老外的几个高压电制作,很牛逼[英文]
金坷居士2012/01/09高电压技术 IP:北京
虽然是英文的,但是强烈建议大家看看
1、自制回扫变压器:XXXXXXXXXXXXXXXXXXX/fryback-transformer/
“When powered by a ZVS and run at 36V the fryback makes some 5 inch long, 2.5cm fat arcs. The voltage is about 20kV while the current must be 100mA or more.”
当用ZVS驱动这个变压器时,输入36V电压,在次级可产生5英寸长、2.5厘米厚的超级电弧(我靠[s:225])。电压有20KV,电流估计有100mA以上。
2、ZVS:XXXXXXXXXXXXXXXXXXX/zvs-driver/
这个讲了ZVS的工作原理,很详细
3、离子扬声器1:XXXXXXXXXXXXXXXXXXX/plasma-speaker-1/
“ About ten dollars and 1 week later my parts arrived, and I put it together in an hour or so. To my surprise it worked fantastically.“
我画了10日元,1周后我的家伙到了,我用1小时把它组装起来。出乎我意料,它工作的刚刚地。
4、微波炉变压器介绍:XXXXXXXXXXXXXXXXXXX/microwave-transformers/
"The microwave oven transformer is possibly one of the simplest methods of making some big high voltage arcs, mainly because they are robust, cheap, and easy to hook up.”
微波炉变压器可能是拉弧的简单方法之一,主要是因为它的功率大、便宜,很容易连接。
5、霓虹灯变压器:XXXXXXXXXXXXXXXXXXX/neon-sign-transformers/
6、离子扬声器2:XXXXXXXXXXXXXXXXXXX/plasma-speaker-2/
金坷居士 作者
13年0个月前 IP:未同步
352296
回 6楼(wangyang386) 的帖子
我刚翻译玩,去看看:
XXXXXXXXXXXXXXXXXXXXXXXX/t/39418
金坷居士
2011/09/23注册,3个月6天前活动
