这个能改成C#么
大名2009/03/28软件综合 IP:辽宁
//求解任意一元三次方程 a*x^3+b*x^2+c*x+d=0
//输入a,b,c,d;  输出三个解分别为x1,x2,x3
#include  <complex>
#include  <iostream>
#include  <math.h>
using   namespace   std;
void  quadratic_equation(double a4,double b4,double c4,complex<double> &z1,complex<double> &z2);
int main()
    float a,b,c,d;
    double p,q,delta;
    double M,N;
    complex<double> temp1,temp2;
    complex<double> x1,x2,x3;
    complex<double> y1,y2;
    cout<<" please input the coefficients a, b, c, d : ";
    cin>>a>>b>>c>>d;
    //输入一元三次方的系数,得方程为a*x^3+b*x^2+c*x+d=0;
    if(a==0)
        quadratic_equation(b,c,d,y1,y2);
        x1 = y1;
        x2 = y2;
        x3 = 0;
        std::cout<<" x1="<< x1 <<endl;<br>        std::cout<<" x2="<< x2 <<endl;<br>        std::cout<<" x3="<< x3 <<endl;<br><br>    }<br>    else<br>    {<br>        <br>    p = -1.0/3*pow((b*1.0/a),2.0)+c*1.0/a;                  <br>    q = 2.0/27*pow((b*1.0/a),3.0)-1.0/3*b*c/(a*a)+d*1.0/a;  <br>    <br>    // p = -1/3*(b/a)^2+c/a;<br>    // q = 2/27*(b/a)^3-1/3*b*c/(a*a)+d/a;    <br>    //化成 y^3+p*y+q=0 形式<br><br><br>    delta = pow((q/2.0),2.0)+pow((p/3.0),3.0);<br>    <br>    //判别式 delta = (q/2)^2+(p/3)^3;<br><br><br>    <br>    cout<<" delta>0,有一个实根和两个复根;delta=0,有三个实根;delta<0,有三个不等的实根"<<endl;
    cout<<" 判别式的值 delta="<<delta<<endl;<br>    //delta>0,有一个实根和两个复根;<br>    //delta=0,有三个实根;<br>    //delta<0,有三个不等的实根。<br><br>    <br><br>    <br>    complex<double>  omega1(-1.0/2, sqrt(3.0)/2.0);<br>    complex<double>  omega2(-1.0/2, -sqrt(3.0)/2.0);<br><br>    complex<double>  yy(b/(3.0*a),0.0);    <br><br>    <br>    M = -q/2.0;<br><br>    if(delta<0)<br>    {<br>         N = sqrt(fabs(delta));<br>         complex<double>  s1(M,N);  <br>         complex<double>  s2(M,-N);    <br>         <br>         x1 = (pow(s1,(1.0/3))+pow(s2,(1.0/3)))-yy;<br>         x2 = (pow(s1,(1.0/3))*omega1+pow(s2,(1.0/3))*omega2)-yy;<br>         x3 = (pow(s1,(1.0/3))*omega2+pow(s2,(1.0/3))*omega1)-yy;         <br>         <br><br>        std::cout<<" x1="<< x1 <<endl;<br>        std::cout<<" x2="<< x2 <<endl;<br>        std::cout<<" x3="<< x3 <<endl;<br><br>        //输出结果 x1=y1-b/(3*a); x2=y2-b/(3*a); x3=y3-b/(3*a);<br>    }<br>    else<br>    {<br>        N = sqrt(delta);<br><br>        //cout<<" please output the M+N="<<M+N<<endl;<br>        //cout<<" please output the M-N="<<M-N<<endl;<br><br>        //  M+N= -q/2+sqrt((q/2)^2+(p/3)^3);<br>        //  M-N= -q/2-sqrt((q/2)^2+(p/3)^3);<br><br>        complex<double>  f1(M+N,0); <br>        complex<double>  f2(M-N,0);<br><br>         if(M+N >= 0)<br>             temp1 = pow((f1),1.0/3);<br>         else<br>             temp1 = -norm(pow(sqrt(f1),1.0/3));<br><br><br>         if(M-N >= 0)<br>             temp2 = pow((f2),1.0/3);<br>         else        <br>             temp2 = -norm(pow(sqrt(f2),1.0/3));<br><br><br>         x1 = temp1+temp2-yy;         <br>         x2 = omega1*temp1+omega2*temp2-yy;<br>         x3 = omega2*temp1+omega1*temp2-yy; <br><br><br>         std::cout<<" x1="<< x1 <<endl;<br>         std::cout<<" x2="<< x2 <<endl;<br>         std::cout<<" x3="<< x3 <<endl;<br><br>        //输出结果 x1=y1-b/(3*a); x2=y2-b/(3*a); x3=y3-b/(3*a);<br>    }<br><br>    }<br><br>  return 0;<br><br>}<br><br><br><br><br><br>void  quadratic_equation(double a4,double b4,double c4,complex<double> &z1,complex<double> &z2)<br>{<br>        <br>    double delta;<br>    complex<double> temp1,temp2;<br><br>    delta=b4*b4-4*a4*c4; <br><br>    <br>    complex<double> temp(delta,0);<br><br>    temp1 = (-b4)/(2*a4);<br>    temp2 = sqrt(temp)/(2*a4);<br><br>    z1=temp1+temp2;<br>    z2=temp1-temp2;<br>    <br>}
来自:计算机科学 / 软件综合
fw。
15年10个月前 IP:未同步
85567
93°
15年10个月前 IP:未同步
87031
纯算法,啥语言都能 = =
大名
2007/03/05注册,1年1个月前活动
