中国地震台网爬虫+语音报警
大仙2019/12/09原创 软件综合 IP:江苏
语音报警wav文件生成采用开源的Balabolka工具,Json解析使用Newtonsoft.Json,HTTP库采用RestSharp
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.IO;
using System.Windows.Forms;
using System.Media;
using System.Timers;
using Newtonsoft.Json.Linq;
using Newtonsoft.Json;
using RestSharp;
namespace CEIC_Forms
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            this.Text = "中国地震台网数据";
        private void button1_Click(object sender, EventArgs e)
        public static void RunExeByProcess(string exePath, string argument)
            //开启新线程
            System.Diagnostics.Process process = new System.Diagnostics.Process();
            //调用的exe的名称
            process.StartInfo.FileName = exePath;
            //传递进exe的参数
            process.StartInfo.Arguments = argument;
            process.StartInfo.UseShellExecute = false;
            //不显示exe的界面
            process.StartInfo.CreateNoWindow = true;
            process.StartInfo.RedirectStandardOutput = true;
            process.StartInfo.RedirectStandardInput = true;
            process.Start();
            process.StandardInput.AutoFlush = true;
            process.WaitForExit();
        private void timer1_Tick(object sender, EventArgs e)
            try
                RestClient client = new RestClient("http://www.ceic.ac.cn/ajax/speedsearch?num=3");
                RestRequest request = new RestRequest(Method.GET);
                request.AddHeader("cache-control", "no-cache");
                request.AddHeader("Accept-Encoding", "gzip, deflate");
                request.AddHeader("Cache-Control", "no-cache");
                request.AddHeader("Accept-Language", "zh-CN,zh;q=0.8,zh-TW;q=0.7,zh-HK;q=0.5,en-US;q=0.3,en;q=0.2");
                IRestResponse response = client.Execute(request);
                string jsonText = response.Content.ToString();
                jsonText = jsonText.Substring(1);
                jsonText = jsonText.Substring(0, jsonText.Length - 1);
                JObject json = (JObject)JsonConvert.DeserializeObject(jsonText);
                JArray array = (JArray)json["shuju"];
                int i = array.Count;
                this.textBox1.Text = "";
                this.textBox2.Text = "";
                this.textBox3.Text = "";
                foreach (JToken jObject in array)
                    string aa = jObject["LOCATION_C"].ToString();
                    this.textBox1.Text = this.textBox1.Text + aa + "\r\n";
                    string bb = jObject["SYNC_TIME"].ToString();
                    this.textBox2.Text = this.textBox2.Text + bb + "\r\n";
                    string cc = jObject["M"].ToString();
                    this.textBox3.Text = this.textBox3.Text + cc + "\r\n";
                    string filetime = Convert.ToDateTime(bb).GetHashCode().ToString();
                    bool playtrue = false;
                    if (!File.Exists(filetime + aa + cc + ".wav"))
                        playtrue = true;
                        Form1.RunExeByProcess("D:\\Program Files\\Balabolka\\balabolka.exe",
                            "-snq \""+
                            aa+
                            "发生里氏"+
                            cc+
                            "级地震\" \""+
                            filetime+
                            aa+
                            cc+
                            ".wav\""
                    if (playtrue)
                        SoundPlayer player = new SoundPlayer(filetime + aa + cc + ".wav");
                        player.Play();
            catch
来自:计算机科学 / 软件综合
航模发烧友
5年0个月前 IP:广东
867214
看到没命名的文本框,和 aa、bb、cc 这些命名就晕😂
大仙作者
5年0个月前 IP:江苏
867215
引用航模发烧友发表于1楼的内容
😅花10分钟写的,见谅。
航模发烧友
5年0个月前 IP:广东
867242
你看,你发完没多久就真的地震了,有发挥作用吗😁
大仙作者
5年0个月前 IP:江苏
867416
引用航模发烧友发表于3楼的内容
严格来说地震局公开接口速报速度太慢,起不到预警作用的。
paclab
5年0个月前 IP:英国
867486
这个挺好,如果有更实时的数据接口就能做出可视化监测的效果了
你看看日本民间的这个XXXXXXXXXXXXXXXXXXXXXXX/watch?v=ZeZ049BUy8Q
大仙作者
5年0个月前 IP:江苏
867499
引用paclab发表于5楼的内容
这个挺好,如果有更实时的数据接口就能做出可视化监测的效果了你看看日本民间的这个https://www...
实话说成都那个研究所的加密接口也破解了,就是人家接口不公开,发出来不太合适。回头想办法在美观程度上再修正修正。
Leonard
5年0个月前 IP:浙江
867501
爬地震网,代码被人用的多了,怕是变成DDos攻击?一个timeout把你们统统搞定。
5年0个月前 IP:四川
867507
引用大仙发表于6楼的内容
实话说成都那个研究所的加密接口也破解了,就是人家接口不公开,发出来不太合适。回头想办法在美观程度上再...
开发一个地震传感器套件,连接网络或wifi即可共享数据?
SparrowHe
4年11个月前 修改于 4年11个月前 IP:山东
868710
其实....可以用python写一个监听,直接爬网页,那个更新快,或者是监听微博更新也是可以的,而且有轮子
大仙作者
4年11个月前 IP:江苏
868926
引用SparrowHe发表于9楼的内容
其实....可以用python写一个监听,直接爬网页,那个更新快,或者是监听微博更新也是可以的,而且...
python环境装起来太麻烦,对小白使用者不现实。
jemila
4年10个月前 IP:广东
869415
引用大仙发表于10楼的内容
那倒不会,装anaconda一套搞定
大仙
2008/05/17注册,8时43分前活动
