适用于.NET 2.0 SP2/3.5:
适用于.NET 3.5 SP1:
适用于.NET 4.x:
首先,从这个网站下载SQLite的XXXXXXT驱动。
XXXXXXXXXXXXXXXXXXXXXXXXXXXXX/XXXXXXXXml/doc/trunk/www/downloads.wiki
推荐下载这个版本:
Precompiled Statically-Linked Binaries for 32-bit Windows (.NET Framework 2.0 SP2)
sqlite-netFx20-static-binary-bundle-Win32-2005-1.0.102.0.zip
使用SQLite需要将C#的架构改成x86,不能用Any CPU。
XXXXXXnfig改成这样,不然在新版.NET中会加载失败。
<code class="language-xml"><?xml version="1.0" encoding="utf-8" ?> <configuration> <startup uselegacyv2runtimeactivationpolicy="true"> <supportedruntime version="v4.0.30319"> <supportedruntime version="v2.0.50727"> </supportedruntime></supportedruntime></startup> </configuration> </code>
如果不想改XXXXXXnfig可以下载这个,不过.net3.5及以下版本就不能用了:
Precompiled Statically-Linked Binaries for 32-bit Windows (.NET Framework 4.0)
sqlite-netFx40-static-binary-bundle-Win32-2010-1.0.102.0.zip
使用时添加System.Data.SQLite.dll的引用就行了,不需要做其它事情。
使用示例代码如下,连接时如果文件不存在则会自动创建文件。
<code class="language-cs">using System; using System.Collections.Generic; using System.Text; using System.Data; using System.Data.Common; using System.Data.SQLite; namespace sqlitetest { class Program { static void Main(string[] args) { using (DbConnection conn = new SQLiteConnection("Data Source = test.db")) { conn.Open(); using (DbCommand cmd = conn.CreateCommand()) { cmd.CommandText = "CREATE TABLE IF NOT EXISTS student(id integer, name varchar(20), sex varchar(2));"; cmd.ExecuteNonQuery(); cmd.CommandText = "INSERT INTO student VALUES(1, '小红', '男')"; cmd.ExecuteNonQuery(); cmd.CommandText = "INSERT INTO student VALUES(2, '小李', '女')"; cmd.ExecuteNonQuery(); cmd.CommandText = "INSERT INTO student VALUES(3, '小明', '男')"; cmd.ExecuteNonQuery(); cmd.CommandText = "SELECT * FROM student"; using (DbDataReader dr = cmd.ExecuteReader()) { while (dr.Read()) { Console.WriteLine(dr.GetInt32(0)); Console.WriteLine(dr.GetString(1)); Console.WriteLine(dr.GetString(2)); } } } } } } } </code>
[修改于 8年5个月前 - 2016/07/10 03:10:34]
