刚注册发现论坛要激活,想做个stm32的东西,可快递都放假了,没办法,手头没东西,就随便发一个吧,这个是去年这个时候帮别人写的,大概就是四个按键控制单片机,按一下按键点亮一个对应led,再按一下灯灭,其中一个按亮灯后,再按其他按键灯灭,然后长按其他按键单片机重启,各位可能觉得没什么难度,当时刚学,写的时候里面的逻辑挺绕的,所以就发这个吧
#include<reg52.h>
#define uint unsigned int
#define uchar unsigned char
#define ulong unsigned long
typedef struct key
uchar key1;
uchar key2;
uchar key3;
ulong flag;
uchar count;
} keycon;
keycon keyarray[8];
ulong n,at,m;
void inittimer0(void);
void delay(uint);
void init(keycon * );
uchar scankeys(void);
void openled(keycon * ,uchar);
void doled(keycon * );
void ledtoled(keycon * ,uchar);
//void closetimer1(void);
//void inittimer1(void);
void main()
uchar i,j;
init(keyarray);
inittimer0();
P3=0xff;
j=9;
while(P3!=0xff);
while(1)
j=scankeys();
if(j<8)
openled(keyarray,j);
while(P3!=0xff);
while(P3==0xff)
for(i=0;i<8;i++)
if((keyarray[i].flag)<n)
ledtoled(keyarray,i);
at&=keyarray[i].flag;
if(at==0xffff)
n=0;
uchar scankeys()
uchar keys;
if(P3!=0xff)
delay(5);
if(P3!=0xff)
keys=P3;
switch(keys)
case 0xfe : return 0 ; break ;
case 0xfd : return 1 ; break ;
case 0xfb : return 2 ; break ;
case 0xf7 : return 3 ; break ;
case 0xef : return 4 ; break ;
case 0xdf : return 5 ; break ;
case 0xbf : return 6 ; break ;
case 0x7f : return 7 ;
else
return 9;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void inittimer0()
TMOD=0x01;
TH0=(65535-60000)/256;
TL0=(65535-60000)%256;
EA=1;
ET0=1;
TR0=1;
void inittimer1()
TMOD=0x01;
TH1=(65535-50000)/256;
TL1=(65535-50000)%256;
EA=1;
ET1=1;
TR1=1;
m=0;
void timer0() interrupt 1
TH0=5535/256;
TL0=5535%256;
n++;
void closetimer1()
TR1=0;
void timer1() interrupt 3
m++;
void init(keycon * keyarray)
uchar pio1,pio2,poi;
uchar i;
pio1=0xff;
pio2=0xff;
poi=0xfe;
for(i=0;i<8;i++)
keyarray[i].key1=pio1;
keyarray[i].key2=pio2;
keyarray[i].key3=poi;
keyarray[i].count=0;
keyarray[i].flag=0xffff;
poi=(poi<<1)|1;
doled(keyarray);
void openled(keycon * keyarray,uchar i)
keyarray[i].flag=1000+n;
keyarray[i].count++;
if(keyarray[i].count==2)
/* if((P3!=0xff)&&(keyarray[i].flag>n))
inittimer1();
while(P3!=0xff);
closetimer1();
if(m>=20) */
// (*(void(*)()) 0x0000)();
(*(void (*)())0x000)();
else
keyarray[i].key1=keyarray[i].key3;
keyarray[i].key2=0xff;
doled(keyarray);
void doled(keycon * keyarray)
uchar temp1,temp2;
uchar i;
temp1=0xff;
temp2=0xff;
for(i=0;i<8;i++)
temp1=temp1&keyarray[i].key1;
temp2=temp2&keyarray[i].key2;
P1=temp1;
P2=temp2;
void ledtoled(keycon * keyarray,uchar i)
// if(keyarray[i].flag<n)
keyarray[i].count=1;
keyarray[i].key1=0xff;
keyarray[i].key2=keyarray[i].key3;
doled(keyarray);
