枚举应用程序中有缓冲区溢出危险的函数
bruclan2012/08/01软件综合 IP:北京
枚举应用程序中有缓冲区溢出危险的函数,这些函数大多位于老版本的C运行库中,使用Python编写。注意该脚本使用了pydbg库,该库可以从一款名为“白眉”的工具中得到,我会在附件中附上。同时附上微软公布的危险函数列表。如果软件中使用了这些函数,还愁找不到攻击目标吗,哈哈哈。
注意:pydbg只能用于python 2.4版,切记!!!
下面是源代码:
#!/usr/bin/env python
from pydbg import *
from XXXXXXXXfines import *
import utils
# The max number of times of executing single step after restore snapshot
MAX_INSTRUCTIONS = 10
# Functions are considered to be dangerous
dangerous_functions = {
    # Dangerous string copy functions
    "strcpy" : "msvcrt.dll",
    "wcscpy" : "msvcrt.dll",
    "_mbscpy" : "msvcrt.dll",
    "_mbccpy" : "msvcrt.dll",
    "lstrcpyA" : "kernel32.dll",
    "lstrcpyW" : "kernel32.dll",
    # Dangerous string concatenation functions
    "strcat" : "msvcrt.dll",
    "wcscat" : "msvcrt.dll",
    "_mbscat" : "msvcrt.dll",
    "lstrcatA" : "kernel32.dll",
    "lstrcatW" : "kernel32.dll",
    # Dangerous sprintf functions
    "sprintf" : "msvcrt.dll",
    "swprintf" : "msvcrt.dll",
    "wsprintfA" : "user32.dll",
    "wsprintfW" : "user32.dll",
    "wnsprintfA" : "shlwapi.dll",
    "wnsprintfW" : "shlwapi.dll",
    # Dangerous "n" sprint functions
    "_snprintf" : "msvcrt.dll",
    "_snwprintf" : "msvcrt.dll",
    # Dangerous variable argument sprintf functions
    "wvsprintfA" : "user32.dll",
    "wvsprintfW" : "user32.dll",
    "vsprintf" : "msvcrt.dll",
    "vswprintf" : "msvcrt.dll",
    # Dangerous variable argument "n" sprintf functions
    "_vsnprintf" : "msvcrt.dll",
    "_vsnwprintf" : "msvcrt.dll",
    "wvnsprintfA" : "shlwapi.dll",
    "wvnsprintfW" : "shlwapi.dll",
    # Dangerous "n" string copy functions
    "strncpy" : "msvcrt.dll",
    "wcsncpy" : "msvcrt.dll",
    "_mbsncpy" : "msvcrt.dll",
    "_mbsnbcpy" : "msvcrt.dll",
    "lstrcpynA" : "kernel32.dll",
    "lstrcpynW" : "kernel32.dll",
    # Dangerous "n" string concatenation functions
    "strncat" : "msvcrt.dll",
    "wcsncat" : "msvcrt.dll",
    "_mbsnbcat" : "msvcrt.dll",
    # Other dangerous functions will be added
dangerous_functions_resolved = {}
crash_encountered = False
instruction_count = 0
def DangeroursFuncHandler(dbg):
    # If dangerous function is invoked,
    # display some of parameters of function on stack.
    esp_offset = 0
    print "[*] Hit %s" % dangerous_functions_resolved[XXXXXXntext.Eip]
    print "=" * 88
    while esp_offset <= 20:
        parameter = XXXXXXart_dereference(XXXXXXXXXXXXXXp + esp_offset)
        print "[ESP + 0x%02x] => %s" % (esp_offset, parameter)
        esp_offset += 4
    print "=" * 88
    dbg.suspend_all_threads()
    XXXXXXocess_snapshot()
    XXXXXXsume_all_threads()
    return DBG_CONTINUE
def AccessViolationHandler(dbg):
    # If access violation occurs,
    # restore process to last point of calling of dangerous function.
    # When exception occurs, the debugger will receives the exception
    # before debuggee get it. For debuggee can receive this exception,
    # we have to pass the first chance exception.
    if dbg.dbg.u.Exception.dwFirstChance:
        return DBG_EXCEPTION_NOT_HANDLED
    crash = XXXXXXXXash_XXXXXXXXXXash_binning()
    XXXXXXXXcord_crash(dbg)
    print XXXXXXXXash_synopsis()
    if crash_encountered == False:
        XXXXXXocess_restore()
        crash_encountered = True
        # Set each of thread to status of single step
        for threadId in dbg.enumerate_threads():
            print "[*] Setting single step for thread: 0x%08x" % threadId
            hThread = dbg.open_thread(threadId)
            XXXXXXngle_step(True, hThread)
            XXXXXXose_handle(hThread)
        # Now, resume all threads of debugee,
        # this cause the control of debugee was handled by
        # SingleStepHandler routine right now.
        return DBG_CONTINUE
    else:
        dbg.terminate_process()
def SingleStepHandler(dbg):
    global instruction_count
    global crash_encountered
    if crash_encountered:
        if instruction_count == MAX_INSTRUCTIONS:
            XXXXXXngle_step(False)
            return DBG_CONTINUE
        else:
            # Disassembly next instruction
            instruction = dbg.disasm(XXXXXXntext.Eip)
            print "#%d\t0x%08x : %s" % (instruction_count, XXXXXXntext.Eip, instruction)
            instruction_count += 1
            XXXXXXngle_step(True)
    return DBG_CONTINUE
dbg = pydbg()
pid = int(raw_input("Enter the PID you wish to monitor: "))
XXXXXXtach(pid)
# Search for dangerous functions,
# and set bp for them,
# and append them to dict which used to store resolved functions.
for func in dangerous_XXXXXXXXXXXXys():
    funcAddr = dbg.func_resolve(dangerous_functions[func], func)
    print "[*] Resolved breakpoint: %s -> 0x%08x" % (func, funcAddr)
    dbg.bp_set(funcAddr, handler=DangeroursFuncHandler)
    dangerous_functions_resolved[funcAddr] = func
XXXXXXt_callback(EXCEPTION_ACCESS_VIOLATION, AccessViolationHandler)
XXXXXXt_callback(EXCEPTION_SINGLE_STEP, SingleStepHandler)
XXXXXXn()
危险函数的列表可以自己扩展的呦。
attachment icon PaiMei-1.1-REV122.zip 1.74MB ZIP 19次下载
attachment icon Dangerous CRT Functions.rar 79.99KB RAR 20次下载
来自:计算机科学 / 软件综合
