上点好料
波锅涅2009/08/21喷气推进 IP:浙江
1. KNSU的安全性
I've never felt very comfortable writing about safety, I don't really feel qualified. But I have been doing it long enough now, without any accidents, that I can at least offer some pointers. This page is by no means complete, I'll add to this page as I deem it necessary. I also welcome any pointers from my readers, the EX community. This will be more of a rambling narrative than a guide, so bear with me.
Tip 1: Acquire as much knowledge as possible.
That includes reading books, scouring the internet and most importantly, find an experienced mentor to help. The knowledge and experiences of an experienced motor builder will be invaluable. Don't take one book, or one web site (mine included) or even one persons advice as the gospel truth. Take a long look at all the information as a whole, and make informed decisions from that.
First, let me start by saying there is one thing that has really caught my attention. No two motor builders do it exactly the same. Casting sugar propellant is perhaps as much an art as it is a science. Some of that has to do with what the builder has available to work with and some is personal preference. I've also noticed it's difficult for one builder to exactly duplicate anothers results. Let's explore the reasons for this.
First of all the chemicals used. KNO3 comes in a variety of flavors; prilled, granular, powdered, anti-cake added/no anti-cake, greenhouse grade, fertilizer grade, USP grade, you get the idea. Then there is environmental conditions such as ambient humidity and temperature. Was the KNO3 dried first or used as obtained? How was it stored? If the KNO3 was ground, how was it ground? For how long? Was it ball milled? Now you can go through the same with the sugar, perhaps not to that degree, but it all makes a difference.
Next we look at the process used to make the propellant. Everyone seems to have their own way of doing that too. Some add water, corn syrup, glycerin, or in my case propylene glycol. The melting pot you use makes a difference too. If your pot is 20 degrees hotter than mine, you boil off all the propylene glycol before it has a chance to work. Maybe your melting pot has a couple of hot spots and some cold spots.
Tip 2: Keep detailed records.
The point I'm trying to make is this, everything you do makes a difference. The only way for you to reproduce your results is to make detailed notes of all conditions, and then the results. Try not to make a bunch of changes at once. If you only change one parameter at time, your confidence level of the results of the change will be much higher.
Tip 3: Use an accurate scale.
I use a triple beam lab scale accurate to 1/10 gram. I know a lot of people use inexpensive digital scales now, but I'm not sure I really trust a $50 digital scale to be that accurate. If you must use a cheap digital scale, at least buy a set of accurate weights so you can test the scale.
Tip 4: Avoid creating dust clouds with any materials, oxidizers or fuels.
A dust cloud of any chemical presents the added risk of a dust explosion. We don't usually use powdered metals with sugar propellant, but they present the greatest risk.
Tip 5: Ground yourself before working with chemicals.
A dedicated ground strap is the best, Radio Shack hides them. The idea is to prevent static discharge which could ignite propellant or chemicals. If you work with powdered metals, they are generally more sensitive to high levels of humidity than sugar propellants, and require a fairly low humidity level, be aware the risk of static discharge is much greater at low humidity levels. With standard sugar propellants, i.e., KNO3 and a sugar, a mid range humidity is generally the safest to work in, such as 40 to 60% relative humidity.
Tip 6: Use a thermostatically controlled embedded element heating vessel.
Casting sugar propellant involves heating the KNO3 and sugar. Providing it is done using a heating pot that has embedded heating elements and has a thermostat control it's a fairly safe operation. Under no conditions do I feel it would be safe to heat over a gas stove or open electric element. I don't care how thick the pan or pot is I'm using. I don't think heating the propellant in a double boiler (wax or oil bath), is really safe either. The heating elements still need to be embedded, and now you have the increased risk of an oil or wax spill causing a burn. I use a Presto Multi cooker, it's $20 from most any department store and has a large capacity. I ALWAYS, always, always preheat the pot before adding the chemicals. That keeps the propellant away from those initial hot spots as the cooker heats up.
Tip 7: Don't cast in your house.
Don't cast propellant in an area you don't mind burning down. Serious now. You don't need the wife and kids living in the streets because you burned the house down. Do your casting outside if possible, or in an outbuilding of some sort. Regardless, keep a fire extinguisher and a five gallon bucket of water on hand at all times.
Tip 8: Wear safety clothing.
I'd recommend a leather welders apron, long sleeve cotton shirt, leather gloves and a face shield. Eye protection and gloves at the absolute minimum. One drop of melted propellant on your skin and I guarantee you'll wear protection next time.
Tip 9: Start small, work up incrementally.
One of the scariest things I see, is people wanting to build a "K" or "O" class motor right away. Their theory is they don't want to "waste their time with the little stuff". Oh, my! I've seen it many times and it still makes me shudder. Small PVC cased motors are a great way to get started. They are inexpensive, easy to build and much safer if they cato.
Tip 10: Derive your own burn rate data for your propellant.
I see a lot of numbers floating around, the a and n values, burn rates and such on different sugar propellants. Don't trust the numbers someone else came up with. Because of the differences mentioned at the start of this page, you're propellant will likely not follow the same numbers. I don't like the idea of gauging a propellant by its open air burn rates. What I've found is that how a propellant burns in open air has little to do with how it burns under pressure.
Tip 11: Understand the Kn ratio and how it affects the motors burn.
I think most people use the Kn (Kn is the ratio of propellant burning surface area to nozzle throat area) numbers when building a new motor. You can also use propellant flow rates when designing a new motor. Either way works fine, but Kn ratios seem a bit easier to work with. I have a Kn calculator program that I wrote in my Software page, you don't have to use mine (in fact there are flashier ones out there), but mine is accurate and I use it all the time. Understanding the Kn is vital to understanding how the motor performs.
Tip 12: Use good inhibitors and perform tests.
A Bates grain allows a propellant grain to burn on its outside ends and the core, the outer surface of the grain is inhibited from burning by applying an insulator or ablative material of some sort. Two things are absolutely imperative with a Bates grain: 1) The inhibitor must be securely bonded to the propellant so no burning can take place between the inhibitor and the propellant surface. 2) The inhibitor layer must be able to withstand the heat of the entire motor burn. It really depends on how long the motor burns, and the design of the motor. In most cases, casting propellant into cardboard, or on larger motors a phenolic tube is adequate. Of course testing is always in order.
Tip 13: Make certain your sugar propellant grains are free standing and not case bonded.
There are those that have had success case bonding (case bonding is casting propellant directly into the motor casing), but that is only after using additives to increase the flexibility of the propellant. All the propellants I use are too brittle for case bonding. The propellant grains must be sized to allow the combustion gases and pressure to flow around the grains, that way there is only compressive forces on the grains, which they can easily handle. If the grains are too large in diameter, they can seal the inhibitor to the casing, causing the grain to fracture. If the grains are too long, the grains may seal at the top and bottom of the motor, again, causing the grains to fracture from overpressurizing.
Tip 14: Use spacers between Bates grains.
The reason for spacers is to prevent the grains from sticking together, (end to end). This really concerns me, and I'll not sure how other people address this issue, or if they even do. If the grains all stuck together, you'd have one long grain, that would create a low Kn at the start of the burn, and a very high Kn at the end of the burn. The result would likely be an overpressure of the motor near the end of the burn.
I use PVC pipe large enough to touch the outside wall of the motor chamber, the segments vary in width depending on the motor size. 1.5" motors are generally about 1/8" thick, larger motors up to 1/4" thick. I then cut out a section of the ring so it forms a "C" shape. The reason for cutting out that section is to allow gases around and between each of the grains.
I'm not certain how long these spacers have to support the grains, but keep in mind the loading that will occur on the grains and spacers during liftoff of a rocket. Presumably, during a static test the spacers would only support the weight of the grains themselves. I also assume that once all the end surfaces are burning the gas layer that forms would help support and keep the grains apart, though I have no data to back that up.
Tip 15: Inspect grains for cracks.
With an outside inhibited grain it's not easy to see cracks in the grains. But it is vital to inspect the grains carefully. Most cracks are visible on the end surfaces of the grains, and extend into the grain.
Tip 16: Clean up the burning surfaces of the grains before using them.
I usually do this with erythritol and xylitol grains, I use a wire brush to clean the inside surfaces of the core, and I shave the ends of the grains with a razor blade. This removes any residue of wax paper, and exposes a clean layer of propellant. I wonder if a layer of only sugar forms too, on those outside surfaces. So cleaning them up a bit may help to expose a layer of propellant with a balanced ratio of KNO3 and sugar.
Tip 17: Do a density check on grains before testing.
Once the grain is trimmed to length (if needed), I carefully weigh and measure each grain. Using my Density/Converter software I input the numbers to see where the density is. Density will vary between propellants, but after a few tests you'll get the feel for what the density should be. My xylitol and erythritol grains run in the .061 to .063 pounds per cubic inch range. Sucrose grains run .064 to .065 pounds per cubic inch. If I need to cut or trim a grain, I usually use my band saw. The band saw cuts a very fine kerf and allows me to see some of the inside surfaces and check for voids or small bubbles.
Tip 18: Find a remote area to test your motors.
If you live in a city, you absolutely must find a wide open area to test your motors. I would suggest at least 1/2 mile and preferably more from anyone or anything of value. Even then, the motor should be surrounded by a berm or protective barrier of some sort. Digging a hole in the ground and performing the test with the motor underground is one of the easiest ways to add protection while static testing.
Tip 19: Keep yourself protected during a motor test.
Distance is fine, but the potential exists for a cato to throw motor parts for thousands of feet. Distance really only helps in the fact that if parts are thrown your direction, there is less of a chance of being hit by one. Let's say for example you are located 100' from the test motor during a cato. If your body is two feet wide, and the circumference of a 100' radius is 628, you have a one in 314 chance of being hit if a piece flies off on your plane. Now let's increase that to 200' distance. Now the circumference is 1256', and your chance of being hit falls to one in 628. So distance increases your odds, but is no guarantee. (Note: I'm just using a 2 dimensional plane as an example, in reality, the third dimension would make it even safer the farther back you move.)
With that in mind, there are other things to protect yourself. Building a bunker is nice, but not practical for most of us. Again, testing the motor with a protective barrier around it increases the odds in our favor. I would not recommend watching a motor test with the naked eye. Use a mirror from behind something such as a bunker wall, hill, berm, or big heavy car or truck. You should be video taping the event for data anyway, so you can watch it over and over once it's recorded. If you're feeling lucky, and had good distance, watching the test through both rear and front windows of a vehicle would provide some protection. As would a dedicated blast shield with a thick plastic window of some sort.
Tip 20: Have a fail proof safety switch on your ignition control box.
My launch control box has a key switch, I can take the key with me when setting the motor on the test stand. Here's the way I set up for a static test.
Once at my remote test site I check for any people in the area while I set up the test stand. Then I set up the data acquisition power supply and wiring. The launch control wire is then laid to the test stand, but is not hooked up at either end. I use regular extension cords, and have a whip end with alligator leads to go to the igniter that plugs into the extension cord. The motor is placed in the test stand, the key to the launch box is in MY pocket, the launch control box is not yet set up. I get a single igniter from my igniter case, (it's leads are shunted) and remove the nozzle seal on the motor. I unshunt the leads and insert the igniter all the way to the forward bulkhead of the motor. I grab the alligator clips leads from the still unconnected ignition wire, then short the alligator clip leads together. This is to make sure there is no power on the wire, there shouldn't be, as the launch box isn't hooked up yet, and also to discharge any possible static charge in the wire. The alligator clips are attached to the igniter, and I quickly make my way back to my safe area for performing the ignition.
Data acquisition and video recording is now started. The ignition lead wire from the test stand is only now inserted into the receptacle on the launch control box. Next, the power supply leads to the launch control box are connected to the battery. One last check to make sure all is clear. The key is inserted into the launch control box and turned to the power on position. The main power switch for the launch control box is now turned on. Next, announcement of the impending countdown, and to take cover. The continuity button is pressed to check continuity to the igniter. Good continuity is announced. Then, "Countdown, 5,4,3,2,1, ignition."
Tip 21: Wait at least 5 minutes before approaching a motor that failed to ignite.
This should be common sense. I've had motors that looked like they failed to ignite, without even visible signs of smoke coming from the motor, then after some time they took off. After a failed ignition, turn the power off, disconnect the battery, remove the safety key, unplug the ignition lead wire from the launch control box and wait 5 minutes before approaching the motor.
Tip 22: Keep extra people in the safe area all the time.
If you must have spectators, don't let them in the danger area at any point before, during or after the test.
Tip 23: It's best for only one person to prep, set up and conduct the test.
If you have other people performing some of the tasks, you can never be certain of what they did. This is a case of, "If you want it done properly, do it yourself."
Tip 24: Use a checklist.
To make sure you don't forget anything, and do everything in the proper sequence. It's only natural to get a little excited about the impending test, in your excitement it's easy to forget procedures.
Tip 25: Keep a well stocked first aid kit in your launch box and know how to use it.
Tip 26: Be over cautious.
You can never be too careful. But one time being under cautious can lead to disaster.
波锅涅 作者
15年5个月前 IP:未同步
143281
XXXXSU的浇筑
This page explains the casting process I use to make sugar propellant grains for my home built motors. I tend to use a 65% KNO3 and 35% Sugar mix for all my motors. It gives just about maximum performance with relatively low combustion temperatures, in fact, the combustion temperatures are low enough that no thermal insulation is required in the motor when using steel for the casing, nozzle and top closure. Stainless steel could be used, but it is an added expense not required.
To start with, the KNO3 and sugar(this is powdered sugar, under a dollar for a two pound bag) should be carefully measured by weight, to the desired 65%/35% ratio. I use a triple beam lab scale. First, weigh a plastic, sealable container (such as tupperware) on the scale. This is your tare weight, for example, let's say our plastic container weighs 11 grams, and we are making a 100 gram batch of propellant. We need to add 65 grams of KNO3 to the container so we would set the scale to 76 grams, and add KNO3 until the scale balanced at 76 grams. Now we need to add the 35 grams of sugar, so the scale is now set to 111 grams, and sugar added until the scale is again balanced. Now we have the correct ratio of fuel (sugar) to oxidizer (KNO3).
I use two different preparation techniques for mixing the sugar and KNO3.
If I am seeking maximum Isp, and a fast burn rate, I use a tumbler with leads balls to grind and mix the KNO3 and sugar. Care must be taken, as the mixture is now flammable. Keep away from heat, physical shock and static charge. I tumble the mix at a very low rpm, for about three hours. The result is a very fine, homogenous powder.
If I want a lower burn rate, and don't mind a slightly lower Isp, I will simply put the cover on the container I weighed in. And shake it for a few minutes before casting. This method also makes casting easier, as the courser particles make a thinner, less viscous propellant when melted.
Before starting the heat casting process. Make sure you have everything on hand before starting.
Heating Pot. I use a Presto Multi Cooker. It is thermostat controlled from 200 to 400 (F) and has a non stick surface. It's about $20 from any discount store. Never use a pot on a range or electric burner! Only use a heating vessel with embedded heating elements. Test the heating vessel with small amounts of propellant to identify problematic local hot spots. Always pre heat before adding the dry propellant.
Heavy Duty Plastic mixing spoon for stirring the propellant. I use one that has a flat tip, it makes scraping the bottom easy.
A couple of more smaller spoons for scraping the larger spoon.
Casting stand. I use a wood base, with a PVC support tube glued to the wood. I also drill a centering hole in the wood to insert the coring tool.
Casting tube. (if making an outside inhibited grain) This could just be a few wraps of paper lining the inside of the PVC support, a cardboard tube or even a smaller diameter PVC sleeve. I've had good luck with 2.5 to 3 layers of regular 20 pound printer paper on motors 1.5" and smaller. For larger motors I use 2 turns of tag board paper, finish up with a layer of aluminum tape over the paper or cardboard once the grains have cured. The idea is to keep the outside surface of the grain from burning, it only has to last a for a couple of seconds or less.
Wax Paper. I use a small piece of wax paper in the bottom of the support tube to keep the propellant from sticking to the wood base.
Coring tool. This is a rod to create the core in the grain. It can be most anything that's smooth and won't melt. I use hard wood dowels that I coat with paraffin for small cores, and steel bar for larger motors.
Gloves. The melted propellant will stick to you and leave painful, nasty blisters. Use gloves!
Heavy, long sleeved shirt. Again, to prevent burns.
Full face shield. You really don't want this stuff on your face. It may also save your pretty face if your propellant burns unexpectedly.
Water. Keep at least 5 gallons of cold water on hand.
Fire extinguisher. Just in case!
I also use silicone spray. Available from dive stores. I comes in a little pump bottle, spray some on the coring tool to make removal of the tool easier.
Everything ready? Now comes the fun part, sort of...
Let your pot preheat to 325(F) then add your premixed KNO3 and sugar. This batch used prilled/granular KNO3 and was not ball milled in the tumbler. This batch weighed 450 grams (just under 1 pound). Start stirring as soon as the powder is in the pot and don't stop stirring.
This is after about 1.5 minutes, you can see it starting to form clumps.
This is after 2.5 minutes, there are more small clumps.
About 3.5 minutes, don't stop stirring!
After 5 minutes there is no powder left, it's all small clumps.
After 6 minutes it's starting to liquefy.
After about 7 minutes it starts looking like mashed potatoes.
After 8 minutes it's becoming a viscous liquid. At this point I try to spread it out to cover the bottom of the pot. Rather that actually stirring, I sort of push it around with the spoon.
Now it's truly a thick liquid, and you can stir again. At this point some bubbles will start to appear, I believe this is water boiling out.
Keep heating and stirring until all lumps are gone, and no more bubbles come to the surface. At this point the propellant is ready to be cast. Turn the heat off and spray silicone on the coring tool.
Update: I now add 2% of the total propellant batch weight in propylene glycol to thin the propellant. You can see some information on the propylene glycol here. Once thinned with the propylene glycol the melted propellant can, for the most part, be poured into the casting tubes when using granular KNO3.
Now scoop the propellant into the casting tube with your big spoon. You only have 2 or 3 minutes before the propellant starts to harden and thicken. Using the granular/non-milled version, the propellant is liquid enough that no packing is needed to remove air spaces. I just tap the whole thing on the counter after each big scoop to help settle the propellant. If you ball milled the mix, you may need to use a frozen steel bar to pack the propellant into the casting tube. Bubbles in the propellant can be a disaster, they increase the burn surface area, thus increasing chamber pressure to point your motor may overpressure.
Fill the casting tube not quite full, now insert your coring tool. As the tool is lowered into the propellant, displaced propellant fills the casting tube to the top. Try to keep the coring tool in the center of the casting tube, when you hit the wooden base, rotate to tool slightly to find the hole in the bottom. Push the tool into the pre drilled hole to center and hold the coring tool in place.
Set the casting stand in a cool place (not a freezer). Depending on the size of your grain, it may take anywhere from 15 to 30 minutes to firm up. I like to remove my coring tool while the propellant is still warm. Don't take it out too soon, or the propellant will slump back into the core. A little experience here will tell you when to remove the tool.
A few notes about the propellant:
Sugar propellant is very hygroscopic, that is, it readily absorbs moisture from the air. You need to keep your grains stored in a desiccant box of some type. I use a large tupperware tub with an air tight lid. I filled the bottom with calcium chloride pellets (ice melt) and used a wire grate in the bottom to keep the grains out of the calcium chloride.
Never case bond the propellant. In other words, don't cast the propellant directly into your motor casing. The propellant is very brittle, and when the motor comes up to pressure the case will flex, the propellant won't flex, it will crack. Causing a large surface propellant area to be exposed to burning, causing a probable cato (KABOOM). Early on I tried case bonding, each and every time the motor failed.
Start with small motors and work your way up.
Some people consider sugar propellants as amateurish. Well, I think that's just fine. I can fly 60 of my J class motors for the same cost as one commercial J motor. Now, who do you think does more flying? The density of sugar propellants is high, cubic inch for cubic inch you can pack just about as much impulse in a sugar motor as you can an AP motor. The fast burning propellant also means you don't carry around the weight of unburned propellant very long, it also gives you quick acceleration for quick flight stability.
When using a paper casting tube/liner. Make your support tube removable. I use a PVC support tube and cut about 1/2" off a PVC coupler of the same size. Then glue the coupler piece you cut off to the wood base. The PVC support tube can then be easily removed. Also, with a paper liner, they tend to want to float up out of the support tube as you pack in the propellant. I started cutting the paper liners a little longer, then scored the bottom of the paper with a scissors to flare out the bottom. Then push the support tube onto the base with the flared paper caught under the support tube.
You can tape wax paper to your coring tool to keep it from sticking. The wax paper usually stays stuck to the grain but the tool comes out easy. You should clean the wax paper out of the core with a drill bit, knife or sand paper.
You can cast grains without a core at all. Once the grains are cooled you can drill them out to the desired core size. A spade (flat) bit seems to work the best. It is a waste of propellant though, and I always have a hard time drilling the core out true.
波锅涅作者
15年5个月前 IP:未同步
143282
补上图片 knsu1.jpg    knsu2.jpg    knsu3.jpg knsu4.jpg knsu5.jpg knsu6.jpg knsu7.jpg knsu8.jpg knsu9.jpg knsu10.jpg knsu11.jpg
波锅涅作者
15年5个月前 IP:未同步
143283
燃烧率测试及结果
This page will document my burn rate tests of KNO3/sugar using both the KNO3 and powdered sugar in the as obtained form. No grinding or ball milling of the mix was performed. The two ingredients were simply shaken together for 4 or 5 minutes in a sealed plastic container.
Richard Nakka has fully characterized the finely ground KNO3 and sugar propellants, but there are times when using the "as obtained" ingredients are beneficial.
The lower burn rate may be beneficial for certain rockets.
Casting is easier due to the thinner, more pourable nature of the non-powered mixture.
May be a safer propellant due to less chance of bubbles and voids forming in the cast propellant.
Easier to mix and cast, especially for a novice.
This page is a log of ongoing tests, and final data will not come until the tests are complete. So bear with me on this.
Test: KNSU1
As a benchmark, I did my first test using a strand of ball milled propellant. Here are the results of that first test.
Strand Length: 1.9"
Strand Weight: 13 grams
Maximum Pressure: 402 psi
Burn Time: 3.4 Seconds
Average Burn Rate: .558"/Second
Chamber Pressure start: 0 psi
Average Pressure 201 psi
Test: KNSU2 (non powered)
Strand Length: 1.75"
Strand Weight: 5.5 grams
Starting Pressure: 105 psi (air)
Maximum Pressure: 499 psi
Average Pressure: 302 psi
Burn Time: 4.26 seconds
Burn Rate: .411"/second
Test: KNSU3 (non powdered)
Strand Length: 1.5"
Starting Pressure: 201 psi (air)
Maximum Pressure: 1,183 psi
Average Pressure: 491 psi
Burn Time: 2.1 seconds
Burn Rate: .714"/second
If you look at the data above, you may notice some interesting points. Max pressure of 1,183 psi and a burn rate of .714"/second, how can this be? Well, it wasn't unexpected. I was using air to pressurize the chamber for these tests, and I knew that using air would skew the results, the increased partial pressure of oxygen in pressurized air at 201 psi is 14.6 times that of air at atmospheric pressure. I wasn't sure how great the difference would be. The previous test (KNSU2) had me wondering, and this test proved the point. What it means is I must use an inert gas for chamber pressure. I had rather assumed it anyway.
Other things I learned. The strand burner will handle over 1,000 psi. That's good to know but not really the way I wanted to test it. I did blow out one of the epoxy wire plugs after the test. I suppose the heat and very high pressure combined were the cause. Next, I need to find myself a nitrogen tank.
Just for fun here is a graph of the transducer pressure/time trace. The graph was created in Excel after saving the file in csv format from WinDaq Lite. The drop in pressure early in the test was some sort of anomaly. Notice the rapid drop in the pressure at the end of the graph, that is when the one epoxy held wire blew out.
Strand Length: 2.5"
Strand Weight: 16.4 grams
Maximum Pressure: 498.91 psi
Burn Time: 6.033 Seconds
Average Burn Rate: .4144"/Second
Average Pressure 249.45 psi
Strand Length: 2.6875"
Strand Weight: 19.9 grams
Maximum Pressure: 590.91 psi
Burn Time: 6.45 Seconds
Average Burn Rate: .4166"/Second
Average Pressure 295.45 psi
Strand Length: 2.685"
Strand Weight: 22 grams
Maximum Pressure: 704.94 psi
Burn Time: 6.00 Seconds
Average Burn Rate: .4475"/Second
Average Pressure 352.47 psi
Test Sample Weight/Length Burn Rate In/sec Max PSI Time Start Pressure Aver. Psi CPVC Pipe Diameter Density grams/cc
KNSUP1 5.0 grams/1" .4016 782.19 2.49 299.36 540.775 .5" -
- 5.1 grams/1" - - - - - .5" -
- 5.0 grams/1" - - - - - .5" -
- 4.9 grams/1" - - - - - .5" -
