esp32,继电器,充电宝,结合mqtt服务器实现简单的远程点火
九又2024/07/29原创 计算机电子学软件综合 IP:甘肃
关键词
远程点火esp32
这里采用Arduino 编写/烧录程序 未来想着在此基础上添加推力采集部分(推力采集部分写进新的核心里去,以防止继电器控制函数带来的单核阻塞)
C++
#include <PubSubClient.h> #include <WiFi.h> #include <SimpleTimer.h> const char *mqtt_broker = "192.168.2.3";//mqqt服务器地址 const char *mqtt_username = "mqtt";//用户,密码 const char *mqtt_password = "mqtt"; const int mqtt_port = 1883;//端口 String mqtt_topic = ""; String mqtt_data = ""; boolean mqtt_status = false; String project = "esp"; volatile boolean qi;//继电器控制函数 WiFiClient espClient; PubSubClient client(espClient); void callback(char *topic, byte *payload, unsigned int length) {//mqtt消息读取   String data = "";   for (int i = 0; i < length; i++) {     data = String(data) + String((char) payload[i]);   }   mqtt_topic = String(topic);   mqtt_data = data;   mqtt_status = true; } SimpleTimer timer; extern "C" { uint8_t temprature_sens_read(); } uint8_t temprature_sens_read(); void Simple_timer_1() {//状态报告   client.publish("状态",String("检验是否连接,并报告状态").c_str());   client.publish("状态",String(String("mac地址:") + String(WiFi.macAddress())).c_str());   client.publish("状态",String(String("温度:") + String((temprature_sens_read() - 32) / 1.8)).c_str()); } void qibao()//继电器函数 {     digitalWrite(13,LOW);//打开     delay(1000);     digitalWrite(13,HIGH);//复位           } void setup(){   pinMode(21, OUTPUT);//声明21引脚使用(sda/scl)   pinMode(22, OUTPUT);//(sda/scl)   pinMode(13, OUTPUT);//继电器控制开关   digitalWrite(13,HIGH);//我的继电器为高电平关闭,低电平打开(这里事先设置为高电平,防止微弱的闭合)(应在上电一段时间且对应继电器状态灯为关闭后在安入点火头)   //或者建议在安全距离外选择接入点火头     Serial.begin(9600);//串口开启(后期建议放入线程来提升主频)   WiFi.begin("1402""msm53547880");//wifi连接 wifi名,密码   while (WiFi.status() != WL_CONNECTED) {//wifi等待连接     delay(500);     Serial.print(".");   }   Serial.println("Local IP:");   Serial.print(WiFi.localIP());   Serial.println("hello");   Serial.println(WiFi.status());   Serial.println(WiFi.localIP());   client.setServer(mqtt_broker, mqtt_port);   client.setCallback(callback);   while (!client.connected()) {//mqtt连接     String client_id = "esp-client-";     client_id += String(WiFi.macAddress());     Serial.printf("The client %s connects to the public mqtt broker\n", client_id.c_str());     if (client.connect(client_id.c_str(), mqtt_username, mqtt_password)) {       Serial.println("Public emqx mqtt broker connected");     } else {       Serial.print("failed with state ");       Serial.print(client.state());       delay(2000);   }     }   timer.setInterval(500L, Simple_timer_1);//每五秒启动Simple_timer_1(报告函数)   client.subscribe("报告");//发布订阅   client.subscribe("状态");   client.subscribe("数据");   client.subscribe("引爆"); } void loop(){   client.loop();   client.loop();   timer.run();   if (mqtt_status) {     if (String(mqtt_topic).equals("报告")) {//判断消息传回     Serial.println(mqtt_data);     client.publish("数据",String("以接收").c_str());//测试消息服务器用     mqtt_status = false;     }     if (String(mqtt_topic).equals("报告")) {//判断消息传回       Serial.println(mqtt_data);       if(mqtt_data=="001")       {         client.publish("数据",String("以收到001代码,准备引爆").c_str());         qibao();         client.publish("数据",String("以接收,执行完毕").c_str());       }                           mqtt_status = false;     }   }   //client.publish("esp",String("检验是否连接").c_str()); }
(部分为省事,直接从一个可视化编程软件复制过来了)
由于继电器使用电压为5v,所以需要一个外接电源
00:00
00:00
VID_20240729_185313.mp4  点击下载
大体样子
00:00
00:00
VID_20240729_202437(0).mp4  点击下载
实验点火部分
未来可以结合mqtt客户端,或者开发内嵌支持mqtt的应用实现便捷的联网点火/实时数据采集与记录
来自:计算机科学 / 计算机电子学计算机科学 / 软件综合动手实践:实验报导
九又
进士 机友
2024/07/23注册,11天4时前活动
没什么简介?时而整整软件时而玩玩硬件......有时玩玩火箭。 有一个个人博客:XXXXXXXXXXXXXXXXat (访问时温柔点,服务器挺不住)
IP归属地:甘肃
