全新,1000元一个
16
3k VDC or 2k Vrms
Reset button
Screw-fastened Euroblock terminal
250 Hz
Software configurable
On: short to GND
Off: open
DI or event counter
8 channels
Dry contact
Wet Contact (NPN or PNP)
On: 10 to 30 VDC
Off: 0 to 3 VDC
2, 1 MAC address (Ethernet bypass)
1.5 kV (built-in)
Web Console (HTTP), Windows Utility (ioSearch)
EtherNet/IP Adapter (Slave), Modbus TCP Server (Slave), Moxa AOPC (Active Tag), MXIO Library
BOOTP, RESTful API, DHCP Client, HTTP, IPv4, TCP/IP, UDP, SNMPv1 Trap, SNMPv1/v2c
Device Settings MIB
Access control list
Power, Ready, Port 1, Port 2
1, 2, 3, 4, 5, 6, 15, 16, 23
Server
Adapter
9 (for read-only), 1 (for read/write)
12 to 36 VDC
110 mA @ 24 VDC
Plastic
27.8 x 124 x 84 mm (1.09 x 4.88 x 3.31 in)
200 g (0.44 lb)
DIN-rail mounting, Wall mounting
I/O cable, 16 to 26 AWG
Power cable, 12 to 24 AWG
-10 to 60°C (14 to 140°F)
-40 to 85°C (-40 to 185°F)
5 to 95% (non-condensing)
2000 m
EN 55032/24, EN 61000-6-2/-6-4
CISPR 32, FCC Part 15B Class A
IEC 61000-4-2 ESD: Contact: 4 kV; Air: 8 kV
IEC 61000-4-3 RS: 80 MHz to 1 GHz: 10 V/m
IEC 61000-4-4 EFT: Power: 2 kV; Signal: 1 kV
IEC 61000-4-5 Surge: Power: 2 kV; Signal: 1 kV
IEC 61000-4-6 CS: 10 V
IEC 61000-4-8 PFMF
ATEX, Class I Division 2
UL 508
IEC 60068-2-27
IEC 60068-2-32
IEC 60068-2-6
RoHS, CRoHS, WEEE
671,345 hrs
Telcordia SR332
