esp32,继电器,充电宝,结合mqtt服务器实现简单的远程点火
九又2024/07/29原创 计算机电子学软件综合 IP:甘肃
关键词
远程点火esp32
这里采用Arduino 编写/烧录程序 未来想着在此基础上添加推力采集部分(推力采集部分写进新的核心里去,以防止继电器控制函数带来的单核阻塞)
#include <PubSubClient.h>
#include <WiFi.h>
#include <SimpleTimer.h>
const char *mqtt_broker = "192.168.2.3";//mqqt服务器地址
const char *mqtt_username = "mqtt";//用户,密码
const char *mqtt_password = "mqtt";
const int mqtt_port = 1883;//端口
String mqtt_topic = "";
String mqtt_data = "";
boolean mqtt_status = false;
String project = "esp";
volatile boolean qi;//继电器控制函数
WiFiClient espClient;
PubSubClient client(espClient);
void callback(char *topic, byte *payload, unsigned int length) {//mqtt消息读取
  String data = "";
  for (int i = 0; i < length; i++) {
    data = String(data) + String((char) payload[i]);
  mqtt_topic = String(topic);
  mqtt_data = data;
  mqtt_status = true;
SimpleTimer timer;
extern "C"
uint8_t temprature_sens_read();
void Simple_timer_1() {//状态报告
  client.publish("状态",String("检验是否连接,并报告状态").c_str());
  client.publish("状态",String(String("mac地址:") + String(WiFi.macAddress())).c_str());
  client.publish("状态",String(String("温度:") + String((temprature_sens_read() - 32) / 1.8)).c_str());
void qibao()//继电器函数
    digitalWrite(13,LOW);//打开
    delay(1000);
    digitalWrite(13,HIGH);//复位
void setup(){
  pinMode(21, OUTPUT);//声明21引脚使用(sda/scl)
  pinMode(22, OUTPUT);//(sda/scl)
  pinMode(13, OUTPUT);//继电器控制开关
  digitalWrite(13,HIGH);//我的继电器为高电平关闭,低电平打开(这里事先设置为高电平,防止微弱的闭合)(应在上电一段时间且对应继电器状态灯为关闭后在安入点火头)
  //或者建议在安全距离外选择接入点火头
  Serial.begin(9600);//串口开启(后期建议放入线程来提升主频)
  WiFi.begin("1402", "msm53547880");//wifi连接 wifi名,密码
  while (WiFi.status() != WL_CONNECTED) {//wifi等待连接
    delay(500);
    Serial.print(".");
  Serial.println("Local IP:");
  Serial.print(WiFi.localIP());
  Serial.println("hello");
  Serial.println(WiFi.status());
  Serial.println(WiFi.localIP());
  client.setServer(mqtt_broker, mqtt_port);
  client.setCallback(callback);
  while (!client.connected()) {//mqtt连接
    String client_id = "esp-client-";
    client_id += String(WiFi.macAddress());
    Serial.printf("The client %s connects to the public mqtt broker\n", client_id.c_str());
    if (client.connect(client_id.c_str(), mqtt_username, mqtt_password)) {
      Serial.println("Public emqx mqtt broker connected");
    } else {
      Serial.print("failed with state ");
      Serial.print(client.state());
      delay(2000);
  timer.setInterval(500L, Simple_timer_1);//每五秒启动Simple_timer_1(报告函数)
  client.subscribe("报告");//发布订阅
  client.subscribe("状态");
  client.subscribe("数据");
  client.subscribe("引爆");
void loop(){
  client.loop();
  client.loop();
  timer.run();
  if (mqtt_status) {
    if (String(mqtt_topic).equals("报告")) {//判断消息传回
    Serial.println(mqtt_data);
    client.publish("数据",String("以接收").c_str());//测试消息服务器用
      if(mqtt_data=="001")
        client.publish("数据",String("以收到001代码,准备引爆").c_str());
        qibao();
        client.publish("数据",String("以接收,执行完毕").c_str());
  //client.publish("esp",String("检验是否连接").c_str());
(部分为省事,直接从一个可视化编程软件复制过来了)
由于继电器使用电压为5v,所以需要一个外接电源
VID_20240729_185313.mp4  点击下载
大体样子
VID_20240729_202437(0).mp4  点击下载
实验点火部分
未来可以结合mqtt客户端,或者开发内嵌支持mqtt的应用实现便捷的联网点火/实时数据采集与记录
来自:计算机科学 / 计算机电子学计算机科学 / 软件综合动手实践:实验报导
九又
进士 机友
2024/07/23注册,7天12时前活动
没什么简介?时而整整软件时而玩玩硬件......有时玩玩火箭。 有一个个人博客:XXXXXXXXXXXXXXXXat (访问时温柔点,服务器挺不住)
IP归属地:甘肃
