights;
                        clr[0] /= sumWeights;
                        clr[1] /= sumWeights;
                        clr[2] /= sumWeights;
                        //Choose LERP quotent basing on how many texels
                        //within the NLM window exceeded the weight threshold
                        // float lerpQ = (fCount > NLM_LERP_THRESHOLD * 65536) ? lerpC : 1.0f - lerpC;
                        long lerpQ = (fCount > 6553) ? 13107 : 52429;
                        //Write final result to memory
                        unsigned long clr00 = image[y * pitch4 + x];
                        clr[0] = lerpf(clr[0], clr00 & 0xff, lerpQ);
                        clr[1] = lerpf(clr[1], (clr00 >> 8) & 0xff, lerpQ);
                        clr[2] = lerpf(clr[2], (clr00 >> 16) & 0xff, lerpQ);
                        image_out[y * pitch4 + x] = ((unsigned char)clr[0]) | ((unsigned char)clr[1] << 8) | ((unsigned char)clr[2] << 16);
    return 0;
+1000  科创币    phpskycn    2010/06/18 加少了。。。
+500  科创币    phpskycn    2010/06/18 不解释
来自:计算机科学 / 软件综合
43
小俊 作者
15年1个月前 IP:未同步
225468
为了提高速度,所有运算放大65536倍后基于整型进行,避免过多浮点运算。
运算速度在破双核E7200上大概为每秒处理160万像素,悲剧了,1000多万像素的照片得处理10秒。。。
小俊作者
15年1个月前 IP:未同步
225472
降噪效果测试:
500D拍的室内照片暗部,ISO1600,0.125s,原图裁剪:
处理结果(参数为noise=0.25, lerpc=0.15)
小俊作者
15年1个月前 IP:未同步
225473
原算法来自CUDA SDK。
这个程序的CUDA版本代码在GTX285上的速度大概为双核E7200的80-90倍。
小俊作者
15年1个月前 IP:未同步
225475
引用第5楼y2k于2010-06-18 00:26发表的  :
感覺細節失了不少...
哪里的细节丢失了?请圈出
局部颜色过渡不自然倒是有点
小俊作者
15年1个月前 IP:未同步
225482
引用第7楼y2k于2010-06-18 00:33发表的  :
所有的花纹都还在吧,只是对比度损失了一些,可以加一级处理纠回来
小俊作者
15年1个月前 IP:未同步
225496
引用第9楼cat13于2010-06-18 00:46发表的  :
处理后不锐了 不处理的图还可以接受
世界上有一样算法叫USM锐化:
不处理那是噪点满天飞了。
小俊作者
15年1个月前 IP:未同步
225506
引用第12楼warmonkey于2010-06-18 01:22发表的  :
对焦不太好,另外请上100%截图
已经是原图大小的截图,可能屏幕分辨率不够大的话论坛给缩小了
给个小尺寸截图:
小俊作者
15年1个月前 IP:未同步
225507
引用第11楼花落一天于2010-06-18 01:19发表的  :
眼神不好,没看到燥点少了多少.........倒是看到锐度降低了很多,整个图糊了........
可能你的屏幕分辨率太低了,论坛把图缩小了
小俊作者
15年1个月前 IP:未同步
225601
引用第18楼hmy0011于2010-06-18 13:31发表的  :
用易语言的飘过。。。不懂高深的英文编程。。
高不高深不在于语言本身,而在于算法。
小俊作者
15年1个月前 IP:未同步
225609
引用第20楼phpskycn于2010-06-18 15:02发表的  :
看图
GTX285不是人人都有的,不过在GT240之类主流产品上的速度应该还可以接受。
上面那个E7200的速度是单线程的?另外感觉躁点仍然存在,少了很多
是多线程的,线程数量等于CPU核的数量。我发的代码也是线程函数。
并行计算时代已经到来,过去靠彪CPU频率来拼速度的时代一去不复返。
即使不用CUDA,也应该在编程时考虑并行化和多线程。
另外GT240之流已经不能算是主流产品了。Fermi系列的最低端GF108已经达到GT240的级别。
小俊作者
15年1个月前 IP:未同步
225647
引用第22楼phpskycn于2010-06-18 17:10发表的  :
GF108还有若干个月。。。
额那两个线程如何同步?把图像裁两半分开处理?
正解。。。
GF108,1个月之内必出,96个SP。
小俊作者
15年1个月前 IP:未同步
225698
引用第24楼startwood于2010-06-18 17:35发表的  :
额,那么中间分开那地方便还得再处理遍。。。
TSMC产能有点小小的问题,还有我发现NV似乎还没完全清仓,GT200系列还要存在一段时间,不知道啥时候GF10X才能替代原来那些产品,价格降到正常点的价位。
GF108要是便宜的话买一张……i7配7300LE太那个了。。。
不需要处理分界部分。这个是根据输出像素来划分线程的。
小俊作者
15年1个月前 IP:未同步
226729
引用第27楼startwood于2010-06-18 19:28发表的  :
我个人认为LZ属于那种已经不用看书多年的。
纸质书的确很久没看过了,现在再看会睡着的。
电子文档倒是经常看,不一定是书,多数是技术文档或者论文一类的。
小俊
进士 学者 机友 笔友
2006/12/29注册,4个月0天前活动
