【分享】Ruby元编程资料
acmilan2012/07/28软件综合 IP:山东
里边全是英文版,英文不好的童鞋请使用金山词霸(Windows)或StarDict星际译王(Linux)或直接搜索中文版pdf,仅供学习用途
Ruby入门:Beginning Ruby: From Novice to Professional  中文名:Ruby从入门到精通
attachment icon Beginning Ruby.pdf 7.75MB PDF 37次下载 预览
书中全部源代码:
attachment icon ruby-sources-Begining_Ruby.zip 191.58KB ZIP 36次下载
中文版传不上来,请直接搜索“Ruby从入门到精通 pdf”
Ruby元编程:Metaprogramming Ruby 中文名:Ruby元编程
attachment icon Metaprogramming Ruby.pdf 5.69MB PDF 29次下载 预览
+10  科创币    jrcsh    2012/07/28 高质量发帖
+20  科创币    .........    2012/07/28 高质量发帖
+100  科创币    phpskycn    2012/07/29 据说大神不太缺KCB。。。
来自:计算机科学 / 软件综合
acmilan 作者
12年6个月前 IP:未同步
428609
【转】元编程简介
元编程是指某类计算机程序的编写,这类计算机程序编写或者操纵其它程序(或者自身)作为它们的数据,或者在运行时完成部分本应在编译时完成的工作。多数情况下,与手工编写全部代码相比,程序员可以获得更高的工作效率, 或者给与程序更大的灵活度去处理新的情形而无需重新编译
编写元程序的语言称之为元语言。被操纵的程序的语言称之为目标语言。一门编程语言同时也是自身的元语言的能力称之为反射或者自反
反射是促进元编程的一种很有价值的语言特性。把编程语言自身作为一级数据类型(如LISP,Forth或Rebol)也很有用。支持泛型编程的语言也使用元编程能力。
元编程通常通过两种方式实现。一种是通过应用程序编程接口(APIs)将运行时引擎的内部信息暴露于编程代码。另一种是动态执行包含编程命令的字符串表达式。因此,“程序能够编写程序”。虽然两种方式都能用于同一种语言,但大多数语言趋向于偏向其中一种。
acmilan作者
12年6个月前 IP:未同步
428611
英文对照:
Metaprogramming is the writing of computer programs that write or manipulate other programs (or themselves) as their data, or that do part of the work at compile time that would otherwise be done at runtime. In some cases, this allows programmers to minimize the number of lines of code to express a solution (hence reducing development time), or it gives programs greater flexibility to efficiently handle new situations without recompilation.
The language in which the metaprogram is written is called the metalanguage. The language of the programs that are manipulated is called the object language. The ability of a programming language to be its own metalanguage is called reflection or reflexivity.
Reflection is a valuable language feature to facilitate metaprogramming. Having the programming language itself as a first-class data type (as in Lisp, Forth or Rebol) is also very useful. Generic programming invokes a metaprogramming facility within a language, in those languages supporting it.
Metaprogramming usually works in one of three ways. The first way is to expose the internals of the run-time engine to the programming code through application programming inter*aces (APIs). The second approach is dynamic execution of expressions that contain programming commands, often composed from strings, but can also be from other methods using arguments and/or context. Thus, "programs can write programs." Although both approaches can be used in the same language, most languages tend to lean toward one or the other.
第三种没有中文翻译,有谁翻译下:
The third way is to step outside the language entirely. General purpose program transformation systems, which accept language descriptions and can carry out arbitrary transformations on those languages, are direct implementations of general metaprogramming. This allows metaprogramming to be applied to virtually any target language without regard to whether that target language has any metaprogramming abilities of its own.
acmilan作者
12年6个月前 IP:未同步
428616
第三种就是真正的用程序生成程序。[s:274]
其实在一般语言中调用system("dir/s/b");等,还有调用SQL语句都是元编程,重要的是语言的反射特性。
acmilan作者
12年5个月前 IP:未同步
429236
反射就是程序设计语言的自我反应自我操作,以区别于SQL之类的互操作。
acmilan作者
12年5个月前 IP:未同步
429370
回 7楼(phpskycn) 的帖子
这个是常规技术,而自修改代码是黑客技术,而且这个简单明了用途广。 [s:275]
而且这个是与程序设计语言相关的。。。
acmilan作者
12年5个月前 IP:未同步
429836
回 9楼(phpskycn) 的帖子
认真你就输了
前辈还告诉俺:没有运行时修改指令的基础,就没有运行时不能修改指令的语言[s:274]
POSIX的exec就是在运行时修改自身指令的哦。。。
acmilan
进士 学者 笔友
2009/05/30注册,5年10个月前活动
