哈哈换了全新的驱动电路,行变发威了!
bomb2009/07/23电子技术 IP:浙江
换了全新的驱动电路,用大功率三极管2n3055来驱动,再加几个电阻,flyback上初级绕两组,一组feedback,一组primary,电弧到1.7cm了,实际看起来很强,比上次那个强劲多了,纸放在中间1秒就烧!!
上图
还有一段视频:
attachment icon MOV-0027.3gp 2.04MB 3GP 81次下载
21
15年7个月前 IP:未同步
130214
1W27ohm电阻是做什么的?
bomb作者
15年7个月前 IP:未同步
130217
The  principle of operation is as simple as the circuit itself: When power is applied, the transistor will conduct the current allowed through resistors R1 and R2 into the flyback primary, causing it to induce a current on the secondary, and, at the same time, on the feedback winding. This feedback current will trigger the transistor to stop conducting, and as the magnetic field in the ferrite core collapses, a large HV spike will appear on the secondary windings (basic inductor action). But now there is no feedback current to keep the transistor off, so it will once again conduct, and the cycle will repeat, at a natural frequency that puts the transformer in resonance, resulting in enormous voltage gain. One of the advantages of having a feedback winding is that the circuit becomes dynamic: The frequency of operation is automatically adjusted to resonance, depending on many factors. It is interesting, because you can actually hear the frequency change as you draw an arc (high loads drop the frequency to a high pitched 20Khz whine which than becomes ultrasonic as the arc grows).
拔刀斋
15年7个月前 IP:未同步
130218
2N3055基极串联一个快速二极管FR107(普通1N4007也行)防止b-e反向击穿,输出电压更高
R1要略减小
15年7个月前 IP:未同步
130220
另外可5W的电阻可用电阻(电阻功率不能太低)并联电容(无极性的)代替,以前我这样做过的确比单用电阻好。
另外楼主是几寸的高压包?
west_0830
15年7个月前 IP:未同步
130230
共集级三极管的连线方式.好像放大倍数不高的.
15年7个月前 IP:未同步
130238
谁能告说我那个1w 的电阻是做什么的?
trample
15年7个月前 IP:未同步
130247
6P   .....玉足................orz.........
15年7个月前 IP:未同步
130252
楼上什么意思?我没看懂。
bomb作者
15年7个月前 IP:未同步
130257
21寸的高压包
bomb作者
15年7个月前 IP:未同步
130258
串联FR157可以不?
bomb作者
15年7个月前 IP:未同步
130266
串fr157我试了效果很不好,电弧长度减一半
15年7个月前 IP:未同步
130273
串个耐压地的fr157耐压1000v
用1N4001可能行
15年7个月前 IP:未同步
130276
真象放P的声音
天狼晓月
15年7个月前 IP:未同步
130645
你把行输出里面那个高压硅堆给想办法去掉效果会更好。
bomb作者
15年7个月前 IP:未同步
130715
这个怎么去掉啊,高压包环氧树脂封了拆不开,我怕拆坏,拆完了卖相也难看
15年7个月前 IP:未同步
130718
我的29寸的高压包电弧都到7cm了二极管还没击穿。
拔刀斋
15年7个月前 IP:未同步
134660
电阻要重新调
引用第11楼bomb于2009-07-23 18:19发表的  :
AsyncMaster
15年7个月前 IP:未同步
135785
关心耗电量,有没有2A?。。。。。。。。。。。。?
笨笨先生
14年10个月前 IP:未同步
208700
引用第16楼223388于2009-07-24 16:37发表的  :
7CM. 70KV ? 你的电路是怎么做的,初级线圈多少砸,有没有详细的说明 啊?
vocal@ルカ
14年7个月前 IP:未同步
234476
Can you speak chinese?
操作原理是【9130】,这条赛道本身:当通电时,晶体管将进行电流允许通过电阻R1和R2为反激式小学,从而导致促使对目前的中学,并在同时,在反馈绕组。这种反馈电流的晶体管触发停止进行,并作为磁场铁芯倒塌,大型高压尖峰会出现在二次绕组(基本电感行动)。但现在有没有反馈电流来保持晶体管关闭,所以它会再次conduct,以及该周期将重复,一种天然的frequency that把在谐振变压器,于丰厚的电压增益resulting。对有反馈绕组的好处之一是,该电路变为动态:工作频率自动调整到共振,这取决于许多因素。有趣的是,因为你其实可以听到频率的变化,你画一个弧(高负荷下降的频率20kHz的高音调抱怨不仅限于成为电弧超声的增长)。
bomb
2006/07/17注册,7年8个月前活动
